Author Topic: Anong bootloader ang gamit ninyo?  (Read 3273 times)
Re: Anong bootloader ang gamit ninyo?
« Reply #20 on: July 24, 2008, 10:53:40 AM »
Yun ytang microcode ang ginamit ko ksama ng proton, di ko na po sure ksi di ko na inulit.
Offline donacoba
« Reply #21 on: September 01, 2008, 11:04:14 AM »
I'm currently using Tiny PIC Bootloader. It took awhile to figure out how to configure it for the CC5X C compiler. I have just started using but it seems to be working flawlessly. I can finally make a custom development board without removing the PIC every time I have to program it!
some specs:
uC: PIC16F877A
Baud rate: 38400 bps
XTAL: 8MHz
Offline paranz
  • Pogi/Ganda Points: 177
  • 1/4W resistor specialist
    • RapidSignal Electronics
« Reply #22 on: September 01, 2008, 06:05:40 PM »
^ Na-try ko na rin gamitin ang Tiny bootloader, works just fine for the pic16f877a and pic16f88
Offline drx2k
  • Pogi/Ganda Points: 15
    • Drx2k Network
« Reply #23 on: August 01, 2009, 10:53:16 AM »
bakit ganun may warning nung load ko yung hex file ng bootloader from tinybootloader sa PICKit 2 v2.61?
eto po yung file name ng hex file: tinybld16F887.HEX, tinybld16F887_8MHz_int.HEX
load ko sana sya sa PIC16F877A ko eh pero may warning message
ok lang po ba yun na may warning?
compatible ba sa ibat-ibang compiler ang tinybootloader??
i also try yung hex file na galing sa http://www.microchipc.com/PIC16bootload/, wala syang warning message sa pickit 2
ginamit ko yung bootldr-16F877A-20MHz-56000bps.HEX from http://www.microchipc.com/PIC16bootload/PIC16F87xA_bootloader_v9-60.zip
ano mas mabuting gamitin between tinybootloader at yung sa microchipc.com?
Offline paranz
« Reply #24 on: August 01, 2009, 12:54:33 PM »
that firmware is for PIC16F887, not PIC16F877A.
The bootloader is not included in your c or basic code, so compatibility is not an issue here.
Naka program na kasi yung bootloader sa chip mismo, tapos gagamitin mo lang ang bootloader to download your other application board na ginawa mo using other languages like assembly, c, or basic
