Author Topic: Globe Tattoo's USB HSDPA Modem:Interfacing to Hyperterminal and PL  (Read 21618 times)
Offline lcg
Re: Globe Tattoo's USB HSDPA Modem:Interfacing to Hyperterminal and PL
« Reply #160 on: October 10, 2010, 11:05:26 PM »
wala po bang problem kung gusto kong magsend ng 50 messages in one minute?  gagawa kasi ako ng app na mgsesend ng text after an event (button click, or pag press ng enter).  May delay po ba?  kung meron tolerable naman po ba na delay?  thanks
« Reply #161 on: October 11, 2010, 08:16:56 AM »
Usually the delay depends on the GSM module. I don't know how to use multiple recipient. Try to check the AT command set of your GSM Module.
« Reply #162 on: October 11, 2010, 08:45:18 AM »
Mukhang hindi kakayanin ng isang usb modem or even a gsm modem yung 50 messages/minute, use multiple usb/gsm modems.  Sa trials ko, I can only send about 4~5 messages/sec  in the first few seconds tapos nabubulunan na yung gsm modem.
« Reply #163 on: October 11, 2010, 08:54:36 AM »
For those na tinatamad or hindi marunong magcompile ng vb.net you can also use Brays Terminal, pwede mo istore sa macros yung mga AT commands na kalimitan inyong ginagamit.
Offline lcg
« Reply #164 on: October 14, 2010, 11:25:13 AM »
sir alyas, wla po bang way to go about this problem?  anu po bang modem type dapat kung kelangan ng 50 msg per minute?  super noob po kasi ako dito, mostly database applications ginagawa ko eh.  thanks.
Offline nan
« Reply #165 on: October 26, 2010, 03:31:13 AM »
ate seven ano ung MCU?
« Reply #166 on: October 26, 2010, 09:23:14 AM »
Yung mga gsm modems din kasi, hindi naman sila designed to send sms that fast, limited kasi yung ram at processing power ng mga mcu/mpu na gamit.
Gamit ka siguro  ng apat na usb modems pero di ko alam paano implement ito kasi di naman ako magaling sa programming.  Pero baka may limitation pa rin yan kasi, apat na modems ang maguunahan magsend ng sms sa iisang channel ng gsm signal sa isang particular cell site(SDCCH) tapos kalaban mo pa yung ibang mga sms texters, baka sa cell site level naman magkaruon ng temporary congestion.  Kung sms via 3g siguro pwede na dahil mabilis na yung channel.
Kapag ganyan kasi kabilis, usually direct sa SMSC server na ng telco provider ang connection via ip using smpp, cimd2 or ucp protocols
Offline glutnix_neo
  • Pogi/Ganda Points: 166
    • Underground Workbench
« Reply #167 on: October 26, 2010, 11:09:38 AM »
Microcontroller Unit.
Offline doom
« Reply #168 on: November 03, 2010, 04:45:09 PM »
until now ok pa po ba ang free internet access ng globe tattoo?
Offline doom
« Reply #169 on: November 03, 2010, 04:51:18 PM »
eh ano po kaya maganda modem kasi gumagawa din ako ng vb6 program na hindi dapat mabubulunan ang modem..gamit ko po ay smart bro..thanks a lot
Offline helirage
« Reply #170 on: November 14, 2010, 04:24:29 PM »
hi mga ka e-lab ... i tried this things pero some of the AT commands doesn't work (read, write, and send) , my usb modem is globe tattoo, e1552, latest firmware, ung nasa red box. alam kong ung usb na to cannot be unlocked and globe rin pal disabled the AT commands
Offline nan
« Reply #171 on: November 23, 2010, 03:40:56 AM »
mga bro okey pa ba yung load mo na 50 unlimited sa globe? wala ba expire yun.
Offline chairless
« Reply #172 on: December 11, 2010, 08:51:30 AM »
pwede po ba ito sa windows 7..?
Offline mini_mouse ^_^
  • Pogi/Ganda Points: 7
  • he's keeping it up, I should take pride :)
« Reply #173 on: December 20, 2010, 08:15:00 AM »
hello po, pahelp din po.. gagamit po ako ng zilog, z8f082a po. then visual basic 6 inteface po xa. connect ko po xa sa serial port.. tyhen yung isesend na data ng mcu, mababasa po sa visual basic... help po, paano po yung concept..
after po na mabasa yung data, yung globe tattoo usb modem po ay kaylangan mgtext...
...I'm thankful each and every day, coz I found you...
Offline guy_gwapo
« Reply #174 on: September 04, 2011, 11:58:38 PM »
gandang gabi po sa lahat....how about poh sending free SMS from your pc using SMART/GLOBE broadbandee......using vb6 or vb.net....para walang gastos po yung gagamit sa system??.....kahit lang po ung free send ng SMS galing sa broadband ok na poh....
pa help po plsssss............
