Author Topic: Hot Air Soldering Station for Cellphone Repair  (Read 22329 times)
Offline THXneo
  • Pogi/Ganda Points: 34
  • DJ, Home Theater Fanatic
Re: Hot Air Soldering Station for Cellphone Repair
« Reply #100 on: November 19, 2011, 10:22:45 PM »
sa saudi ko nabili yun sis.350 riyal.
More to Lose by Seona Dancing
Offline Macgyver
  • Pogi/Ganda Points: 70
    • MakerDude
« Reply #101 on: November 20, 2011, 10:56:13 PM »
Quiapo! at Manila City Plaza.. you can try S-1 second floor or GSM Sandwich, or S-67 second floor call 211-8630 or text 09178574076
ang nakikita ko sa Quiapo is solder flux na in paste form.
ang dating hinahanap ko dun is yung solder paste.  yung solder in paste form na ginagamit sa smd para ireflow.  same lang ba ito dun sa pang bga na paste?
Offline Mannymekaniko
« Reply #102 on: November 20, 2011, 11:24:49 PM »
iyan po yung available sa Quiapo kinunan ko na lahat bakasakaling makita mo dyan sis! Yun pong pang BGA yung nasa upper left (solder Paste)kita nyo po yung 63%tin/37%lead kapag na hot air po yan nagiging solder lead gamit po pang reball ng BGA using Stencil. Yan po ba hanap mo sis?
Yung Flux paste type RMA-223 (nasa Syringe)madalas gamitin ng mga cellphone tech.
trying a career shift but cannot..Visit my site http://www.photobymanny.multiply.com
Offline Macgyver
    • MakerDude
« Reply #103 on: November 20, 2011, 11:36:10 PM »
yan nga.  yan yung gusto kong i-try.    so ganyan pala itsura. parang vicks vaporub na lalagyan.  pag nagawi uli akong quiapo, hanapin ko yung ganyan.
« Reply #104 on: November 20, 2011, 11:44:09 PM »
meron akong nakita dati nasa Syringe din kaso wala nako mahanap ngayon puro ganyan na,sis napapanis yan kapag nabuksan na kelangan ilagay sa ref(freezer) para di mapanis,pero pag sealed pa ok lang di ilagay sa ref. tumitigas kapag di nilagay sa ref at di mo na magagamit.
« Reply #105 on: November 20, 2011, 11:55:25 PM »
Meron din ba nung liquid flux (yung nasa plastic bottle at the right  sa picture) sa quiapo?  Parang wala akong nakitang ganyan dati.  Yan yung need ko to solder smd chips para madali linisin pcb.
Offline BhongTech
  • Pogi/Ganda Points: 152
« Reply #106 on: November 21, 2011, 06:04:03 AM »
^ merun po yan sa plaza miranda,sa quiapo.
Offline Macgyver
    • MakerDude
« Reply #107 on: November 22, 2011, 07:37:39 AM »
marami nyan dun.  nasa  plastic ng mineral water.  tapos bili ka na lang nung magandang plastic dispenser na may syringe.
Offline MR. JUAN
« Reply #108 on: November 30, 2011, 03:57:34 PM »
Pa link naman po ng decent tutorial nito..
"One good reason for doing the right things   Today  ...is Tomorrow"
Offline Macgyver
    • MakerDude
« Reply #109 on: February 22, 2012, 11:47:18 AM »
bagal uminit nitong aeolus 906c ko.  mas mabilis pa yung luma kong newstar soldering iron.
ang tagal nang nakaset so 350c yung settings ko, di pa din makatunaw ng solder.  ano ba yun.
minax out ko yung calibration pot sa loob.
chineck ko temperature ng tip using fluke+thermocouple,  naka max sa 480C ang settings pero actual is 300-320c.
At 400c na setting, naglalaro sa 280 actual.
  • Pogi/Ganda Points: 412
« Reply #110 on: February 22, 2012, 12:02:55 PM »
Sis gawa tayo temp sensor para dyan...;D
anu maganda candidates aside from TC?
« Reply #111 on: February 27, 2012, 11:02:30 AM »
sis nangyari na sa aeolus ko yan, just replace the heating element. dami ko suspect na parts yun pala heating element lang ang problem. it cost 150 sa Manila city Plaza
Offline Macgyver
    • MakerDude
« Reply #112 on: February 27, 2012, 01:40:16 PM »
nakow.  kakadaan ko lang dun kahapon.  sayang.
  • Pogi/Ganda Points: 53
« Reply #113 on: February 27, 2012, 01:46:26 PM »
mas ok ata yun IRDA station magkano naman kaya..
« Reply #114 on: February 27, 2012, 02:00:41 PM »
Sakin ganyan din..pero bago yung filament..
Offline tolit_02
« Reply #115 on: March 04, 2012, 08:00:53 PM »
tanong ko lng po kung meron po nkka alam kung saan makakabili ng hot air nozzel na sqaure type yung pang tanggal ng mga bga chips
Offline ajadinomar
« Reply #116 on: June 21, 2012, 03:59:03 PM »
siguro ok din ang BAKU 898A, compact size sya, di masyadong maconsume sa space, tapos mabilis mag initalize heating ng solder.
Offline Milkyway
« Reply #117 on: July 27, 2012, 03:17:59 PM »
wala po yata square type, circle po lahat at available ito sa Quiapo(besides Quiapo church)
mas mabilis naman masira, tested ang aeolus brand pagdating sa hot air
Offline crimbuz
  • Pogi/Ganda Points: 6
« Reply #118 on: May 09, 2013, 09:00:09 PM »
sa quiapo... sa may plaza miranda katabi ng simbahan ng quiapo.. makakabili ka din dun ng cellphone accesories and parts..
ito ang hanap ko bilihan ng parts ng celpon sana meron pa to ngayon
Offline e-tronix
« Reply #119 on: May 09, 2013, 09:34:43 PM »
Irda station sino meron? And any review?
