Author Topic: making torrent faster  (Read 5125 times)
Offline tdh7700
  • Pogi/Ganda Points: 25
Re: making torrent faster
« Reply #20 on: April 07, 2009, 12:51:44 AM »
A seed is a client that has a complete copy of the data of a certain torrent. Once your BitTorrent client finishes downloading, it will remain open until you click the Finish button (or otherwise close it). This is known as being a seed or seeding.
:D
ORDONIO ELECTRONICS
public mkt. sq pangasinan ph.
Offline Aflift
  • "everything has a purpose just keep moving and bel
« Reply #21 on: April 19, 2009, 02:42:27 AM »
yung port forwarding ba indi prone sa hack?
tama sila tiis nalang kung di afford ang mabilis na connection hehehe
Offline Woots29
  • Pogi/Ganda Points: 344
  • asan si mojacko?
    • Woots Page
« Reply #22 on: April 19, 2009, 10:52:41 AM »
naka port forward me ngaun sa aking torrent
bumilis nga hehehe
pero the software tells no connection ;D ;D ;D
basta hindi alam ung port hindi mahahack
WootsPC2 Videos  Woots Page
Offline tdh7700
« Reply #23 on: April 19, 2009, 12:55:12 PM »
sir paano po ba mag port forwarding?
ORDONIO ELECTRONICS
Offline Woots29
  • asan si mojacko?
    • Woots Page
« Reply #24 on: April 19, 2009, 01:31:18 PM »
ano ba modem u sir  http://portforward.com/
Offline tdh7700
« Reply #25 on: April 19, 2009, 05:13:34 PM »
prolink galing digitel
ORDONIO ELECTRONICS
« Reply #26 on: April 19, 2009, 06:32:42 PM »
My router/modem is a huawei smartAX MT880 - provided by bayantel. Basically, I don't port forward. Instead, I just set the router to DMZ (demilitarized zone). I don't know how it works, pero feeling ko lang, lahat ng ports will be open. I don't have to set the port number and etc...
It works great for me. Maximized ko ang speed na provided na Bayantel... it have an average of 85kB/s with a burst of more than 100kB/s. My subscribed speed is 768kbps with SOD of 1024kbps.
Kung meron din yang router mo, might as well try it.
Offline hardcore misery
« Reply #27 on: April 19, 2009, 07:59:24 PM »
ang gusto ko lang malaman kung panu ibypass ung torrent blocking ng digitel. sa smart nun, halos 12to47kbps ang downlud noon,
ha???/ kaya pala ambagal magDL sa torrentz(sa pc ng kapitbahay ko)
Offline Woots29
  • asan si mojacko?
    • Woots Page
« Reply #28 on: April 20, 2009, 09:27:33 AM »
@tdh7700
ah pwedeng HR9000 yan kung bida yan yan ung may AR sa dulo, mjo mahabang process bago iforward.kungsbagay may tutorial dun na pwede mong sundan
@marcelino
nakaktakot kasi ung DMZ baka may manghack.
@hardcore misery
tama may blocking nga ang digitel, kasi sa smart bro hindi nman.
Offline tdh7700
« Reply #29 on: April 20, 2009, 05:36:46 PM »
h9200ar po.
ORDONIO ELECTRONICS
Offline Woots29
  • asan si mojacko?
    • Woots Page
« Reply #30 on: April 21, 2009, 08:54:14 AM »
h9200ar!
pareho tau.
ang problem kasi eh panu magset ng static IP.
natsambahan ko lang ung sakin eh ;D
Offline tdh7700
« Reply #31 on: April 21, 2009, 12:09:05 PM »
h9200ar!
pareho tau.
pa turo naman. anung ginawa mo....
ORDONIO ELECTRONICS
Offline Woots29
  • asan si mojacko?
    • Woots Page
« Reply #32 on: April 21, 2009, 12:48:54 PM »
punta ka dito
http://portforward.com/english/routers/port_forwarding/Prolink/H9200AR/Utorrent.htm
(for utorrent)
den basahin mo ung port sa utorrent mo un ang ilagay mo sa Utorrent's Port for incoming connections
ung ip address eh 192.68.1.1
den follow steps sa port forward sa router mo
ung login info pm me
Offline tdh7700
« Reply #33 on: April 21, 2009, 01:06:36 PM »
sige gagawin ko mamaya. punta muna ako sa shop. tanksss :) :) :)
ORDONIO ELECTRONICS
« Reply #34 on: August 17, 2009, 05:48:00 AM »
pwede pang puro download nalang at hindi na magupload? bagal kasi ng DL ko eh, ang bilis naman ng upload :(
Offline boolean
« Reply #35 on: September 24, 2009, 06:15:14 AM »
port forwarding, mataas o mdaming seeders 1:50 ratio pede na, and of course high speed net conexion...
Offline bluegirl
  • Pogi/Ganda Points: 7
  • ..........me..........
    • author lang aq dito
« Reply #36 on: October 04, 2009, 09:36:57 PM »
punta ka dito
(for utorrent)
talaga ba mapabilis ang download sa torrent?
“Mathematics is made of 50 percent formulas, 50 percent proofs, and 50 percent imagination.”
Offline Woots29
  • asan si mojacko?
    • Woots Page
« Reply #37 on: October 05, 2009, 09:51:25 AM »
oo naman
kasi nabloblocked yung ports thru router eh
so iport forward natin para hassle free
Offline GTowerZ
« Reply #38 on: July 27, 2010, 10:24:44 PM »
may idae ba kayo kung paano bibilis ang pag download ng mga torrent files gaya sa utoorent.. share naman jan
the following steps were proven and tested. im using utorrent as my torrent downloader. what i did was:
1.] simply right click the utorrent icon at the system tray and adjust the upload limit from "unlimited" to "5 or 10kB/sec". by doing this, the bandwidth allocation of your internet connection is more prioritized to "download".
2.] (this is optional.) right click the download priority setting and adjust to "high priority".
3.] right click the torrent file you are currently downloading and set the "bandwidth allocation" to "high".
i hope, this helps you a little... oh! by the way, my internet bandwidth is only 384kbps, DSL ;) :) :D
  • Pogi/Ganda Points: 321
« Reply #39 on: July 27, 2010, 10:58:32 PM »
@GTowerZ
proportional ang upload at download. limiting your upload will SLOW your download speed. since 384kbps lang connection mo malamang pwede pa yan...
The effectiveness of this data exchange depends largely on the policies that clients use to determine to whom to send data. Clients may prefer to send data to peers that send data back to them (a tit for tat  scheme), which encourages fair trading. But strict policies often result in suboptimal situations, such as when newly joined peers are unable to receive any data because they don't have any pieces yet to trade themselves or when two peers with a good connection between them do not exchange data simply because neither of them takes the initiative. To counter these effects, the official BitTorrent client program uses a mechanism called “optimistic unchoking”, whereby the client reserves a portion of its available bandwidth for sending pieces to random peers (not necessarily known good partners, so called preferred peers) in hopes of discovering even better partners and to ensure that newcomers get a chance to join the swarm.[10]
reference:
http://en.wikipedia.org/wiki/BitTorrent_%28protocol%29
