Author Topic: Hello World using E-gizmo's CPLD board  (Read 15461 times)
Offline 'yus
  • Pogi/Ganda Points: 299
  • hw -> fw -> sw
    • yus' projects
Re: Hello World using E-gizmo's CPLD board
« Reply #20 on: March 15, 2009, 10:03:18 PM »
may ADC module din ba sya? ???
join  - Philippine Electronics and Robotics Enthusiasts Club - www.philrobotics.com
« Reply #21 on: March 15, 2009, 10:06:10 PM »
alam ko madalas wala kaya gumagamit ng external Fast DAC's.
Offline ef - el - ay - pee
  • Pogi/Ganda Points: 34
  • Regrets, I have a few...
    • The Taste Bytes Food Blog
« Reply #22 on: March 15, 2009, 10:12:27 PM »
too bad CoE's at hindi ECEs ang natututong mag VHDL sa amin. :( , though may mga iilang anak ng diyos na mga ECEng natututo nito. :)
"Engineers are the Oompah-Loompahs of Science" - Dr. Sheldon Lee Cooper
Offline Born2BeWired
  • Pogi/Ganda Points: 168
  • Analog and Precision Circuits Junkie
    • e-Gizmo Mechatronix Central
« Reply #23 on: March 15, 2009, 10:26:21 PM »
Ayos ito! mukhang dito ako matututong mag CPLD ;D
Electronics <- Once you got a taste of it, you will never get enough.
Insanity <- Doing the same thing, expecting different results.
"The more I learn, the more I am humbled."
Offline marcelino
  • Pogi/Ganda Points: 258
« Reply #24 on: March 15, 2009, 10:36:48 PM »
grabe ka naman... you can even learn it without a board!
;D
« Reply #25 on: March 15, 2009, 10:45:28 PM »
sabagay...aaralin ko to pag meron na kong oras, may market value din ang mag-aral ng FPGA....pero hindi po ba verilog ang standard sa industry? ....tapos anlaki pa ng installer ng Xilinx... :)
Offline marcelino
« Reply #26 on: March 15, 2009, 10:52:37 PM »
thats not true... standardize naman ang vhdl (ng ieee).
Offline paranz
  • Pogi/Ganda Points: 177
  • 1/4W resistor specialist
    • RapidSignal Electronics
« Reply #27 on: March 15, 2009, 11:01:54 PM »
yes tama sa efi, verilog na talaga ang kadalasang ginagamit sa industry ngayun
PIC16 Programming Tutorial using MPLAB and Hi-Tech C
www.rapidsignalph.com/tutorials/pic16-tutorials
Arduino & gizDuino Tutorials
www.rapidsignalph.com/tutorials/arduino-tutorials
« Reply #28 on: March 15, 2009, 11:12:39 PM »
Pagkakaalam ko sir, verilog is gaining popularity dahil malapit na malapit siya sa C, and generally mas maikli ang lines of codes sa Verilog ikumpara sa VHDL describing the same logic.
Offline marcelino
« Reply #29 on: March 15, 2009, 11:20:52 PM »
buti pa pala, pag-aralan din natin ang verilog... hehehe ;D
nag-attempt na ako nyan, halos magkapareho naman. :)
eto article, comparing vhdl and verilog. pero di naman dinicuss ang popularity.
http://www.angelfire.com/in/rajesh52/verilogvhdl.html
Offline 0b00000111
  • Pogi/Ganda Points: 398
« Reply #30 on: March 16, 2009, 09:02:59 AM »
ganda points sa iyo tita marce! ;D ;D ;D turuan mo pa kami hehe ;D
ang ginagawa ko sa ngayon is yung schematic representation sa webpack ise ang ginagamit ko at hinde ako gumagamit pa ng VHDL hehehe ;D (pang-tamad) ;D ;D ;D
pero plan ko is mag-full VHDL without using schematic ng xilinx ISE.
nagpabook bind na ako kanina ng VHDL ebook... hopefully, matutunan at ma-master (sana) ko din ang VHDL using CPLD ;D ;D ;D
Tel #: (63)(2) 536-3378
Globe +63915-973-7691
Smart +63921-779-0748
Location Map
« Reply #31 on: March 16, 2009, 09:10:36 AM »
buti pa kayo may time. ;D ;D ;D
Offline marcelino
« Reply #32 on: March 16, 2009, 09:28:16 AM »
^thanks for the point!
di naman ako magaling magsulat.... basta kapag may naisip (or may nagawa) ako, iseshare ko nalang. hehehe ;D
pero in contrary, di pa ako nakakagamit nung schematic. try ko mamaya... ;D
Offline 0b00000111
« Reply #33 on: March 16, 2009, 09:42:55 AM »
mas madali yung schematic kasi madami ng ready made na parts hehehehe ;D ;D ;D pero gusto ko pa rin pag-aralan yung VHDL para gumawa ng customized parts hehe ;D
Location Map
Offline marcelino
« Reply #34 on: March 16, 2009, 10:05:44 AM »
sabagay...
pero ang advantage naman ng vhdl kaagad, kahit di mo alam kung anong rtl equivalent ng ALU, kusang nailalagay na. hehehe ;D
tulad nitong ginawa ko.
so yan ang pasunod-sunod...
hanggang sa kinaloob-looban, gates lang naman pala... ;D
Offline subzer0
  • Pogi/Ganda Points: 38
  • Garbage In Garbage Out.
« Reply #35 on: March 16, 2009, 10:17:25 AM »
ate marce, di ba po xilinx CPLD yan?may simulator ba yung software ng xilinx?para makita ko naman yung flow ng program bago ko i load yung program sa JTAG.
Signing Off...
Offline marcelino
« Reply #36 on: March 16, 2009, 10:22:10 AM »
yung webpack meron na din...
pero di ako sanay dun, kaya nagdownload pa ako ng modelsim para masimulate ko lang. pero kakailanganin mo pang gumawa ng testbench (vhdl code din ito) para masimulate mo ng maganda. Though, you can forcibly give values to each port/pin.
Offline subzer0
« Reply #37 on: March 16, 2009, 11:28:04 AM »
meron ka pong link sa modelsim?dati po kasi ako gumagamit ng altera maxplus,pero di ko pa natatry yung xilinx,sensya na po makulit ako.
Signing Off...
Offline 0b00000111
« Reply #38 on: April 09, 2009, 01:07:25 AM »
meron bang VHDL editor na may intellisense/code completion tulad ng sa visual studio? ;D
Location Map
Offline paranz
« Reply #39 on: April 09, 2009, 11:38:13 AM »
^ asa ka pa ;D
