Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
Electronic Appliances/Devices Repair (Electronics Technician Forum)
Television Repair
Sony Televisions
sony kv-14apx1 one blink lng wont start up
« previous
next »
Print
Pages: [
1
2
3
4
Go Down
Author
Topic: sony kv-14apx1 one blink lng wont start up (Read 5795 times)
flatlander2john
Size AAA Battery
Pogi/Ganda Points: 2
on:
February 15, 2009, 01:07:05 PM »
di mag start up yung unit pero may blink na isa.. ask din po kung ano value ng R622 kasi sunog 1/4 watt
Logged
on:
flatlander2john
Size AAA Battery
Re: sony kv-14apx1 one blink lng wont start up
Reply #1 on:
February 17, 2009, 01:30:51 PM »
ok ung b+ at h out may 115 volts pero may mga land marks sa flyback na 180v na 115 lng ang inilabas at 800 volts 102v lng
Logged
Reply #1 on:
Tasyo
Size D Battery
Pogi/Ganda Points: 39
Reply #2 on:
February 17, 2009, 02:37:16 PM »
sir walang oscillation yang horizontal mo kaya ganyan lang nasusukat, yung sunog na R622 napalitan mo na ba? bili ka muna sa raon diagram para makita mo kung ano value nya, update mo ako pag napalitan mo
Logged
Reply #2 on:
flatlander2john
Size AAA Battery
Reply #3 on:
February 17, 2009, 08:07:46 PM »
boss ok napalitan ko na 100 k ang value taga mindanao ako. one blink pa rin ayaw mag start up. di kaya flyback ang sira? ganun pa rin ang reading sa mga landmarks.
Logged
Reply #3 on:
Tasyo
Size D Battery
Reply #4 on:
February 17, 2009, 09:02:45 PM »
sir ano Jungle nyan CXA1213 ba sorry forget ko na, kung di ako nagkamali 1992 model yata yan. Mindanao lapit lang yan di na kelangan passport para punta manila
patingin nalang ng jungle sir hanap natin ka series dito.
Logged
Reply #4 on:
flatlander2john
Size AAA Battery
Reply #5 on:
February 19, 2009, 10:37:34 AM »
boss cx 20192 ang jungle ic. check ko na jungle ic from pin 15-28 ata walang voltahe na lumalabas.
Logged
Tasyo
Size D Battery
Reply #6 on:
February 19, 2009, 12:50:21 PM »
sorry sir wala ako kaparehas na model na gumagamit ng ganyang jungle, baka pwedi pa post yung schematic, anyway try mo itong mga moving parts sa model na yan.
KV-14APX1 124494100 RESISTOR,CARBON; 680K 1/2W REPLACEMENT 7.85%
KV-14APX1 874990083 IC STR50115A REPLACEMENT 7.69%
KV-14APX1 120284600 RESISTOR, SOLID 470K 1/2W REPLACEMENT 6.75%
KV-14APX1 110767991 CAPACITOR,ELCT 10MF/450V REPLACEMENT 5.65%
KV-14APX1 123064111 RESISTOR,ADJ,METAL GLAZE 2.2M REPLACEMENT 4.08%
KV-14APX1 146447851 IF BLOCK (IFB-450A) REPLACEMENT 3.92%
KV-14APX1 RES470K1W REPLACEMENT 2.98%
KV-14APX1 871930349 DIODE R2M REPLACEMENT 2.83%
KV-14APX1 112746500 CAPACITOR,10MF,ELECT REPLACEMENT 2.51%
KV-14APX1 RES680K1W REPLACEMENT 2.35%
KV-14APX1 154419011 SPEAKER (5X9) REPLACEMENT 2.20%
KV-14APX1 112302400 CAPACITOR,ELECT 33MF/160V(85C) REPLACEMENT 2.20%
KV-14APX1 112387200 REPLACEMENT 2.04%
KV-14APX1 110796111 CAPACITOR ELECT 10MF/250V REPLACEMENT 1.88%
KV-14APX1 RES470K1WA REPLACEMENT 1.88%
KV-14APX1 143942121 REPLACEMENT 1.73%
KV-14APX1 110766111 CAPACITOR, ELECT 10MF/350V REPLACEMENT 1.73%
KV-14APX1 110766211 CAPACITOR, ELECT 22MF/350V REPLACEMENT 1.73%
KV-14APX1 124652100 REPLACEMENT 1.41%
KV-14APX1 157143311 SWITCH,PUSH (AC POWER) REPLACEMENT 1.26%
KV-14APX1 RES680K1WA REPLACEMENT 1.26%
KV-14APX1 REPLACEMENT 1.10%
KV-14APX1 ELECTRICAL ADJUSTMENT 1.10%
KV-14APX1 111939100 CAPACITOR,ELECT 250V 22MF REPLACEMENT
Logged
flatlander2john
Size AAA Battery
Reply #7 on:
February 19, 2009, 05:42:41 PM »
boss ano po ibig sabihin nito? (KV-14APX1
112387200
REPLACEMENT 2.04% ) sorry baguhan lng po
Logged
flatlander2john
Size AAA Battery
Reply #8 on:
February 19, 2009, 05:44:48 PM »
thanks for the info boss..........try ko lng yong info
Logged
Tasyo
Size D Battery
Reply #9 on:
February 19, 2009, 05:51:34 PM »
standard part number ng sony yan sir, focus ka doon sa value wag dyan sa part number every part number may corresponding part value sya
yung 9 digit number is the part number for a 680K carbon resistor yung percentage naman sa dulo yan yung frequency kung gaano sya kadalas masira sa certain model
Logged
flatlander2john
Size AAA Battery
Reply #10 on:
February 20, 2009, 01:29:16 PM »
boss ask lng po. may 284 volts po lalabas sa str 50112 pin 3? tnx
Logged
Tasyo
Size D Battery
Reply #11 on:
February 20, 2009, 01:58:29 PM »
Sir yung 284 volts sa pin 3 is Unreg pa yan, pag check nyan is yung pin 123 ng STR mo ( 50115 ) like CBE ng transistor ngayon kung may short in any combination probably sira sya, now merong R2M yan sa secondary paki check sa cathode nya kung may 115 volts if ever meron malamang okey yung supply mo, pag OK check mo yung supply ng 20192 which I think 9 volts kung meron baka pwedi paki picture yung section ng 20192 kalimutan ko na kasi pin configuration nyan.
Logged
flatlander2john
Size AAA Battery
Reply #12 on:
February 20, 2009, 02:17:22 PM »
boss walang lumalabas na voltahe sa pin 3 tapos yung Q503 walang 115 volts sa base.
Logged
flatlander2john
Size AAA Battery
Reply #13 on:
February 20, 2009, 02:26:14 PM »
Q601 po pala.,
Logged
Tasyo
Size D Battery
Reply #14 on:
February 20, 2009, 03:01:11 PM »
Meron bang B+ na 115 sir?
Yung Q601 yan ba yung TO220 type na kulay green/Black sa power supply, try mo tanggalin yan kasi by experience kahit wala yan tatakbo yung TV. filter lang sya. paki check mo na din 470K or 680K dyan sa power supply ( 1/2 watt ) madalas sirain yan.
Logged
flatlander2john
Size AAA Battery
Reply #15 on:
February 20, 2009, 06:17:46 PM »
pinalitan ko na ng 470 k boss wala pa rin. may 115 volts sa b+, h out, pati sa regulator. yung r2m na diode ok yun may 115 volts.... di kaya flyback sira nito....?
Logged
Tasyo
Size D Battery
Reply #16 on:
February 20, 2009, 07:24:25 PM »
mostly sir pag Flyback yung sira nag lload sa B+ yung symptoms, unless siguro kung open yung winding, anyway subukan mo actual, now kung may scope ka check mo kung may start up yung oscillation ng horizontal, mamaya baka di nag lalabas ng H-pulse yung 20192 mo.
Logged
flatlander2john
Size AAA Battery
Reply #17 on:
February 21, 2009, 10:33:42 PM »
boss tinanggal ko na lng yung flyback. itinitest ko walang high volatge na lumalabas sa red wire na cap. ni check ko na rin yun junle ic walang 9 v din na supply.
Logged
Tasyo
Size D Battery
Reply #18 on:
February 22, 2009, 08:36:27 AM »
focus ka muna sir sa jungle kaya wala kang high voltage kasi nga di tumatakbo jungle mo, paki post diagram kung meron ka mahirap kasi manghula
Logged
flatlander2john
Size AAA Battery
Reply #19 on:
February 25, 2009, 09:47:00 AM »
boss ito na ang diagram sana maayos ko na to. thanks sa 2long.
Logged
Reply #19 on:
Print
Pages: [
1
2
3
4
Go Up
« previous
next »
Television Repair
Sony Televisions
