Author Topic: Applied Mathematics  (Read 2396 times)
Offline lightelectro
  • Pogi/Ganda Points: 51
    • Android Tablet Lover
Applied Mathematics
« on: November 23, 2008, 07:57:24 PM »
Hello, ano po ba ang mga math subjects ang under sa applied math? thanks. 8)
LATEST ANDROID TABLET NEWS
Applied Mathematics
Offline Google
  • Pogi/Ganda Points: 20
Re: Applied Mathematics
« Reply #1 on: November 23, 2008, 08:00:01 PM »
malamang meron dyang algebra  ;D ;D ;D
Offline Bell
  • Pogi/Ganda Points: 18
  • This is real! but this isn't me!!!
« Reply #2 on: November 23, 2008, 08:04:23 PM »
ang unang pumapasok sa isip q is advanced math..
Offline Google
« Reply #3 on: November 23, 2008, 08:07:46 PM »
advanced statistics?
sabi daw nila ang labas daw ng mga karaniwang graduate niya ay statistician or kaya naman ay sa mga banking industry
« Reply #4 on: November 23, 2008, 08:18:18 PM »
ano kaya mga specific subjects dyan? 8)
Offline Google
« Reply #5 on: November 23, 2008, 08:20:54 PM »
iba daw approach sa gnyan puro mano mano daw at saka bihira lang daw gumamit ng calculator sa pagsolve ng mga problems  ??? ???
Offline ef - el - ay - pee
  • Pogi/Ganda Points: 34
  • Regrets, I have a few...
    • The Taste Bytes Food Blog
« Reply #6 on: November 23, 2008, 08:35:21 PM »
actuarial science. :)
may mga subject descriptions. :)
https://www.math.upd.edu.ph/index.php?option=com_content&task=view&id=490
Offline Bell
« Reply #7 on: November 23, 2008, 09:09:55 PM »
iba nman ata yan,e...
u know foyey...in adv. math? ;D
« Reply #8 on: November 23, 2008, 11:48:23 PM »
fourier?
Offline Bell
« Reply #9 on: November 24, 2008, 08:38:39 PM »
Offline ElektroniC8
« Reply #10 on: January 23, 2010, 10:10:49 PM »
HElp mga master :) :D
finding X to this equation
assignment ng pamagkin ko
16x + 10 - 32 = 35 - 10x -5
sa knowledge ko sa math dapat yong  answer ay no decimal point kapag idivide ang two equation at dapat yung rin ang higher or pangalawa na dividend sa lower summation sa 2 equation.
medyo magulo ipaliwanag pero ganito ginawa ko.
16x - 22 = 30 - 10x
16x + 22 = 30 + 10x
16x + 10x = 22+ 30
 = 26           =52
52/26 =   (2) final answer
pwede rin ba ganito mga master?
x1 = 26 - 32     x2 = 25 -5
x1 = 6              x2 =20
ano ang higher number na makaka-divide sa x1 at x2 na walang decimal point  hendi pwedi ang 3 kaya 2
tama ba ang two solution ko,? medyo mahina ako sa math mga master saaken pa nagpaturo pamangken ko ayaw ko naman mapahiya sa kanya :) ;0 ;)
Offline KANGARO
« Reply #11 on: January 23, 2010, 10:17:51 PM »
16x - 22 = 30 - 10x
16x + 22 = 30 + 10x
16x + 10x = 22+ 30
 = 26           =52
x1 = 6              x2 =20
(16x + 10 - 32) = (35 - 10x -5)
answer X=2 correct
Offline ElektroniC8
« Reply #12 on: January 23, 2010, 10:37:11 PM »
master tama ba yong two solution na ginawa ko?  :)
Offline emmgon
« Reply #13 on: June 05, 2010, 08:51:15 AM »
Applied math means that mathematics is applied to any field of science, engineering, or even business and economics. If a mathematical topic (e.g. calculus) can be used to solve a certain real-world practical topic such as estimating the peak of growth of bacteria, i.e. using differential equation, then you have now applied mathematics.
Hope this helps.
Offline Google
« Reply #14 on: June 05, 2010, 09:21:41 AM »
nakakabaliw daw yang lalo na pag MS at PhD students ka na ;D
Offline emmgon
« Reply #15 on: June 05, 2010, 09:03:26 PM »
not really...depende rin kung sino ang naging prof mo sa graduate school... kung hindi marunong magturo yung prof mo sa graduate school, then you're doomed...
