Author Topic: sino po ang may alam tunkol sa echo link  (Read 2042 times)
Offline magsy
  • Pogi/Ganda Points: 7
  • BT995 MONSTER RADIO 5TH LEVEL G-MALL BAJADA D.C.
    • www.rx931.com
« on: April 07, 2009, 11:49:43 AM »
na monitor ko sa aking vhf radio 14.5460mhz amature band narinig ko ang ibayong dagat kasi naka link sila sa echo link with satelite repeater at paano ang set up nito naka ingit naman na namonitor ko buong pilipinas at ibayong dagat thru vhf radio
thanks
magsy
THE LAND OF PROMISE DAVAO CITY PHILIPPINES  wwwrx931.com
Offline dv2 rxb
Re: sino po ang may alam tunkol sa echo link
« Reply #1 on: April 11, 2009, 10:38:47 PM »
bro ask ko lang kung licensed amateur holder ka? kc  kylangang ng licence validation
kung hindi naman pwede k magbreak in @ makipag qso nlang
73's and good numbers.  DV2 RXB, baguio city
Offline hamkid
  • "not again i am interfering the TV"
« Reply #2 on: April 25, 2009, 05:55:02 AM »
tama si dv2rxv...i agree
du9hgf/dw9hgf/4d72hgf
"If all my friends were to jump off a bridge, I wouldn't jump with them, I'd be at the bottom to catch them" :-)
Offline BATHALA
« Reply #3 on: April 27, 2009, 12:44:17 PM »
tama po sila. ang pwede lang maka pag qso using echo link ay holder ng amateur lisence. require kasi pag mag open ka ng link. much better po kung mag member kayo ng amateur group para mas ma guide kayo kung pano.
Offline rurikdgreat
  • Pogi/Ganda Points: 11
« Reply #4 on: April 27, 2009, 02:13:07 PM »
i'm using echolink, walang nga lang interface between my radio and pc, pero nakakapag qso ako with stations from other countries using my pc only. nakalink din ang aming club.
you can use your transceiver or pc to talk to other stations, locally or globally, using their radios or pc.
you can download the program at http://www.echolink.org/ kaya lang kailangan ng valid amateur radio license for validation para makaconnect ka otherwise di mo rin magagamit.
Life's too short...... call CQ!
A HAM will always be a HAM.
Offline magsy
    • www.rx931.com
« Reply #5 on: May 02, 2009, 07:09:57 PM »
hindi pala ako pwede commercials ang ntc licesend ko pero lang naka monitor lang ako
Offline butingting
« Reply #6 on: May 28, 2009, 10:48:12 PM »
meron akong alam na voip software parang katulad na ginagamit sa echolink, di na kailangan ng license, at sa pagkakaalam ko saking palagay mas maganda ito sa echolink... please lang ''wag nyong gamitin ito sa business nyo. http://www.freeradionetwork.eu/
Offline BATHALA
« Reply #7 on: October 04, 2009, 07:59:07 PM »
pwede po bang malaman ang procedure nito kung papano gagamitin at ikakabit sa pc from radio? ano po ba mga kailangan na gagamitin pag set up at ano ang procedure?
Offline Cowboy 1628(Maverick)
« Reply #8 on: August 17, 2010, 07:17:37 AM »
by this time you probably find out how to use the FRN(freeradionetwork) and set up your pc and radio. if not, may procedure po yung site on how to use software. may schematic diagram din yung interface para sa pc and radio. you'll find everything on www.freeradionetwork.eu
73's to all
Offline 1-Lucio
  • 1 - Lucio
« Reply #9 on: August 22, 2010, 11:42:25 PM »
uu at kung di ka license holder ,...pwede ka sa SWL (short wave listener)  like Hamsphere,
kung na install mo na ang FRN Client ng www.freeradionetwork.eu,  log in ka lang sa server na gamit ko.
server; philippine-channel.ham-radio-op.net
port; 14844
Net: pilipino channel
DY1-LCO (1-Lucio) NCR, Phils. @ 145.240 Mhz  +0.600 CTCSS 20
FRN VoiP Channel: philippine-channel.ham-radio-op.net Port:14844
Net: pilipino channel (download FRNClient @www.freeradionetwork.eu)
Hamsphere DX listener my SWL callsign: 79HS184
