Author Topic: madalas ba kayong na-virus ? virus na galing sa usb  (Read 17349 times)
Offline madeline07
  • **madeline**
Re: madalas ba kayong na-virus ? virus na galing sa usb
« Reply #20 on: February 23, 2008, 02:51:08 PM »
eh panu naman po pag nabura ung.vbs script file??? wat po gagawin??? d ko kc ma open ung C ska ung Usb ko eh???
"Like a shooting star, I will go the distance"
« Reply #21 on: February 23, 2008, 03:22:30 PM »
right click nyo na lang then explore.
Offline madeline07
  • **madeline**
« Reply #22 on: February 23, 2008, 03:42:33 PM »
Ayaw nya pa rin po mag open eh....
Offline clarkent
  • Pogi/Ganda Points: 20
  • iehs
« Reply #23 on: February 23, 2008, 03:56:44 PM »
try mo kayang irestart.
Offline madeline07
  • **madeline**
« Reply #24 on: February 23, 2008, 04:05:31 PM »
ok try ko....
Offline creedcradle
  • Pogi/Ganda Points: 19
  • I'm living beneath the undeground, come with me!
« Reply #25 on: February 23, 2008, 04:15:50 PM »
Uy! atake na naman ang brontok.. trojan gawa ng taga indonesia yan... 14 years old lang.. yan ang nakuha kung traces sa mga gawa niya... medyo mayabang kasi yang batang yan kaya may text na "Embrace Islam or you will die.." na ksama sa trojan files na yan..
nga pala at worst case, pagne-restart mo ang pc, mag HALT yan sa boot process kasi pinapagana niya ang program before log-on screen.. malupit din talaga yan...
as much as possible work your troubleshooting sa safe mode with networking...
1. remove all traces/processes bago mo gawin ang .bat file na eexecute mo...
2. delete this file c:\windows\shellnew\ , tapos view hidden files, lahat ng hidden files delete mo
3. go to start up menu, tanggalin mo lahat ng di mo kilalang start up items...
4. go to c;\windows\temp -delete mo lahat ng laman dito
5. search for the file na tinanggal mo sa start up , then delete it..
-creedcradle
-creedcradle
LEARN TO SHARE and SHARE TO LEARN!
'BE A GOOGLER & WIKIMAN
Offline mArKhAo
  • Pogi/Ganda Points: 70
  • point and shoot
« Reply #26 on: February 23, 2008, 07:20:29 PM »
deep freze
Offline Siramiko
  • Pogi/Ganda Points: 35
  • thank you elab
« Reply #27 on: February 23, 2008, 08:56:50 PM »
punta ka ng dos prompt,
start -> run enter
type cmd.exe
then type
cd\
attrib -h -r -s autorun.inf
ren autorun.inf autorun.txt
notepad autorun.txt
yung .exe, .vbs file na nakalaman sa autorun.txt ,searh mo tapos delete
I shall return
Offline krayziebone
  • Pogi/Ganda Points: 9
« Reply #28 on: February 24, 2008, 02:51:55 AM »
may ginawa akong prevention at removal tips..
baka makatulong..  ;D ;D ;D
http://xhien.net/
Offline toasted siopao
  • Global Moderator
  • Pogi/Ganda Points: 107
    • TeknoBlogger
« Reply #29 on: February 24, 2008, 10:36:12 AM »
Di ako madalas magkavirus pero madalas makadetect ako na galing sa USB.
Offline bbench
  • Pogi/Ganda Points: 13
  • :) :D :D :D :)
« Reply #30 on: February 24, 2008, 10:47:21 AM »
opo jujuju pano po kasi ung comp.lab. sa school kung anu anung virus ang nakalagay d manlang ireformat ang mga comp  :'( buti nlng andyan c parameterx para iscan ang mga usb namin jejeje thnx tol!  :)
bench!
Offline WildSwan
  • Addicted to solder flux.
« Reply #31 on: February 28, 2008, 12:37:22 PM »
This is what I do...
No need to dissable auto-play.
We must understand that the only way for any virus na kumalat via USB is to be able to AUTORUN. so how does a virus does this? It creates autorun.inf. Basically, laman nitong file na ito is a call to a hidden executable file na nasa USB. Once it run, the virus attaches itself sa OS. So kahit  idelete mo yung autorun.inf, walang use. Since active na sya, all it needs to do is write the autorun.inf file sa USB device.
The file has the following attribute +H +S +R... so hindi mo ito makikita sa explorer. Pero you can access it directly and in read-only mode.
Itong tip ko, effective ito kung hindi ka pa infected. Once you do this, it is guarenteed na hindi magkakaron ng chance na mainfect/maka infect USB mo. The virus may still be able to copy itself sa USB mo, pero it will never be able to run.
Tama na kwento. Follow this steps:
1. go to DOS prompt or command promt.
2. go to your USB drive.
3. type "MD autorun.inf" without the qoutes.
4. type "CD autorun.inf" without the quotes.
5. type "COPY CON protect.txt" without the quotes.
6. press enter key
7. press F6
8. press enter key, you should see 1 file(s) copied message.
9. type "ATTRIB +H +R +S protect.txt" without the quotes.
10. type "CD\" without the quotes.
11. type "ATTRIB +H +R +S autorun.inf" without the quotes.
You are done. Basically, you have created an autorun.inf directory. It is hidden, systemized and read-only. There is no way now that anything can be able to create autorun.inf file in your USB. The file protect.txt inside the autorun.inf directory is just there to make sure that the autorun.inf directory will never be deleted.
HTH.
« Reply #32 on: April 29, 2008, 05:58:54 AM »
hope my kaizer killer can help you =)
 ;D ;D ;D
http://www.freewebs.com/gigz_09/kaizer_killer.rar
Offline drx2k
  • Pogi/Ganda Points: 15
    • Drx2k Network
« Reply #33 on: July 16, 2008, 07:06:45 PM »
deep freze
yah, deepfreeze lang ang katapat nyan, kahit walang antivirus yung PC mo, basta naka freeze yung drive, di naman kasi tulad ng ibang virus yung vbs script virus na kumakapit sa boot sector ng hdd. kahit mag propagate yung .vbs virus sa naka-freeze na hdd, pag restart na PC wala na yan.
saka nasa pag iingat di naman yan, wag kasi basta-basta mag open ng flash drive para di ma-infect ng virus
Offline gatasngpusa
  • this is what pirates are doing
« Reply #34 on: July 31, 2008, 12:27:48 AM »
6. press enter key
7. press F6
HTH.
how to disable autorun?
and also how to get to usb drive using Dos like what you stated in number 2?
Offline 'yus
  • Pogi/Ganda Points: 299
  • hw -> fw -> sw
    • yus' projects
« Reply #35 on: July 31, 2008, 07:50:22 AM »
one way is to use yung TweakUIXP na nasa control panel:
Offline gatasngpusa
« Reply #36 on: August 01, 2008, 08:37:03 PM »
thanks,then what is the answer to the other question?
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
« Reply #37 on: August 01, 2008, 09:40:12 PM »
..then what is the answer to the other question?
yung using DOS? ???
open mo lang yung command prompt, then type mo lang yung drive letter ng USB drive mo, the colon..
for example, drive E ang naka-assign sa USB mo,
type mo lang sa command prompt: E: then press Enter
Offline Ugin
  • Pogi/Ganda Points: 48
« Reply #38 on: August 01, 2008, 09:57:25 PM »
Try to use this one. Tried and tested:
http://www.mediafire.com/?eyj9cwcjyty
Offline zaki
« Reply #39 on: August 05, 2008, 09:26:57 PM »
pano po ba to?...
lahat ng file microsoft word pag inopen ko nagkakaron ng duplicate tapos nawawala din?...
hindi  madetect ng antivirus ko...
pano po ba matatanggal to?...HELP.........
