Author Topic: Proton Picbasic Tutorial  (Read 26870 times)
« on: February 16, 2009, 10:57:04 PM »
Muli kong ibabalik ang tutorial na ito sana gawing sticky ng mga mod. I'll start this tomorow.
Offline ajak
  • Pogi/Ganda Points: 50
Re: Proton Picbasic Tutorial
« Reply #1 on: February 17, 2009, 08:21:10 AM »
sir marami ako itatanong ah.. para mas matuto pa ako sa basic.. salamat..
« Reply #2 on: February 17, 2009, 11:13:46 AM »
Instead of going back sa basic magsisimula na lang ako ng isang project na we can use. I'll start with the schematic
« Reply #3 on: February 17, 2009, 11:19:38 AM »
First code to try.
' Check PortB bit 0-3 and output it to PortD bit 0-3
   Device 16F877         ' Declare Device
   XTAL = 20          ' Use a 20MHz crystal
   ALL_DIGITAL = TRUE      ' Set analog pins to digital
   Input PORTB         ' Define PortB as input
   Output PORTD         ' Define PortA as output
   Clear PORTD         ' Clear Port A
LOOP:    PORTD.0   = PORTB.0      ' PortA.0 state same as PortB.0
   PORTD.1   = PORTB.1      ' PortA.1 state same as PortB.1
   PORTD.2   = PORTB.2      ' PortA.2 state same as PortB.2
   PORTD.3   = PORTB.3      ' PortA.3 state same as PortB.3
   DelayMS 100         ' Delay 100mS (Debounce)
   GoTo LOOP         ' Check input forever
Offline colot
  • "ahhhhhh, wala akong masabi...."
« Reply #4 on: February 17, 2009, 11:44:25 AM »
First code to try.
sir ung portD eh nagiging port A sa comment........
oo nga po sir nawala ung mga post nyo na tutorial noon d2,...tnx po sa pag restart ng tutorial na to...
« Reply #5 on: February 17, 2009, 11:48:34 AM »
sorry di ko pala nabago comment
Offline ajak
« Reply #6 on: February 17, 2009, 08:40:55 PM »
Sa mga gusto magsimula ng Proton Picbasic Programming
1D96b^S328)S759T05)>[<
-:=@^TWB&6248.*B*S,?2T/91+<^[]`aTV[dSuz~xtv/$3*>:'5/z+;/W%[/T%]/f¶
+=1R6-6R.==1
2 ito na executable file na nakapackage into 1, pr0t3us at proton na. wag nio na lang idagdag un kung meron na kau pr0t3us.
Me kasama na tong pdf file...
Offline arv_papo
« Reply #7 on: February 18, 2009, 08:16:46 PM »
bossing, more pa po. hehe
Offline ajak
« Reply #8 on: February 18, 2009, 08:23:26 PM »
Basahin po natin ung proton manual para macacatch up tau sa tutorial, me mga sample dun every command/syntax ng proton.. Ung pinost ko above andun un manual..
Offline arv_papo
« Reply #9 on: February 18, 2009, 09:12:44 PM »
ok po, tanx po pala..
« Reply #10 on: February 19, 2009, 10:32:32 AM »
Serial Interface na isusunod ko. Eto ang diagram using max232
« Reply #11 on: February 19, 2009, 10:57:24 AM »
code:
' Device declaration
        Device 16F877              ' Produce code for a 16F877
        TRISC = %00000001                        ' Set PortC to output except PortC.7
        Output PORTD                                ' Set PortD to output
' Declaration of serial communication
        Declare HSERIAL_BAUD  = 9600                  ' Set baud rate to 9600,19200,38400,57600,115200
        Declare HSERIAL_RCSTA = %10010000       ' Enable serial port and continuous receive
        Declare HSERIAL_TXSTA = %00100000       ' Enable transmit and asynchronous mode
        Declare HSERIAL_CLEAR = On         ' Enable Error clearing on received characters
' Declaration of variables
        Dim BUFFER  As Byte           ' General storage
        DelayMS 200              ' Wait to stabilize
        Clear PORTD            ' Put Port B to low
MAIN:HSerIn 300,TOUT,[Wait("T"),BUFFER]       ' Received data
        PORTB = BUFFER          ' Output received data to Port D
        HSerOut ["INPUT: ", Dec BUFFER,13]        ' Transmit the decimal value of Buffer and carriage return
TOUT:   GoTo MAIN         ' Back to main program
Offline magike
« Reply #12 on: February 20, 2009, 09:11:53 PM »
+=1R6-6R.==1
sir, anu po ulit un key n gngmit pra madecode??
Offline ajak
« Reply #13 on: February 20, 2009, 11:24:47 PM »
pm po kita.. check it how..
Offline Mayalin22
  • Pogi/Ganda Points: 400
« Reply #14 on: March 09, 2009, 03:37:04 PM »
+=1R6-6R.==1
Sir I am very much interested in basic programming. Nabuboryong na kc ako sa assembly.. baka pd po madownload..
« Reply #15 on: March 09, 2009, 04:11:25 PM »
use the encrypted link
http://www.seabreezecomputers.com/encrypter/
key: elab
Sir i'm willing to assist kung may tanong ka post mo lang sa thread ko pra masagot ko agad.
Offline Mayalin22
« Reply #16 on: March 09, 2009, 06:07:56 PM »
salamat po  :-*... nadownload ko na PDF file... ung program po pano pag-download kelangan pa po ba mag-register? ... sobra excited ko ehe he he  ;D
Offline ajak
« Reply #17 on: March 09, 2009, 10:52:24 PM »
meron dun sa napost ko na link ng program, tapos open mo yun, tapos sa may upper left meron dung request download na link click mo un, tapos download..  no need to register..
Offline Mayalin22
« Reply #18 on: March 10, 2009, 10:54:18 AM »
Tenchu! Working na po.  ;)
Offline Mayalin22
« Reply #19 on: March 10, 2009, 12:34:59 PM »
Mga sister ano ba magandang plugin para dito sa proton? Try ko na ang program medyo nangangapa pa  :(
