Hi, I have a development for PIC programming. I made myself I will post schematic , pcb, and how to make this hope you this would be a help
its a pic programmer hardware, not a development board
sir paranz, i was actually looking for the in-circuit programming interface. because basically dev board is using that one, right? I just want to confirm it.I will be implementing it to my incoming project so that the specific task can be change to a particular need.actually the idea originally came from sir motion55. hehehe
actually po im not familiar sa circuit posted above, but its a programmer if im not mistaken.if you want the in-circuit programming interface, i think ok na ang inchworm ICD2.The P16Pro programmer im using can also be used for ISP (5 wires) kaya lang you have to make some modifications sa target board na gusto mong gawin.
I'll go for the ICD2, walang masyadong wires... datasheet even says that icsp can be implemented 2wires for debuging and 3wires for programming.well got to do more readings to make sure!kaya nga inaabangan ko ang paggawa mo ng inchworm! hehehehe
hehe i just bought 20 Mhz xtal from e-gizmo, so completo na siguro ako components for the inchworm.Kaso wala ako BC548/BC558 transistors, so i might use the BC547/BC557. Oki na rin siguro The max232 circuit uses 10 uF cap. instead of the recommended 1 uF sa MAX232 datasheet, i'll see if its still ok. And all 1/4 watt resistors i will use the ordinary variety.By sunday start ko na i-assemble yan. Hopefully it will work.
