Author Topic: digital clock using pic and display with 3310 lcd.... help  (Read 2018 times)
Offline quedee
mga masters patulong naman po,.. gusto ko kasing gumawa nito.. very noob po ako about pic or microcontroler.. pero medyo may konting background po ako sa programming..
anu pong microcontroler ang pwede.. at paanu ko magagawa to.. salamat po
Re: digital clock using pic and display with 3310 lcd.... help
« Reply #1 on: March 10, 2009, 12:19:35 AM »
mas magagawa mo ito ng mabilis if marunong ka magC language =)
PIC16F84A i think will do.. not so sure lang kung kaya ng RAM.. or PIC16F628A ^_^
actually this is one my current project.. but sa SevenSegment muna.. after achieving it, saka ko move ng LCD ng 3310 =)
Offline juzkidding
  • Conserve Water; Drink Beer!
« Reply #2 on: March 10, 2009, 01:51:32 AM »
for your guide please look here: http://www.100acre.org/elec/nokia_lcd/
Give me 5 Volts and I'll give you information.
« Reply #3 on: March 10, 2009, 03:11:09 AM »
testing before going to bed!
if you could make use of CCS, improve mo nalang to...
#include <16F84A.h>
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES XT                       //Crystal osc <= 4mhz for PCM/PCH , 3mhz to 10 mhz for PCD
#FUSES NOPUT                    //No Power Up Timer
#FUSES NOPROTECT                //Code not protected from reading
#use delay(clock=32768)
#include "N3310LCD.c"
short RTCC_flag;
#int_RTCC
void  RTCC_isr(void)
      RTCC_flag = TRUE;          //fires every 1sec
void main()
   int sec,min,hour;
   nokia_init();
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_4);       //overflow every 1
   enable_interrupts(int_RTCC);
   enable_interrupts(GLOBAL);
   while(true)
      if(RTCC_flag)
         RTCC_flag = FALSE;
         sec++;
         if (sec >= 60)
            sec=0;
            min++;
            if(min >= 60)
               min=0;
               hour++;
      nokia_gotoxy(0,0);
      printf(nokia_printchar,"\f%u:%u:%u",hour,min,sec);
and here's the driver fo n3210LCD.
Graphic LCD Nokia 3310 (LPH7779) routines v3
CCS compiler
by Michel Bavin 2004 --- bavin@skynet.be --- http://users.skynet.be/bk317494/ ---
august 29, 2004
// ex:
// nokia_init();
// nokia_gotoxy(0,0);
// printf(nokia_printchar,"test???");
#define nok_sclk  pin_b4
#define nok_sda   pin_b3
#define nok_dc    pin_b2
#define nok_cs    pin_b1
#define nok_res   pin_b0
char char_row,charsel,charpos,chardata;       // for nokia_3310 lcd
int16 ddram;
//char plot_value;
int32 plot_value32;
int32 plot_umsb,plot_lmsb,plot_ulsb,plot_llsb;
BYTE const TABLE1[240]= {
   0x00,0x00,0x00,0x00,0x00,   // 20 space          ASCII table for NOKIA LCD: 96 rows * 5 bytes= 480 bytes
   0x00,0x00,0x5f,0x00,0x00,   // 21 !
   0x00,0x07,0x00,0x07,0x00,   // 22 "
   0x14,0x7f,0x14,0x7f,0x14,   // 23 #
   0x24,0x2a,0x7f,0x2a,0x12,   // 24 $
   0x23,0x13,0x08,0x64,0x62,   // 25 %
   0x36,0x49,0x55,0x22,0x50,   // 26 &
   0x00,0x05,0x03,0x00,0x00,   // 27 '
   0x00,0x1c,0x22,0x41,0x00,   // 28 (
   0x00,0x41,0x22,0x1c,0x00,   // 29 )
   0x14,0x08,0x3e,0x08,0x14,   // 2a *
   0x08,0x08,0x3e,0x08,0x08,   // 2b +
   0x00,0x50,0x30,0x00,0x00,   // 2c ,
   0x08,0x08,0x08,0x08,0x08,   // 2d -
   0x00,0x60,0x60,0x00,0x00,   // 2e .
   0x20,0x10,0x08,0x04,0x02,   // 2f /
   0x3e,0x51,0x49,0x45,0x3e,   // 30 0
   0x00,0x42,0x7f,0x40,0x00,   // 31 1
   0x42,0x61,0x51,0x49,0x46,   // 32 2
   0x21,0x41,0x45,0x4b,0x31,   // 33 3
   0x18,0x14,0x12,0x7f,0x10,   // 34 4
   0x27,0x45,0x45,0x45,0x39,   // 35 5
   0x3c,0x4a,0x49,0x49,0x30,   // 36 6
   0x01,0x71,0x09,0x05,0x03,   // 37 7
   0x36,0x49,0x49,0x49,0x36,   // 38 8
   0x06,0x49,0x49,0x29,0x1e,   // 39 9
   0x00,0x36,0x36,0x00,0x00,   // 3a :
   0x00,0x56,0x36,0x00,0x00,   // 3b ;
   0x08,0x14,0x22,0x41,0x00,   // 3c <
   0x14,0x14,0x14,0x14,0x14,   // 3d =
   0x00,0x41,0x22,0x14,0x08,   // 3e >
   0x02,0x01,0x51,0x09,0x06,   // 3f ?
   0x32,0x49,0x79,0x41,0x3e,   // 40 @
   0x7e,0x11,0x11,0x11,0x7e,   // 41 A
   0x7f,0x49,0x49,0x49,0x36,   // 42 B
   0x3e,0x41,0x41,0x41,0x22,   // 43 C
   0x7f,0x41,0x41,0x22,0x1c,   // 44 D
   0x7f,0x49,0x49,0x49,0x41,   // 45 E
   0x7f,0x09,0x09,0x09,0x01,   // 46 F
   0x3e,0x41,0x49,0x49,0x7a,   // 47 G
   0x7f,0x08,0x08,0x08,0x7f,   // 48 H
   0x00,0x41,0x7f,0x41,0x00,   // 49 I
   0x20,0x40,0x41,0x3f,0x01,   // 4a J
   0x7f,0x08,0x14,0x22,0x41,   // 4b K
   0x7f,0x40,0x40,0x40,0x40,   // 4c L
   0x7f,0x02,0x0c,0x02,0x7f,   // 4d M
   0x7f,0x04,0x08,0x10,0x7f,   // 4e N
   0x3e,0x41,0x41,0x41,0x3e    // 4f O
BYTE const TABLE2[240]= {
   0x7f,0x09,0x09,0x09,0x06,   // 50 P
   0x3e,0x41,0x51,0x21,0x5e,   // 51 Q
   0x7f,0x09,0x19,0x29,0x46,   // 52 R
   0x46,0x49,0x49,0x49,0x31,   // 53 S
   0x01,0x01,0x7f,0x01,0x01,   // 54 T
   0x3f,0x40,0x40,0x40,0x3f,   // 55 U
   0x1f,0x20,0x40,0x20,0x1f,   // 56 V
   0x3f,0x40,0x38,0x40,0x3f,   // 57 W
   0x63,0x14,0x08,0x14,0x63,   // 58 X
   0x07,0x08,0x70,0x08,0x07,   // 59 Y
   0x61,0x51,0x49,0x45,0x43,   // 5a Z
   0x00,0x7f,0x41,0x41,0x00,   // 5b [
   0x02,0x04,0x08,0x10,0x20,   // 5c
   0x00,0x41,0x41,0x7f,0x00,   // 5d
   0x04,0x02,0x01,0x02,0x04,   // 5e
   0x40,0x40,0x40,0x40,0x40,   // 5f
   0x00,0x01,0x02,0x04,0x00,   // 60
   0x20,0x54,0x54,0x54,0x78,   // 61 a
   0x7f,0x48,0x44,0x44,0x38,   // 62 b
   0x38,0x44,0x44,0x44,0x20,   // 63 c
   0x38,0x44,0x44,0x48,0x7f,   // 64 d
   0x38,0x54,0x54,0x54,0x18,   // 65 e
   0x08,0x7e,0x09,0x01,0x02,   // 66 f
   0x0c,0x52,0x52,0x52,0x3e,   // 67 g
   0x7f,0x08,0x04,0x04,0x78,   // 68 h
   0x00,0x44,0x7d,0x40,0x00,   // 69 i
   0x20,0x40,0x44,0x3d,0x00,   // 6a j
   0x7f,0x10,0x28,0x44,0x00,   // 6b k
   0x00,0x41,0x7f,0x40,0x00,   // 6c l
   0x7c,0x04,0x18,0x04,0x78,   // 6d m
   0x7c,0x08,0x04,0x04,0x78,   // 6e n
   0x38,0x44,0x44,0x44,0x38,   // 6f o
   0x7c,0x14,0x14,0x14,0x08,   // 70 p
   0x08,0x14,0x14,0x18,0x7c,   // 71 q
   0x7c,0x08,0x04,0x04,0x08,   // 72 r
   0x48,0x54,0x54,0x54,0x20,   // 73 s
   0x04,0x3f,0x44,0x40,0x20,   // 74 t
   0x3c,0x40,0x40,0x20,0x7c,   // 75 u
   0x1c,0x20,0x40,0x20,0x1c,   // 76 v
   0x3c,0x40,0x30,0x40,0x3c,   // 77 w
   0x44,0x28,0x10,0x28,0x44,   // 78 x
   0x0c,0x50,0x50,0x50,0x3c,   // 79 y
   0x44,0x64,0x54,0x4c,0x44,   // 7a z
   0x00,0x08,0x36,0x41,0x00,   // 7b
   0x00,0x00,0x7f,0x00,0x00,   // 7c
   0x00,0x41,0x36,0x08,0x00,   // 7d
   0x10,0x08,0x08,0x10,0x08,   // 7e
   0x78,0x46,0x41,0x46,0x78    // 7f
BYTE const DIGITS_8x16[160]=
   0xfc, 0xfe, 0xfe, 0x06, 0x06, 0xfe, 0xfe, 0xfc, 0x7f, 0xff, 0xff, 0xc0, 0xc0, 0xff, 0xff, 0x7f, //0
   0x00, 0x18, 0x1c, 0xfe, 0xfe, 0xfe, 0x00, 0x00, 0x00, 0x00, 0xc0, 0xff, 0xff, 0xff, 0xc0, 0x00, //1
   0x3c, 0x3e, 0x3e, 0x06, 0x86, 0xfe, 0xfe, 0x7c, 0xe0, 0xf0, 0xfc, 0xff, 0xcf, 0xc7, 0xc1, 0xc0, //2
   0x1c, 0x1e, 0x9e, 0x86, 0x86, 0xfe, 0xfe, 0xfc, 0x78, 0xf8, 0xf9, 0xc1, 0xc1, 0xff, 0xff, 0x7e, //3
   0x00, 0xf0, 0xfe, 0x7e, 0xfe, 0xfe, 0xfe, 0x00, 0x3f, 0x3f, 0x37, 0x30, 0xff, 0xff, 0xff, 0x30, //4
   0xfe, 0xfe, 0xfe, 0xc6, 0xc6, 0xc6, 0xc6, 0x86, 0x71, 0xf1, 0xf1, 0xc0, 0xc0, 0xff, 0xff, 0x7f, //5
   0xfc, 0xfe, 0xfe, 0xc6, 0xc6, 0xde, 0xde, 0x9c, 0x7f, 0xff, 0xff, 0xc0, 0xc0, 0xff, 0xff, 0x7f, //6
   0x06, 0x06, 0x06, 0x86, 0xe6, 0xfe, 0x7e, 0x1e, 0x80, 0xf0, 0xfe, 0x3f, 0x07, 0x01, 0x00, 0x00, //7
   0x7c, 0xfe, 0xfe, 0x86, 0x86, 0xfe, 0xfe, 0x7c, 0x7e, 0xff, 0xff, 0xc1, 0xc1, 0xff, 0xff, 0x7e, //8
   0xfc, 0xfe, 0xfe, 0x86, 0x86, 0xfe, 0xfe, 0xfc, 0x78, 0xf9, 0xf9, 0xc1, 0xc1, 0xff, 0xff, 0x7f  //9
void  nokia_init(void);
void  nokia_write_command(char bytefornokia_command);
void  nokia_write_data(char bytefornokia_data);
void  nokia_write_dorc(char bytefornokia);
void  nokia_gotoxy(int8 xnokia, int8 ynokia);
void  nokia_erase_y(int8 ynokia);
void  nokia_erase_x(int8 xnokia);
void  nokia_printchar(int8 cvar);
void  nokia_clean_ddram(void);
void  table_to_nokialcd(void);
void  nokia_plot(int8 xnokia,int8 plot_value8);
void  nokia_write_data_inv(char bytefornokia_data_inv);
void  nokia_clear_screen(void);
void  nokia_clear_xy(int8 xnokia, int8 ynokia);
void  nokia_print_uparrow(void);
void  nokia_print_downarrow(void);
void  nokia_print_leftarrow(void);
void  nokia_print_rightarrow(void);
void  nokia_print_degree(void);
void  nokia_print_lowbatdegree(void);
void  display_digit(unsigned char line, unsigned char column, unsigned char digit);
  output_high(nok_dc);            // bytes are stored in the display data ram, address counter, incremented automatically
  output_high(nok_cs);            // chip disabled
  output_low(nok_res);            // reset chip during 250ms
  delay_ms(10);         // works with less.....
  output_high(nok_res);
  nokia_write_command(0x21);   // set extins extended instruction set
  nokia_write_command(0xc2);   // Vop  v1: 0xc8 (for 3V)// v2: 0xa0 (for 3V) // v3: 0xc2 (2v6-5v)   ********************************************************************************************************************
  nokia_write_command(0x13);   // bias
  nokia_write_command(0x20);   // horizontal mode from left to right, X axe are incremented automatically , 0x22 for vertical addressing ,back on normal instruction set too
  nokia_write_command(0x09);   // all on
  nokia_clean_ddram();      // reset DDRAM, otherwise the lcd is blurred with random pixels
  nokia_write_command(0x08);   // mod control blank change (all off)
  nokia_write_command(0x0c);   // mod control normal change
  nokia_gotoxy(0,0);         // 84*6=504      clear LCD
  for (ddram=504;ddram>0;ddram--){nokia_write_data(0x00);}
  output_low(nok_dc);   // byte is a command it is read with the eight SCLK pulse
  output_low(nok_cs);   // chip enabled
  nokia_write_dorc(bytefornokia_command);
  nokia_write_dorc(bytefornokia_data);
void nokia_write_dorc(char bytefornokia)         // serial write data or command subroutine
  char caa;
  for (caa=8;caa>0;caa--) {
    output_low(nok_sclk);
    // delay_us(2);
    if ((bytefornokia&0x80)==0){output_low(nok_sda);}
    else {output_high(nok_sda);}
    output_high(nok_sclk);
    bytefornokia=bytefornokia<<1;
void nokia_gotoxy(int8 xnokia, int8 ynokia)      // Nokia LCD 3310 Position cursor
  nokia_write_command(0x40|(ynokia&0x07));   // Y axe initialisation: 0100 0yyy
  nokia_write_command(0x80|(xnokia&0x7f));   // X axe initialisation: 1xxx xxxx
  nokia_gotoxy(0,ynokia);
  printf(nokia_printchar,"              ");
  char column;
  for (column=0;column!=6;column++){
    nokia_gotoxy(xnokia,column);
void nokia_printchar(int8 cvar)               // Write 1 character to LCD
  charsel=cvar;
  table_to_nokialcd();
void table_to_nokialcd(void)   // extract ascii from tables & write to LCD
  if (charsel<0x20)return;
  if (charsel>0x7f)return;
  for (char_row=0;char_row<5;char_row++) {      // 5 bytes
    if (charsel<0x50){charpos=(((charsel&0xff)-0x20)*5);chardata=TABLE1[(charpos+char_row)];}            // use TABLE5
    else if (charsel>0x4f){charpos=(((charsel&0xff)-0x50)*5);chardata=TABLE2[(charpos+char_row)];}            // use TABLE6
    nokia_write_data(chardata);      // send data to nokia
  nokia_write_data(0x00);      //    1 byte (always blank)
  char i;
  plot_value32=0;
   plot_value32|=1;         // unremark this if you want dotgraph instead of bargraph
  for (i=0;i!=plot_value8;i++){
    //plot_value32|=1;         // remark this if you want dotgraph instead of bargraph
    plot_value32<<=1;
  //plot_value32|=2;            // bottom line is always filled
  plot_llsb=(plot_value32&0xff);
  plot_ulsb=((plot_value32>>8)&0xff);
  plot_lmsb=((plot_value32>>16)&0xff);
  plot_umsb=((plot_value32>>24)&0xff);
  nokia_gotoxy(xnokia,1);
  nokia_write_data_inv(plot_umsb);
  nokia_gotoxy(xnokia,2);
  nokia_write_data_inv(plot_lmsb);
  nokia_gotoxy(xnokia,3);
  nokia_write_data_inv(plot_ulsb);
  nokia_gotoxy(xnokia,4);
  nokia_write_data_inv(plot_llsb);
  char caa;
    delay_us(2);
    if ((bytefornokia_data_inv&0x01)==0){output_low(nok_sda);}
    bytefornokia_data_inv=bytefornokia_data_inv>>1;
  nokia_erase_y(0);
  nokia_erase_y(1);
  nokia_erase_y(2);
  nokia_erase_y(3);
  nokia_erase_y(4);
  nokia_erase_y(5);
  nokia_gotoxy(xnokia,ynokia);
  nokia_printchar(" ");
  nokia_write_data(0x04);
  nokia_write_data(0x02);
  nokia_write_data(0x7f);
  nokia_write_data(0x10);
  nokia_write_data(0x20);
  nokia_write_data(0x08);
  nokia_write_data(0x1c);
  nokia_write_data(0x2a);
  nokia_write_data(0xf8);
  nokia_write_data(0x06);
  nokia_write_data(0x09);
  // nokia_printchar("  ");
  nokia_write_data(0x0f);
   unsigned char i;
   if (line<1 && line>5) return;
   if (column >74) return;
   if (digit>9) return;
   nokia_gotoxy(column, line-1);
   for(i=0; i<8; i++) nokia_write_data(DIGITS_8x16[digit*16+i]);
   nokia_gotoxy(column, line);
   for(i=8; i<16; i++) nokia_write_data(DIGITS_8x16[digit*16+i]);
galing yan dun sa project ni yus...
here is the snapshot:
BTW, including the driver, memory usage is: ROM = 90%, RAM = 65% to 75%
Offline quedee
« Reply #4 on: March 10, 2009, 11:56:51 PM »
panu po ang circuit nito?.. pwede po bng supply nya eh 5v..
« Reply #5 on: March 11, 2009, 12:10:13 AM »
tignan mo yung project ni yus... may sample circuit sya using PIC16f876a.
yung sample simulation ko, i did use 32768Hz crystal
yeah, 5V po.
pag-aralan mo nalang yung mapping sa N3310... actually, di ko naiintindihan eh! heheh ;D
Offline RaffT
  • Pogi/Ganda Points: 103
  • more on R-n-D
    • MY Bots
« Reply #6 on: March 11, 2009, 06:29:44 AM »
^sis marce,
 nice one...  :-*
 pwede add-on feture...  ;D
pakilagay naman AM/FM tapos SNOOZE function  :D
« Reply #7 on: March 11, 2009, 08:31:13 AM »
Possible rin ito sa proton picbasic. tapos lalagyan na lang ng RTC pra sa precise timing. tapos gawin mong projector
Offline SpongeBob
  • Pogi/Ganda Points: 33
« Reply #8 on: March 11, 2009, 09:21:20 AM »
@quedee
kayang kaya mo yan dahil maraming sample codes for different programming languages using N3310 LCD
ang driver/controller nyan PCD8544
http://pdf1.alldatasheet.com/datasheet-pdf/view/18170/PHILIPS/PCD8544.html
mas simple pa ang initialization compared to HD44780 based
« Reply #9 on: March 11, 2009, 11:46:55 AM »
^sis marce,
 nice one...  :-*
actually my intention is to see how much memory will it occupy... just trying to prove if it would fit into a pic16F84 hehehe ;D
Offline quedee
« Reply #10 on: March 11, 2009, 08:31:02 PM »
try ko pong simulate ung project ni sir yus... eh may error po naghahanap ng dll ung sa lcd..
« Reply #11 on: March 11, 2009, 08:46:21 PM »
kailangan mong magdownload nung proteus library na N3310...
i found mine using google... :)
Offline quedee
« Reply #12 on: March 13, 2009, 12:33:51 AM »
nakahanap na po ako at nailagay ko na sa library at models.. ganun pa rin po?.. panu kaya to..
« Reply #13 on: March 13, 2009, 12:59:50 AM »
thats odd...
try this one:http://www.tanu-sha.narod.ru/Files3/Model.zip
Offline quedee
« Reply #14 on: March 13, 2009, 09:56:56 AM »
isis 7 pro po gamit ko ayaw pa rin..
