There is a wide tolerance when using RC circuits for timing. The 1uF capacitor can have a 5% error or worse for an electrolytic cap. You should use a crystal controlled clock. It seems you are using a 1 second time base. You use a 32768Hz clock crystal oscillator and divide it down to a 1Hz frequency using a CD4040 + one J-K flip-flop..
papano po ang pag-apply ng xtal oscillator sa circuit na tulad nito?
thanks sir..i get it now.the only problem remaining is that the only available crystal oscillator in our vicinity is around 3.2MHz.it would then require me to add another CD4060, am i right sir?
