Author Topic: interfacing LCd and Keypad to PIC16f877a  (Read 4046 times)
Offline auditory
« on: February 23, 2009, 10:21:54 PM »
mga boss, pwede po ba mag paturo kung pano mag interface ng lcd and keypad sa pic16f877a, newbie lng po kasi kami sa PICmcu.. we tried constructing our own circuit kaso puro blocks lng po ung display ng lcd nmin.. salamat po
  • Pogi/Ganda Points: 630
Re: interfacing LCd and Keypad to PIC16f877a
« Reply #1 on: February 23, 2009, 10:31:25 PM »
post niyo rito 'yung schematic niyo baka naman 'yung program ang problem.
« Reply #2 on: February 23, 2009, 10:32:43 PM »
o kaya gamitan nyo ng proteus simulation...
Offline jerzclanx
  • Pogi/Ganda Points: 14
  • "Mr. Incognito"
    • personal website
« Reply #3 on: February 23, 2009, 10:35:49 PM »
check nyo po yung pin 3 ng LCD (Contrast)
adjust nyo po yung contrast sa Potentiometer.  ;)
Offline ajak
  • Pogi/Ganda Points: 50
« Reply #4 on: February 23, 2009, 11:15:44 PM »
Offline auditory
« Reply #5 on: February 23, 2009, 11:26:49 PM »
tnry ko po sa proteus, gumagana po siya kaso pag sa hardware na po, puro box lng po ang nagdidisplay..
« Reply #6 on: February 23, 2009, 11:27:39 PM »
pwedeng 'yung contrast nga.
Offline toasted siopao
  • Global Moderator
  • Pogi/Ganda Points: 107
    • TeknoBlogger
« Reply #7 on: February 23, 2009, 11:35:33 PM »
Adjust the contrast. Kung nag work sa proteus, chances are mag work rin yan sa actual.
Offline Ugin
  • Pogi/Ganda Points: 48
« Reply #8 on: February 23, 2009, 11:45:08 PM »
What model of LCD are you using?? Is this the SC162a from digitron??
« Reply #9 on: February 24, 2009, 04:22:26 AM »
post your schematic
Offline auditory
« Reply #10 on: February 24, 2009, 06:40:22 AM »
e2 po ung sa proteus na schematic.. ung lcd po namin is ung 4x20 na lcd po from e gizmo..
« Reply #11 on: February 24, 2009, 08:12:27 AM »
wla ka talaga variable resistor sa pin 3? dpat kasi meron yun para sa contrast.
Offline jerzclanx
  • "Mr. Incognito"
    • personal website
« Reply #12 on: February 24, 2009, 08:20:31 AM »
sis Maldita13 nu oras ka nakauwi??  ;)
ayan.. gaya ng sabi nila.. variable resistor aka Potentiometer.  ;D
Offline auditory
« Reply #13 on: February 24, 2009, 06:58:37 PM »
pano po ba ikakabit ung potentiometer sa pins 1, 2 and 3 ng lcd from e gizmo? xencia na po, bago lang po tlga ako dito.. salamat po
« Reply #14 on: February 24, 2009, 07:06:20 PM »
yung isang end ng potentio sa Vdd, yung other end sa Vss... yung gitna sa pin#3 ng LCD..
Offline auditory
« Reply #15 on: February 24, 2009, 08:04:37 PM »
sir, naglagay na po ako ng potentiometer, ang nangyari naman po is puro black po ung line 2 and 4 ng lcd.. ano po ba kaya ang problem this time? thanks po sa help
« Reply #16 on: February 24, 2009, 08:40:36 PM »
line 2 and 4 lang? nangyayari lang sa akin dati 'yun kapag merong mali sa initialization ng 4 line na LCD.
Offline auditory
« Reply #17 on: February 24, 2009, 09:06:53 PM »
uhm ang code ko po na ginamit is ung sample code po from picclite po..
« Reply #18 on: February 24, 2009, 09:12:15 PM »
para sa anong LCD 'yung sample code? kapag kasi nag buong black na blocks 'yung line 2 at 4, naka-initialize siya para sa 2-liner.
« Reply #19 on: February 24, 2009, 09:21:30 PM »
sir RD namemeet ko din yan problem na yan...
sa initialization usually at minsan reset lang... :)
