Author Topic: Need help! Pcb layout, schematic diagram for audio power amplifier  (Read 17474 times)
Offline bluegirl
  • Pogi/Ganda Points: 7
  • ..........me..........
    • author lang aq dito
Uses 4 transistors with the same values, class AB, Vcc between 12-25 volts, load impedance eider 4 or 8, result sana ay 30 watts... Sana may ma recomend po kayong transistor at sana available po sa stores
“Mathematics is made of 50 percent formulas, 50 percent proofs, and 50 percent imagination.”
Offline beginner wan
  • Pogi/Ganda Points: 46
    • [im]Duino
Re: Need help! Pcb layout, schematic diagram for audio power amplifier
« Reply #1 on: February 18, 2009, 11:41:04 PM »
« Reply #2 on: February 18, 2009, 11:57:33 PM »
avoid multiple thread.
This topic should be on PCB section.
Oh please, post the schematic.
Offline bluegirl
« Reply #3 on: February 19, 2009, 12:58:15 AM »
sensya na po. Urgent lng tlga. Wla pa din po aq schematic eh
« Reply #4 on: February 19, 2009, 08:49:42 AM »
paano gagawin yung pcb kung walang diagram?
Offline danny
  • Pogi/Ganda Points: 323
« Reply #5 on: February 19, 2009, 10:48:09 AM »
masyado nang paulit ulit ang post nito
tapos sa ibang post kulang kulang ang specs.
it seems na talgang wala siyang diagram or nde pa
nakaka design, its not easy to design an amp
in a snap together with the pcb.
sana nasimulan na niya ito noon pa
para nde ganitong nag mamadali. :) ;)
danny
Offline bluegirl
« Reply #6 on: February 19, 2009, 01:15:18 PM »
yun nga prob eh kami pa ang pinapahanap ng sir namin ng diagram. Sa intrnet naman wla masyado aq makita samples na 4 yung transistor. Tapos individual pah...
Offline bluegirl
« Reply #7 on: February 19, 2009, 01:18:08 PM »
Pasenxa na po. Last wik lng kasi sinabi eh pati specs na binigay yun lng tlga...
« Reply #8 on: February 19, 2009, 02:00:04 PM »
http://sound.westhost.com/project27.htm
replace mo nalang ang preamp.
« Reply #9 on: February 19, 2009, 02:12:01 PM »
nga pala, have you googled this thing?
eto pa: http://www.ee.washington.edu/circuit_archive/circuits/km241.html
Offline bluegirl
« Reply #10 on: February 19, 2009, 04:42:28 PM »
4 transistors ba ang gamit dun? mas madali ata ung guitar power amplifier kaysa na una na pre amp
Offline bluegirl
« Reply #11 on: February 19, 2009, 04:46:13 PM »
panu po maging readable yung ps file galing sa syt na binigay mo? .ps file po xa
« Reply #12 on: February 19, 2009, 06:59:18 PM »
actually 6 nga na ang ginamit. dalawang drivers at 2 pairs na output transistors.
BD139 and BD134 are the drivers for transistors TIP36c and TIP35c. Tigdadalawang TIP36 and TIP35 to double the power produced. pero pwedeng tig-iisa lang. it shall provide half of power.
« Reply #13 on: February 19, 2009, 07:06:15 PM »
PS can be opened by adobe distiller. It shall result to PDF.
eto, i manage to extract it.
http://depositfiles.com/files/7dguqgy4x
Offline bluegirl
« Reply #14 on: February 19, 2009, 07:22:27 PM »
ah.. pwede 4 transistors ang gamitin q dun with the same values ng transistor? yun kasi sabi ng prof. q eh
Offline bluegirl
« Reply #15 on: February 19, 2009, 07:24:37 PM »
dami pong transistor.. sana may iba po kayo maibigay na schematic na 4-6 transistors lang po
« Reply #16 on: February 19, 2009, 08:50:19 PM »
honestly, i am not good with amplifiers. especially with these discrete types. pero, theoretically, i think you need several stages to amplification.
di lang yan isang level, at amplified na kaagad. Even if you look deep into the internals of those IC audio amplifiers.
Can you provide a more specific requirements?
Sige, i'll try to help.
Offline danny
« Reply #17 on: February 20, 2009, 11:30:05 AM »
well ang mabuti pa
booster na ang ang gawin mo.
iyon patok yun pwede apat na transitor doon same value
siguro naman, iyan ang hinahanap ng prof mo hehhe
12V din supply, may transformer nga lang.
what do u think? :)
danny
Offline Woots29
  • Pogi/Ganda Points: 344
  • asan si mojacko?
    • Woots Page
« Reply #18 on: February 20, 2009, 11:35:36 AM »
tama si sir danny booster na lang
kasi un lang talaga ang desgn na alam ko na pwedeng 2 o apat ang transistor
wel according to ur specs swak un
yhadz class AB diba?  un na un booster hehe  ;D
WootsPC2 Videos  Woots Page
« Reply #19 on: February 20, 2009, 11:43:36 AM »
yan din ang duda ko kaya sya nadadamihan sa transistors... hehehe  ;D
