Author Topic: Globe Tattoo's USB HSDPA Modem:Interfacing to Hyperterminal and PL  (Read 21608 times)
Offline jordandino
Re: Globe Tattoo's USB HSDPA Modem:Interfacing to Hyperterminal and PL
« Reply #140 on: August 10, 2010, 05:20:33 AM »
pahingi din ms tambay_7 :D
« Reply #141 on: August 10, 2010, 10:10:25 AM »
ok no prob... ;) ill upload it pag-uwi ko :)
Offline madzie71
« Reply #142 on: August 10, 2010, 09:22:49 PM »
Pahingi din po...
Offline carlsfootprints
  • Pogi/Ganda Points: 25
« Reply #143 on: August 14, 2010, 03:29:59 AM »
ang ganda mo mother7..
up for the link.. hehe ;D
never saturate..
« Reply #144 on: August 14, 2010, 05:17:57 AM »
eto na po :)
http://www.badongo.com/file/23873988
8KB na zip file... two files ang naanjan, yung application at yung sample script file
nilagyan ko ng show ASCII hex para makita yung mga line feed...
post nyo lang dito kung may suggestions/comments kayo for the improvement of the app. :)
this app is currently tested with USB HSDPA Globe Tattoo Modem...
« Reply #145 on: August 14, 2010, 05:48:46 AM »
quick update:
naglagay ako ng handshaking option,
http://www.badongo.com/file/23874165
« Reply #146 on: August 14, 2010, 06:50:11 AM »
Ang ganda mo talaga sis. Baka naman pwede pakisend na rin source code mo.
Offline dummy_c
  • Pogi/Ganda Points: 162
« Reply #147 on: August 14, 2010, 09:26:39 AM »
quick update:
Ang galing po ninyo master.. +1. Nag try po ako mag send ng msg gamit nyan pero hindi ko kaya. Heto po yung resulta.
Sending Command: AT
Delay: 100msec
Received Reply:
OK
Sending Command: AT+CMGF=1
Delay: 100msec
Received Reply:
OK
Sending Command: +CMSS: 4
Delay: 100msec
Received Reply:
===========END===========
yung msg ko po na save na sa sim memory #4. Ang msg ay nag check lang ng balance ng load ko. Para di ma bawasan ang load ko, hehe. Paano ba ito gawin master? Sorry for being so noob.
« Reply #148 on: August 14, 2010, 11:22:34 AM »
Sending Command: AT
Delay: 100msec
Received Reply:
OK
Delay: 100msec
Received Reply:
OK
Delay: 100msec
Received Reply:
baka bitin lang sis yung delay mo... gumana naman siya sa akin...
eto yung exact script
AT+CMGF=1|TRUE|500|None
AT+CMGL="REC UNREAD"|TRUE|3000|Just to show wala pang unread messages
AT+CMSS=18|TRUE|5000|None
AT+CMGL="REC UNREAD"|TRUE|3000|None
eto yung result
Delay: 500msec
Received Reply:
OK
Sending Command: AT+CMGL="REC UNREAD"
Delay: 3000msec
Received Reply:
OK
Sending Command: AT+CMSS=18
Delay: 5000msec
Received Reply:
+CMSS: 0
OK
+CMTI: "SM",28
Delay: 3000msec
Received Reply:
+CMGL: 28,"REC UNREAD","7176796669",,"10/08/14,11:20:08+32"
Your Account Balance as of 08/14/2010 11:20 is 0.00 You also have 0 remaining FREE texts.
OK
heheheh... nakakahiya man ... wala akong load ngayon :D :D :D ;D ;D ;D
maybe in the future version tanggalin ko na yung delay sa script file at antayin na lang yung ERROR or OK string, tapos may customizable timeout kung sakaling di sumagot ang GSM mode.
« Reply #149 on: August 14, 2010, 11:27:00 AM »
written in C#:
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Text;
using System.Windows.Forms;
using System.IO.Ports;
using System.IO;
namespace AT_Command_Script_Processor
    public partial class frmATScriptProcessor : Form
        const string FRM_TITLE="AT Command Script Processor 00.08.01";
        public frmATScriptProcessor()
            InitializeComponent();
        private void frmATScriptProcessor_Load(object sender, EventArgs e)
        this.Text=FRM_TITLE;
        tssStatusScrFile.Text="";
        cmbSerial.Items.Clear();
        cmbSerial.Items.AddRange(SerialPort.GetPortNames());
        if(cmbSerial.Items.Count!=0)
            cmbSerial.SelectedIndex=0;
        cmbBaud.Items.Clear();
        cmbBaud.Items.AddRange(new string[]{"9600","19200","115200"});
        cmbBaud.SelectedIndex=0;
        cmbHandShaking.Items.Clear();
        cmbHandShaking.Items.AddRange(new string[]{"None","RequestToSend","RequestToSendXOnXOff","XOnXOff"});
        cmbHandShaking.SelectedIndex=0;
        private void btnOpenFile_Click(object sender, EventArgs e)
        if(ofdScriptFile.ShowDialog()==DialogResult.OK)
            //txtScriptFile.Text=ofdScriptFile.FileName;
            tssStatusScrFile.Text=ofdScriptFile.FileName;
        private void btnRun_Click(object sender, EventArgs e)
        string SCRFile=tssStatusScrFile.Text.Trim();
        txtResult.Clear();
        Application.DoEvents();
        if(File.Exists(SCRFile)==true)
            SerialPort mySer=new SerialPort(cmbSerial.SelectedItem.ToString(),int.Parse(cmbBaud.SelectedItem.ToString()));
            mySer.Handshake=(Handshake)Enum.Parse( typeof(Handshake),cmbHandShaking.SelectedItem.ToString());
            mySer.WriteTimeout=1000;
            try
                string [] FileAllLines=File.ReadAllLines(SCRFile);
                try
                    {mySer.Open();}
                catch
                    MessageBox.Show("Error Opening Serial Port!");
                    return;
                btnRun.Enabled=false;
                foreach(string x in FileAllLines)
                    string temp=x.Trim();
                    if(temp.StartsWith(@"//"))
                        continue;
                    string [] spliString=temp.Split(new char[]{'|'},StringSplitOptions.RemoveEmptyEntries);
                    if(spliString.Length!=4)
                        continue;
                    int delay=0;
                    bool boolReadRx=false;
                    string ATcmd="";
                    try
                        delay=int.Parse(spliString[2].Trim());
                        boolReadRx=Convert.ToBoolean(spliString[1].Trim());
                        ATcmd=spliString[0].Trim();
                    catch
                        MessageBox.Show("Error Parsing Data, Please Recheck AT Script File: " + temp,FRM_TITLE,MessageBoxButtons.OK,MessageBoxIcon.Stop);
                        return;
                    mySer.DiscardInBuffer();
                    txtResult.AppendText("Sending Command: " + ATcmd);
                    txtResult.AppendText("\r\n");
                    try
                        mySer.Write(ATcmd);
                        mySer.Write(new byte[]{0x0D},0,1);
                    catch
                        MessageBox.Show("Error Sending Data to GSM Modem!",FRM_TITLE,MessageBoxButtons.OK,MessageBoxIcon.Stop);
                        return;
                    txtResult.AppendText("Delay: " + delay + "msec");
                    System.Threading.Thread.Sleep(delay);
                    if(boolReadRx)
                        string readSer=mySer.ReadExisting();
                        if(chkShowEndHex.Checked)
                            for(int ctr=0;ctr<0x20;ctr++)
                                readSer =readSer.Replace(String.Format("{0}",(char)ctr),String.Format("<0x{0:X2}>",ctr));
                        txtResult.AppendText("Received Reply:\r\n");
                        txtResult.AppendText(readSer);
                    txtResult.AppendText("===========================\r\n");
            finally
                btnRun.Enabled=true;
                mySer.Dispose();
                System.GC.Collect();
            txtResult.AppendText("===========END===========\r\n");
        else
            if(SCRFile==String.Empty)
                MessageBox.Show("Choose file first!",FRM_TITLE,MessageBoxButtons.OK,MessageBoxIcon.Stop);
            else
                MessageBox.Show("File does not exist!",FRM_TITLE,MessageBoxButtons.OK,MessageBoxIcon.Stop);
        private void btnCopyToClipBoard_Click(object sender, EventArgs e)
        if(txtResult.Text.Length!=0)
            Clipboard.Clear();
            Clipboard.SetText(txtResult.Text);
medyo magulo pa yung code... I will optimize it pag may time :) ;)
Offline dummy_c
« Reply #150 on: August 15, 2010, 08:28:27 AM »
Ahh right sa delay lang pala. Marami pong salamat boss master manay 7.+1. Ginamit ko na yung application mo to send, read and delete messages.
written in C#:
using System;
using System.Data;
using System.Text;
using System.IO;
        txtResult.Clear();
            try
                try
                    {mySer.Open();}
                catch
                    return;
                        continue;
                        continue;
                    int delay=0;
                    string ATcmd="";
                    try
                    catch
                        return;
                    try
                        mySer.Write(ATcmd);
                    catch
                        return;
                    if(boolReadRx)
            finally
                mySer.Dispose();
        else
            else
            Clipboard.Clear();
Kailangan ko talagang matuto ng C...  :'(
« Reply #151 on: August 15, 2010, 09:51:29 AM »
Ako rin nose bleed  sa C#. C# dot net ba ginamit mo sis?
« Reply #152 on: August 15, 2010, 12:07:47 PM »
yup... Visual C# 2010 Express Edition ang ginamit ko. nakatarget yang app sa .NET Framework 2.0
« Reply #153 on: August 19, 2010, 05:27:37 AM »
« Reply #154 on: August 19, 2010, 08:53:21 AM »
Sir sa VB 2010 paano ko iseset sa .net framework 2?
« Reply #155 on: August 19, 2010, 01:35:06 PM »
di ako sure sa VB, pero sa project properties lang yun...
« Reply #156 on: August 20, 2010, 05:45:09 PM »
Ok sige I'll try that.
« Reply #157 on: August 21, 2010, 02:39:38 PM »
AT Command Script Processor Version 00.08.02
Revision:
- Added Option to adjust RX Buffer Size
- TX Buffer Size set to 1000
- Special Command for sending hex number: __@HEX   Usage: __@HEX=AA|TRUE|100|None
Offline cool_Taurus
« Reply #158 on: August 21, 2010, 04:20:13 PM »
Hi,
In my system, I need to use this modem in this two mode : Data and Voice.
For the Data part, no problems.
But for the voice part, I have no sound.
To call someone, I use AT commands in a VB.NET application.
The communication are OK. I receive or i can send a call, but no sound pass beetween the two parts.
Of course, with AT commands, I change the sound and don't put in HP mode :
AT+CMUT = 0
AT+CLVL = 4
If I use Mobile Partner application, The voice are up. If I compare the AT log with mine, the two applications send the same commands.
I think the voice data are not transmit to the audio systems(HP, microphone)
Excuse me for my bad english.
Thanks to help me !
Offline jordandino
« Reply #159 on: August 22, 2010, 09:01:02 PM »
written in C#:
using System;
using System.Data;
using System.Text;
using System.IO;
        txtResult.Clear();
            try
                try
                    {mySer.Open();}
                catch
                    return;
                        continue;
                        continue;
                    int delay=0;
                    string ATcmd="";
                    try
                    catch
                        return;
                    try
                        mySer.Write(ATcmd);
                    catch
                        return;
                    if(boolReadRx)
            finally
                mySer.Dispose();
        else
            else
            Clipboard.Clear();
tnx sa pagshare sir seven!
