Author Topic: Need help! Pcb layout, schematic diagram for audio power amplifier  (Read 17524 times)
Offline bluegirl
  • Pogi/Ganda Points: 7
  • ..........me..........
    • author lang aq dito
Re: Need help! Pcb layout, schematic diagram for audio power amplifier
« Reply #80 on: February 24, 2009, 11:13:16 PM »
ilang amps ba kaya ng TIP42? nasa 2.83A ang peak current na dadaan sa transistor.
Ic=6A continuos, 10A peak... Ib=2A
“Mathematics is made of 50 percent formulas, 50 percent proofs, and 50 percent imagination.”
Offline THXneo
  • Pogi/Ganda Points: 34
  • DJ, Home Theater Fanatic
« Reply #81 on: February 25, 2009, 09:30:04 AM »
check mo post d2 sa forum:
http://www.electronicslab.ph/forum/index.php?topic=468.msg4646#msg4646
mj2955 boosterized.
parallel mo 4 n2
kailngan mo lng e specs ng input at output x-former.
nag dedepend kc sa wattage yan.
meron 50-100 hnggang 400 watts
pero pareho pa rin schematics nyan
More to Lose by Seona Dancing
Offline bluegirl
« Reply #82 on: February 25, 2009, 10:10:44 AM »
mj2955 boosterized.
parallel mo 4 n2
eh yung TIP42A na po yung transistor anu  gagamitin q eh tapos 4 na ganun... Anu rin po bagay transformer na gagamitin q?
Offline THXneo
« Reply #83 on: February 25, 2009, 10:42:13 AM »
ganon din.
dapat kng 100watts balak mo. 100watts din rating ng audio input at output transformer.
Offline bluegirl
« Reply #84 on: February 25, 2009, 12:56:20 PM »
ganon din.
yung output 30 watts rms pinapakuha nung prof namin eh
Offline THXneo
« Reply #85 on: February 25, 2009, 01:10:12 PM »
meron din. 50watts rated na audio transformer pero nasa 30watts rms un o kya gawa ka ng sarili mo winding
madali lng nman ito.bili ka book sa national.meron dun "how to rewind at preaker rewinding"
lahat ng details paggawa regarding sa audio transformer nandun.
Offline bluegirl
« Reply #86 on: February 25, 2009, 01:17:51 PM »
yun nga prob q eh d pa aq maxado magaling
Offline danny
  • Pogi/Ganda Points: 324
« Reply #87 on: February 25, 2009, 01:46:25 PM »
paps si yhanz yung nangangailangan ng booster diagram
may schematic na siya
galing kay woots
value na lang
ng resistors need niya saka mga transforemer
danny
Offline danny
danny
Offline THXneo
« Reply #89 on: February 25, 2009, 02:36:06 PM »
di nman kailngan magaling eh.
meron nman do's at dont's doon.
pero kng ayaw mo talaga meron jan sa deeco mga audio transformer.
but remember. iba ang input transformer sa output transformer ha?
Offline bluegirl
« Reply #90 on: February 25, 2009, 02:38:37 PM »
opo.. maliit po yung isa
Offline THXneo
« Reply #91 on: February 26, 2009, 10:03:29 AM »
nope! pag rated na 50 watts and below same lng ang size ng input at output transformer na bini-benta.cguro ang sukat ng E-I: 30mm x 30mm x 30mm
di pwede ung pang radyo,ung kulay red at blue
« Reply #92 on: February 26, 2009, 11:08:25 AM »
^actually, nalito din ako nung nabasa ko post nya.
naalala ko kasi, magkapareho talga ang size. Pero may label naman... as "input" and "output".
Offline bluegirl
« Reply #93 on: February 26, 2009, 12:08:45 PM »
kuya, yung sa transformer pwede  lang ba yung isang transformer yung primary lang o dapat primary with secondary???
Offline THXneo
« Reply #94 on: February 26, 2009, 01:23:33 PM »
ngeek! ang tinutukoy natin d2 ay ang audio transformer
2 yan.
1 sa input
1 sa output
tingnan mo sa diagram na binigay sa u d2 sa forum.
iba pa ng transformer para sa power supply
Offline bluegirl
« Reply #95 on: February 26, 2009, 01:29:33 PM »
kasi po yung mga binibenta sa store po eh iba yung input sa output.. tapos yung isa po maliit na transformer den yung isa po eh malaki eh... sabi naman nung may ari ng store yun naman daw ang pang booster or amplifier
Offline THXneo
« Reply #96 on: February 26, 2009, 01:35:24 PM »
punta ka sa deeco. dun sa wholesale area. dmi dun x4rmer na nakalagay lng sa baba.
meron yan nakasulat na audio transformer. ang input side meron primary at secondary
ang output mag dedepend sa u kng gusto mo auto o pipili ka sa 50-70.7 o 100 volt line-wla ito series winding na ito.wala primary o secondary
Offline bluegirl
« Reply #97 on: February 26, 2009, 01:36:34 PM »
hehehe.. sa cebu po yung location q kuya eh....
pwede po magpost ka dito ng pics ng audio transformer para ma compare q dunsa bibilhin q.. tnx
« Reply #98 on: February 26, 2009, 01:51:00 PM »
punta ka lang ng electronics shop at hingi ka nung input and output booster transformers for 50Watts...  alam na nila yan. you don't have to compare it. kapagnakita mo na yan, alam mong yan na.
Say it in bisaya, mas madali! heheh ;D
Offline bluegirl
« Reply #99 on: February 26, 2009, 01:54:57 PM »
yun na nga gagawin q... last question po.. yung output po na transformer, ang bibilin q po ba yung may primary and secondary or pwede yung primary lang? kasi sabi ng nagbebenta pwede daw yung primary lang eh.... ask q lang po sa inyo wat ang babagay dun sa project q...
