Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
Digital Electronics
Microcontroller/Microprocessor Unit Projects and Programming
PIC Microcontrollers
(Moderators:
marcelino
paranz
Simple development board for 40 pin PICmicro
« previous
next »
Print
Pages:
1
2
3
4
Go Down
Author
Topic: Simple development board for 40 pin PICmicro (Read 6052 times)
marcelino
Moderator
Solar Power Satellite
Pogi/Ganda Points: 258
...keep moving forward! - Robinson's
Re: Simple development board for 40 pin PICmicro
Reply #40 on:
June 05, 2010, 07:37:19 PM »
Quote from: akhen on June 05, 2010, 06:56:44 PM
tita marce how about 7 segment parang wala ata... hehe
oo nga eh... tama ka. naisip ko na yan nung makita ko yang kay sis paranz.
eto ang nasa isip ko.
1. UART (with MAX232 of course)
2. 4 seven segment (multiplexed)
3. LCD (4 data pins only)
4. DS1307 (or 24LC512) for I2C
6. LEDs
7. buttons
8. headers for GPIOs
9. pots and LM35 for ADC
10. BOOTLOADER! - elab version of microchip's bootloader!
yan ang mga nasa isip ko... pero wala naman akong time gawin! heheheh
Logged
Reply #40 on:
akhen
Diesel Generator
Pogi/Ganda Points: 47
Gender:
"Learning is good but application is 100x better!"
Reply #41 on:
June 05, 2010, 07:54:44 PM »
share ko sayo free time ko tita... hehe
i will surely build it pag natapos mo... moral support muna ako... hehe
Logged
"kung hindi ako, sino? kung hindi ngayon, kailan?"
http://www.philrobotics.com/
http://www.e-gizmo.com/
http://www.seabreezecomputers.com/encrypter/
Reply #41 on:
studyante
Size AA Battery
Pogi/Ganda Points: 0
Reply #42 on:
September 25, 2010, 07:58:37 AM »
sir dun sa sl1 po ba ikakabit yung pickit2?
sorry medyo beginner palang po ako sa pic
Logged
Reply #42 on:
tiktak
Gas Turbine
Pogi/Ganda Points: 204
Gender:
Reply #43 on:
September 25, 2010, 08:05:14 AM »
^doon nga
Logged
8051 stuff
Reply #43 on:
studyante
Size AA Battery
Reply #44 on:
September 25, 2010, 08:11:49 AM »
salamat sir..hehe paano ko po malalaman kung paano siya ilalagay? yung leftmost na pin ng pickit2 dapat saan po nakalagay na pin? isa pa pong tanong pwede po bang baguhin yung crystal na 20Mhz? ang meron lang kasi ako yung 18.432 MHz at 17.743Mhz na crsytal
Logged
Reply #44 on:
tiktak
Gas Turbine
Gender:
Reply #45 on:
September 25, 2010, 08:31:30 AM »
yung pin1 ng pickit2 ay MCLR, so dun sa mclr din ng board sya ikakabit, yup pede naman palitan yang crystal
Logged
8051 stuff
OPTIMUS PRIME
Diesel Generator
Pogi/Ganda Points: 28
Gender:
Reply #46 on:
September 25, 2010, 09:19:03 AM »
ok lang yan pag di timing critical ang application.
Also check the compiler you are using kung nag susupport cya ng butal na crystal speed.or may provision to declare it sa lood ng program mo
Logged
studyante
Size AA Battery
Reply #47 on:
September 25, 2010, 06:05:22 PM »
sirs nalilito talaga ako sa number ng pwm outputs ng pic16f877. kasi dun sa pinouts niya may pwm0 hanggang pwm 3 pero sa datasheet sabi dalawa lang ang pwm na output niya.
Logged
studyante
Size AA Battery
Reply #48 on:
November 24, 2010, 05:29:36 PM »
sir marcelino, binuo ko po yang circuit niyo pero nung nagdownload po ako ng hex file walang nangyayari. pickit2 po yung gamit ko at mikroc pro for pic ang gamit kong ide. pic16f877a po yung gamit ko na mcu. nagdodownload at write naman po siya pero wala pong lumalabas sa output pins na intended. eto po yung program at hex file.
void main(){
TRISC = 0x00;
PORTC = 0x00;
PWM1_Init(5000);
PWM1_Start();
PWM1_Set_Duty(192);
while(1);
:100000008B28FF3FFF3F8312031321088A0020083B
:100010008200080083120313FB01FA01F90180300A
:10002000F800F10CF00C031C1E287408F907750881
:100030000318750FFA070318FB0A0310F01F262890
:100040007408FA0775080318750FFB07FB0CFA0C08
:10005000F90CF80C031C11287B08F3007A08F20055
:100060007908F1007808F000080083120313950165
:100070001712971208008316031307118312121523
:100080000C309704080003208A110A128000840AA9
:10009000A00A0319A10AF003031D432808008316D0
:1000A00003131208013EF000F1010318F10A831254
:1000B0002208F400F5010A200630F2007008F4006E
:1000C0007108F500720803196A28F50CF40CF51391
:1000D000FF3E63280430F1007408F0007108031932
:1000E0007528F00D7010FF3E6F2883120313303017
:1000F0007005F3007408F0007508F100F10CF00CC5
:10010000F113F10CF00CF113700895000F30970506
:10011000730897040800831603138701831287016D
:1001200012149210F9308316920035203B20C03013
:10013000A2004F209A289B28FF3FFF3FFF3FFF3F31
:02400E00492F38
:00000001FF
Logged
marcelino
Moderator
Reply #49 on:
November 24, 2010, 05:47:11 PM »
try mo nga yan sa proteus kung magwork?
Logged
studyante
Size AA Battery
Reply #50 on:
November 24, 2010, 07:16:32 PM »
san po makakadownload ng proteus at nung crack nun?
Logged
studyante
Size AA Battery
Reply #51 on:
November 25, 2010, 04:37:28 PM »
sir gumamit po ako ng real pic simulator at gumana po siya. kapag nadownload ko na sa board, wala pong lumalabas sa mga pins ng PORTB..
Logged
amadjo01
Lead Acid Battery
Pogi/Ganda Points: 14
Gender:
Meow....
Reply #52 on:
December 21, 2010, 02:31:13 PM »
ngayon ko lang to nakita ah,,,,
napakahusay po mga master.....
Logged
Mayor Johnaray
Gas Turbine
Pogi/Ganda Points: 238
Reply #53 on:
December 21, 2010, 03:54:56 PM »
Up nga natin... any updates?
Logged
OPTIMUS PRIME
Diesel Generator
Gender:
Reply #54 on:
December 21, 2010, 04:45:54 PM »
Quote from: Mayor Kuya Johnaray Geek on December 21, 2010, 03:54:56 PM
Mukha may board ako nito ...diba may PIC16f877a ka bossing---bigay ko na lang sayo. Wag ka lang tatawa sa hinang ko
Logged
dbx232629
CR2032 Battery
Reply #55 on:
September 08, 2011, 05:35:38 PM »
any update? ginawa ko yung bigay ni sir paranz na schematic. i wonder kung pwede ipost yun dito. nagawan ko na rin sya ng PCB kaso may nakikita pa akong mga mali kaya maganda mcritics para maayos.
Logged
OPTIMUS PRIME
Diesel Generator
Gender:
Reply #56 on:
September 08, 2011, 06:19:08 PM »
Feel free ijo
Logged
amadjo01
Lead Acid Battery
Gender:
Meow....
Reply #57 on:
September 09, 2011, 06:50:14 PM »
yeah post it....
Logged
dbx232629
CR2032 Battery
Reply #58 on:
September 13, 2011, 03:20:27 PM »
Uploaded with
ImageShack.us
Logged
dummy_c
Diesel Generator
Pogi/Ganda Points: 162
Gender:
If I die 2nyt, 8's bcoz maimai is not at my side!
Reply #59 on:
September 13, 2011, 04:12:32 PM »
^^^ Nice! +1
Pwede maka hingi din ng schem niyan para mapag kunan din ng idea? Salamat po.
Logged
Reply #59 on:
Print
Pages:
1
2
3
4
Go Up
« previous
next »
Digital Electronics
(Moderators:
marcelino
paranz
