Author Topic: 300W ATX PSU turns on for a split second then dies  (Read 1972 times)
Offline ranronqx
« on: November 24, 2008, 04:09:25 PM »
anu po posible nangyari sa psu after nireplace ung bulging caps along 3.3 and 5v rails, nagshu-shutoff na after turning on for 2 to 3seconds. Nung una nagkaganito din to usually first hour in the morning when i turn on the pc pro maaayos rin after ko idetach ang power cord then apply long pressed to power button for 10 to 15 second then plug it back, tuloy-tuloy na power nya, un nga lang namamatay bigla ung pc. Pero knina nde na nadala sa technique ko hehehehe....I've check the primary and secondary regulators with a vom and DMM ok nman, ung lm339 and KA7500B nireplace na (KA7500B replaced with MB3769) . any ideas po mga gurus? intermediate lang po alam ko sa elec troubleshooting.BTW... model ng psu is Pentium IV EZ-300W ATX
sana po may mkapagbigay ng idea. mga sir HELP PO!
Offline boki
  • Hampaslupang trabahador
    • Magatol pa sa Ikus
Re: 300W ATX PSU turns on for a split second then dies
« Reply #1 on: November 22, 2009, 01:12:55 PM »
Check you CPU heatsink if it is properly attached, if not, the CPU will get overheated that caused your system to shut off
Offline I n s i d e r 2010
  • Pogi/Ganda Points: 100
  • matalino ka man ngayon ay mapagiiwanan ka rin
« Reply #2 on: November 22, 2009, 01:16:24 PM »
try u sa ibang pc bossing,pag shut down parin sure nasa mother board. pag ok na sure nasa pc parin kaya check u ung mga resistor sa trigger ng input or primary . hope makatulong
ang PIKON ay laging TALO,tandaan nyo po yan mga kapatid. IRESPETO ang bawat isa!
ang PANLALAIT sa kapwa ay isang kasalanan na
pagbabayaran mo rin balang araw!
Offline bugsky777
« Reply #3 on: December 17, 2009, 05:41:10 PM »
check mo tol yung thermal paste sa heatsink baka tuyo na.. baka overheat yung pro kaya nag shashutdown
Offline ronelex
  • Pogi/Ganda Points: 6
  • JR Computer Technician
    • Ronelex Repair Blog
« Reply #4 on: November 30, 2011, 05:58:26 AM »
sa mga inayos ko dito sa ofis. If test the power supply iikot for 3sec0nds ang fan din off ang supply. Kadalasang problema sa psu ay mga output na diode na kamukha ng transistor pero may diode sign ang marking. Kadalasan ang pang 12v ang nasisira.
cause: mahina na ang ikot ng fan dahil sa mga alikabok kung kaya nag.ooverheat at nasisira ang mga pyesa.
sana nakatulong, based on my experience lang po
Offline ars
  • No man is an island
« Reply #5 on: December 02, 2011, 08:34:37 AM »
ts...replace nyu po ung 470uF/16v 2 pcs yata un...sana mkatulong
Offline Tukkar
  • Pogi/Ganda Points: 23
  • My Russian tube amp 6P3S_6N8S_6N9S
« Reply #6 on: January 06, 2012, 02:09:11 PM »
From my experience too....leaky caps o yung mga lumobo ng electrolytics subukan mo palitan at saka yung ultrafast o diodes stack check mo kung okay pa....one thing more ..cold solders...
Pag gusto maraming paraan, pag ayaw maraming dahilan!!!!...
Online pete
« Reply #7 on: January 06, 2012, 05:43:22 PM »
binuhay ang bangkay hehehehe
  • Pogi/Ganda Points: 98
« Reply #8 on: January 06, 2012, 05:52:55 PM »
itest mo without any load by connecting the green wire to ground.
try mo kung gagana sya kung hindi. its time to buy a new one ;D
« Reply #9 on: January 07, 2012, 08:17:49 AM »
Binubuhay talaga. hehehe
« Reply #10 on: January 07, 2012, 08:49:30 AM »
tomoo! pag gumana naman sa board or overhet cpu
Offline stealthwalker
« Reply #11 on: May 09, 2012, 09:08:22 PM »
sis/sir try mo muna tanggalin PSu from board them short green & black sa duration pag naka-On yung PC tingin ko kasi bloated caps prin sa PSu problem mo..
