Author Topic: [im]Duino - MCU development board based on Arduino - FAQs and Tutorial  (Read 20522 times)
Re: [im]Duino - MCU development board based on Arduino - FAQs and Tutorial
« Reply #20 on: February 26, 2009, 02:10:50 PM »
uy! ok to ah.. ngayon ko lang nakita to.. wala pang testimonials kung gaano sya kahirap gamitin? ???
meron before kaya lang napasama sa roll back
Offline ATE
    • Volts and Bytes
« Reply #21 on: February 26, 2009, 05:47:47 PM »
sir beginner wan, nagbebenta ka din ka ng ibang avr chips bukod sa atmega8?
Offline paranz
  • Pogi/Ganda Points: 177
  • 1/4W resistor specialist
    • RapidSignal Electronics
« Reply #22 on: February 26, 2009, 05:48:37 PM »
@ wan
ty sa [im]duino board. God bless you.
Offline beginner wan
  • Pogi/Ganda Points: 46
    • [im]Duino
« Reply #23 on: February 26, 2009, 09:11:12 PM »
@ wan
dumating na sir yung binili nyo?  :D
di naman po talaga nagbebenta sir, board lang po talaga yung binebenta namin.
madali lang sya sir gamitin.. kayang kaya po pag-aralan ng mga beginner na kagaya ko.. kung may prob naman kayong maencounter, post nyo dito or text nyo ko, ayusin natin..  :D :D :D
Offline [J]sil
    • Novice Tinker
« Reply #24 on: February 26, 2009, 09:45:43 PM »
Masmadali pa siya sa pagsusulat ng ABC (prefer ko kasi mag type  ;D)
    • [im]Duino
« Reply #25 on: February 26, 2009, 10:00:58 PM »
hehehe.. tinatamad pala magsulat.. type pala ang gusto.. :D
Offline Pupil
« Reply #26 on: February 27, 2009, 10:01:01 AM »
ah.. madali lang po ba talaga to? mas madali sa PIC?
    • [im]Duino
« Reply #27 on: February 27, 2009, 09:03:09 PM »
LED blink palang na-try ko sa PIC.. tapos simulation lang.. so diko masasabi.. pero madali lang naman gamitin tong [im]Duino..  :D
Offline [J]sil
    • Novice Tinker
« Reply #28 on: March 03, 2009, 04:18:40 AM »
Help! Nabibitin ata sa power yung mga connected components ko. Ganito ang setup ko
yung triplets sa kaliwa, mga proximity sensor ng e-gizmo, ok sila kung isa-isa pero pag nakakabit na ang tatlo wala na ayaw na makadetect ng obstacles. Yung dalawa sa kanan eh mga motor drivers, so far wala pa naman akong problem with regards to those.
Yung isa sa baba ay yung para sa long range IR sensors, hindi pa finalized :/
Anong pwede kong gawin para hindi kulangin yung supply sa mga sensor? Connected sila sa 5V pins ng [im]duino.
« Reply #29 on: March 03, 2009, 09:49:32 AM »
Use a seperate regulator. Use 7805 instead
    • [im]Duino
« Reply #30 on: March 03, 2009, 09:33:30 PM »
tama si sir malditah13..  :)
baka di napo kaya ng supply ng [im]Duino Board yung mga nakakabit sa kanya.. 7805 lang kasi gamit ng [im]Duino, yung 7805, 1A lang kaya nya isupply.. baka lumalagpas na sa 1A yung dino-draw na current ng mga nakakabit sa kanya. try nyo sir ihiwalay yung supply ng 3 sensors nyo..   :D
Offline [J]sil
    • Novice Tinker
« Reply #31 on: March 04, 2009, 09:48:49 PM »
Ok, so try ko siguro gumawa ng connector circuit na may 7805 tapos tap sa same battery.
    • [im]Duino
« Reply #32 on: March 04, 2009, 09:54:48 PM »
pwede din sir..  :)
Offline [J]sil
    • Novice Tinker
« Reply #33 on: March 06, 2009, 10:20:51 PM »
Weak pala ang output ng gamit kong batteries XD, either kumuha ako ng rechargable na mya masmataas na mA rating or mag parallel (suggested from gizmo)
    • [im]Duino
« Reply #34 on: March 06, 2009, 11:18:00 PM »
mas mataas na mA-hour rating, mas maganda.. saka kung magpaparallel sir, dapat same rating..  :)
Offline [J]sil
    • Novice Tinker
« Reply #35 on: March 08, 2009, 10:23:41 PM »
Its alive! kaso umiksi from 6 inches to 3 inches na lang ang detection range ng obstacle detector modules ko. Hmmm ano pa kaya ang pwedeing idagdag
    • [im]Duino
« Reply #36 on: March 08, 2009, 10:33:24 PM »
umiksi? medyo di ako pamilyar sir sa module nyo eh.. ano po ba yung nakaka-apekto sa kanyang range detection?
Offline [J]sil
    • Novice Tinker
« Reply #37 on: March 09, 2009, 09:01:16 PM »
Yun module n e-Giszmo na obstacle detector, bale kasi pag isa lang nakakabit sa [im]duino umaabot ng 6inches sa detection range, pero pag 3 na nakakabit nagiging 3-4 inches na lang
    • [im]Duino
« Reply #38 on: March 09, 2009, 09:07:30 PM »
ah.. baka kelangan ng mas mataas na current para sa mas malayong detection..
Offline ajak
  • Pogi/Ganda Points: 50
« Reply #39 on: March 09, 2009, 11:10:32 PM »
Sir, try mong bawasan ung value ng resistor nandun sa picture... experiment mo,..
