Author Topic: About Electric fan  (Read 20091 times)
  • Pogi/Ganda Points: 231
About Electric fan
« on: April 23, 2009, 05:49:11 PM »
Sir pano po ba actual na Fuction ng Capacitor sa Electric fan. kasi pag mas Mastaas ang capacitance ay mas mabilis syang umikot kasi ay experiment to parallel same value. di po ba starter sopressor lang function nya dito?
About Electric fan
Offline miGs
Re: About Electric fan
« Reply #1 on: April 24, 2009, 12:38:38 PM »
The capacitor improves the power factor of the motor. capacitive reactance is inversely proportional to the capacitance, so the greater the capacitance, the smaller the capacitive reactance. The improvement in power factor explains the increase in speed when using capacitor with higher capacitance.
Offline BANNEDMemberAccount
  • Pogi/Ganda Points: 130
« Reply #2 on: April 24, 2009, 12:43:21 PM »
alam ko yung capacitor starter siya ng motor saka para mapaganda rin ang takbo ng motor
Offline Woots29
  • Pogi/Ganda Points: 344
  • asan si mojacko?
    • Woots Page
« Reply #3 on: April 24, 2009, 01:52:35 PM »
ah eh ang alamko rin starter kasi kapag ala yun ayaw umandar eh ;D
WootsPC2 Videos  Woots Page
insomartin
  • Guest
« Reply #4 on: April 24, 2009, 07:52:12 PM »
kung walang kapacitor hindi nya alam kung anong direction cia iikot. may sariling winding ang kapacitor for every revolution nang winding kailangan nang "tulak" galing sa kapasitor. mas mataas ang value mas mataas ang tulak. mas mabilis ngayon ang ikot. kung mabagal na yung ikot nang electric fan mo and kung smooth naman yung shafting. palitan mo na agad nang capasitor bago pa masira. madalas masunog din ang electric fan kung naka stuckup. on the case of pfc... it serves a different purpose. hindi lahat nang motor dapat lagyan nang pfc.
Offline ahlburuto
  • E&I tech.
« Reply #5 on: April 24, 2009, 08:18:53 PM »
What if palitan natin ng capacitor value yung sa electric fan, pwede kaya? meron kasi ngayong mga fan na number 1 pa lang eh napakalakas na ng ikot eh. Pwede kaya?
br
insomartin
  • Guest
« Reply #6 on: April 24, 2009, 08:23:17 PM »
oo naman if you want to experiment. pero don't change or get a higher voltage rating. wala naman mawawala kung gawin mong 1 farad yung capacitor nyan. pagaralan mo but use your common signs. kung alam mo nang nasusunog eh... tsk tsk
Offline Seigou
« Reply #7 on: April 24, 2009, 09:39:44 PM »
yan po ang schematic ng electric fan motor pag binaliktad po ang ends ng L4 ay babaliktad din po ang rotation ng shaft :)
pag tinaasan po ang value ng capacitor mas matagal po ito macharge kaya mas mataas po ang voltage na papasok sa coil kaya mas mabilis pag mas mataas ang value ng capacitor :) :D
  • Pogi/Ganda Points: 916
« Reply #8 on: April 24, 2009, 11:01:16 PM »
agree  :)
agree  :)
for me the same den sa kanila ....   bastah alam ko for starting purposes ang capacitor & improving the power factor  of the motor.. & being a have a fixed rotation  so dat the ventilation of the air have a fixed flow   hehehehehe    ;)  ;)  ;)  ;)   ;)
Offline Seigou
« Reply #9 on: April 24, 2009, 11:16:59 PM »
agree  :)
agree  :)
hehehe actually ang function ng capacitor sa electricfan ay phase limiter :) nililimit nya kung hanggang saang phase papasok ang kuryente sa coil :)
insomartin
  • Guest
« Reply #10 on: April 25, 2009, 01:01:26 AM »
http://www.physclips.unsw.edu.au/jw/electricmotors.html
paki explain yung phase limiter...
wala naman ako masyadong alam sa motors. pero MADAMING electric fans na akong narepair.
kung mapa PFC or Phase limiting hayaan na natin c ccasiser mag decide kung sino ang winner. hihihi.
Offline miGs
« Reply #11 on: April 25, 2009, 08:33:32 AM »
ang "tulak" na sinasabi mismo ang power factor improvement. during starting, induction motors have very low power factor, kaya the starting winding (in case of single phase motors) needs "push" from the capacitor. In case of three-phase, starting capacitors are not needed since the windings are displaced by 120 degrees.
Offline robbietan
  • Pogi/Ganda Points: 17
« Reply #12 on: April 25, 2009, 02:50:35 PM »
in a single phase AC induction motor needs a rotating magnetic field so that torque could be develop by the motor in order for it to start rotating. a capacitor is used to provide a phase shift in the voltage so that the motor could develop enough torque to start.
for a 3 phase induction motor, no capacito is needed to start as the 3 phase voltgae are already 120 degrees out of phase. capacitors added to a 3 phase motor are designed to improve the motor efficiency by improving power factor.
apqi.ph
« Reply #13 on: April 27, 2009, 05:41:41 PM »
salamat sa inyong lahat malaking kaalaman ito sa akin kung paano nag pa function ang capacitor sa winding ng electric fan. napaka halaga pala ng isang capacitor .. salamat naging malinaw na sa akin at hopely na nakatulong din itong forum sa iba..
Offline aira93
« Reply #14 on: August 01, 2009, 04:55:52 PM »
It is also common to use electric fans as air fresheners, by attaching fabric softener sheets to the protective housing. This causes the fragrance to be carried into the surrounding air.
________________
Bathroom fan
Offline 9 Volts
  • Pogi/Ganda Points: 7
  • Moving Target
« Reply #15 on: August 31, 2009, 10:41:45 AM »
Mga idoL panu ba gawain ung electric fan namin na standard eh..3 na ung sira eh... ayaw umikot parang kelanga ng langis peo pag nilagyan naman ayaw parin umikot ... panu po ba?? tnx
If we hear, we forget; if we see, we remember; if we do, we understand. -- Proverb
Offline robbietan
« Reply #16 on: September 02, 2009, 09:43:32 AM »
if mahirap ikutin ang fan kahit walang kuryente, mechanical problem
if mahirap ikutin kapag may kuryente, electrical problem
mechanical problems - bearings, alignment, etc
electrical problems - windings, capacitor, etc
apqi.ph
Offline bj_santino
« Reply #17 on: September 02, 2009, 11:32:34 AM »
hello sa lahat. ano po ba talaga ang common na masira sa elec fan?
Offline 9 Volts
  • Moving Target
« Reply #18 on: September 02, 2009, 02:36:58 PM »
Anu po ba ang regular maintenance ng electric fan???
Dami ko na kcng nakatambak na d ko magawa na electric fan..
« Reply #19 on: September 10, 2009, 10:45:33 PM »
mostly  pag walang internal resistance ang e.fan kahit nakapress on   commonly trouble talaga na open  iyong thermal fuse sa loob ng motor
