Author Topic: SOS Servo Motor Out-of-stock sa e-gizmo  (Read 2119 times)
Offline KennethSarita
  • Nag aaral pa lang ...
« on: March 16, 2009, 03:50:57 PM »
san pa po kaya pwedeng makakuha ng servo motor na 9805BB - 20Kg or higher weight capacity servo???
Wala pa daw ung sa egizmo eh
All our knowledge falls within the bounds of possible experience.
Re: SOS Servo Motor Out-of-stock sa e-gizmo
« Reply #1 on: March 16, 2009, 04:58:44 PM »
Meron na servo sa alexan. try to visit then at kung wla pa rin sa megamall or sa glorieta na pwede mo puntahan.
Offline ajak
  • Pogi/Ganda Points: 50
« Reply #2 on: March 16, 2009, 09:15:03 PM »
make a diy servo motor pero matagal ito. .hehe..  Bile ka na lang sa ibang bansa.. di pa ako nakatry bumile ng servo motor ng alexan..
« Reply #3 on: March 17, 2009, 05:46:22 AM »
Madami nman available dito sa pinas problema lang eh presyo. I think meron din dun sa may QC.
« Reply #4 on: March 17, 2009, 01:12:36 PM »
Na check ko na po ung sa Alexan, kaso po ang baba ng stall torque nung binenbenta nilang motors,
ayoko po nung DIY baka abutin po ako ng syam syam  ;D
ung sa megamall po at glorietta san po dun? wala po bang specific shop name? I think your pertaining to hobby shop? ung parang sa RC toys
« Reply #5 on: March 17, 2009, 01:28:32 PM »
yes mga hobby shop nga.
« Reply #6 on: March 17, 2009, 04:53:43 PM »
Thanks I'll check it soon
Offline ajak
« Reply #7 on: March 17, 2009, 09:20:22 PM »
Ung sa may sikatuna,QC mahal dun..
ung sa may megamall at trinoma un name ng store ay Lil's hobby, pero konte lang pagpipilian dun, intay mo na lang ung sa egizmo ok na ok un..
« Reply #8 on: March 18, 2009, 09:03:29 AM »
ung stall torque po ba sa specs ng servo motors ex 20Kg/cm un ung kaya nyang weight? na maximum?
Offline ajak
« Reply #9 on: March 18, 2009, 08:17:04 PM »
oo kaya nya un, basta malakas ang current ng battery mo, if mahina di kaya.. importante ang mataa na current ng battery para makahandle ng mabigat na weight...
« Reply #10 on: March 18, 2009, 08:18:55 PM »
'yan 'yung torque na kaya niya. so kung may pulley ka na 1cm ang radius, 20 kg. ang mabubuhat nun, pero kung gagawin mong .5cm ang rdius nung same pulley, 40kg. na ang mabubuhat niya. ;)
« Reply #11 on: March 18, 2009, 10:20:35 PM »
edi kung i-aaply ko po sya sa isang GEAR na may radius na 2cm its stall torque will be divided? 10KG?
Offline bravokilo
  • Pogi/Ganda Points: 105
« Reply #12 on: April 23, 2009, 01:18:07 PM »
Kenneth, I am Bong, si Bravokilo, modeller and repairman ng mga modeller when it comes to radio systems. i may be able to help if you will tell me the details of application.  I may be able to source the right servo for you or build one for you for your application.  20 kilograms, wow, malakas yan. Kahit yung quarter scale servo namin, baka maliit.  Speed and torque are inversely proportional.  Kaya, you can increase torque by gearing down,pero babagal.  Kaya, depended din sa speed kailangan mo. I developed winch motors for sailboat to pull the sheet(the sail). Di rin pwede maliit na maliit na motor.  Kaya ,pero ang bagal!  Kaya, size comes in. size has higher torque na mabilis pa.  You can call me at 8253867 or text 09197726274.  My email address is rcdevices@yahoo.com.ph.
BK
Offline alvin.fluke
« Reply #13 on: April 27, 2009, 06:24:51 AM »
saan mo gagamitin yong servo motor toys project we have  a lot or servo motor but  hindi ko alam gamit pero may manga robotics parts ako
baka makatulong ako mail mo ako regarding sa servo motor ( alvin.fluke@yahoo.com)k
Offline bisr2k
  • "Learning is fun.." -GB
« Reply #14 on: August 04, 2009, 04:58:46 PM »
try himodel.com tried and tested ko na ang site na yan dyan ako bumili ng servo motors for my project.. if may paypal account ka mas ok but if wala western union na lang gamitin mo for payment; probably next week will be tring this model:
http://www.himodel.com/radios/30Kg-cm_Large_Torque_Metal_Gear_Servo_S8166M.html
« Reply #15 on: August 04, 2009, 10:50:53 PM »
pwede rin dito
http://www.willysrc.com/
at least local lang yan
Offline paul_lirasan0726
« Reply #16 on: October 05, 2009, 03:56:20 PM »
UNG servo bracket poh san makakabili..... cra daw sa gizmo eh
