Author Topic: Pls Help Me in Creating Relay Driver For pic16f877  (Read 1257 times)
Offline marcasjr™
« on: February 25, 2008, 12:52:32 AM »
i need to drive a magnetic lock using relay.but pic16f877 cannot drive the relay.
my magnetic lock is 12v.
tnx for any replys
Offline marcasjr™
Re: Pls Help Me in Creating Relay Driver For pic16f877
« Reply #1 on: February 25, 2008, 12:53:19 AM »
pls provide schemtics..
tnx..
Offline Shey
  • Administrator
  • Pogi/Ganda Points: 154
    • Elab.PH
« Reply #2 on: February 25, 2008, 01:11:09 AM »
Ganito lang yun. Yung base resistor from 4.7K to 10K ang value niya. Yung bypass capacitor siyempre 0.1 uF. Yung transistor bale general purpose transistor ok na yan..
The darkness around me
Shores of a solar sea
Sleeping
Weeping
With you
I walk alone
Every step I take
I walk alone
My winter storm
Holding me awake
It’s never gone
Your dangerous mind
As your true colours show
A dangerous sign
Offline toasted siopao
  • Global Moderator
  • Pogi/Ganda Points: 107
    • TeknoBlogger
« Reply #3 on: February 25, 2008, 06:14:46 AM »
Do not forget to put that diode between the coils of your relay.
Offline marcasjr™
« Reply #4 on: February 25, 2008, 07:01:15 AM »
I will try it now
tnx. :D
Offline zer0w1ng
  • Pogi/Ganda Points: 305
    • The Cebuano Geek
« Reply #5 on: February 25, 2008, 02:31:45 PM »
I think the base capacitor is not needed.  The diode in parallel to the relay coils are very IMPORTANT though.
If absent, the NPN transistor will be damaged due to reverse voltage generated by the coil after it is de-energized.
If you are using multiple relays in your circuit, you could use ULN2003 as relay drivers.
This is multiple darlington transistors in one 16 pin DIP package including the resistors and diode.
Easy interfacing for beginners :).
The Cebuano Geek
