Author Topic: sensor that can detect human body  (Read 5042 times)
Offline marcasjr™
« on: May 04, 2009, 05:34:22 PM »
we are having a project called  Person counter,ung aming prof suggest na hindi basta bibilangan lng nya ung dadaan,baka kac daw object ung dumaan,kelangang malaman person talaga ung dumaan ,ano po kayang sensor ang pdeng gamitin para ma detect human body?
tnx for replies...
Offline marcasjr™
Re: sensor that can detect human body
« Reply #1 on: May 04, 2009, 09:36:40 PM »
up
Offline lightelectro
  • Pogi/Ganda Points: 51
    • Android Tablet Lover
« Reply #2 on: May 04, 2009, 10:02:56 PM »
siguro thermal sensor. siguro iba naman ang temperature nang tao kumpara sa hayop. baka ibang members meron pang suggestions. 8)
LATEST ANDROID TABLET NEWS
Offline Born2BeWired
  • Pogi/Ganda Points: 168
    • e-Gizmo Mechatronix Central
« Reply #3 on: May 04, 2009, 10:22:46 PM »
A PIR sensor detects human body by resolving its temperature compared to the ambient. Yun lang prone ito sa error, kasi any other object that is a little hotter or colder than the surroundings will trigger a count.
Otherwise, mukhang machine vision lang ang uubra dito sa thesis mo... Yung mga ganitong thesis is not for the undergrads. In fact kakaunti lang ang existing system made exclusively for human (facial) detection, like the one now used in UK (i think) select places. Im sure it took an army of PHDs to build this system.
The only possible option I can think of is to require people to press a push button as they pass through.  ;)
Offline Cross Talk
« Reply #4 on: May 04, 2009, 10:47:14 PM »
hindi ba pwede mechanical? like yung sa MRT-LRT?
Delikado pala maging impakta!
« Reply #5 on: May 04, 2009, 11:11:11 PM »
You'll need to combine sensors for this application.  You can use an  ir beam sensor  or ultrasonic sensor in combination with a PIR sensor.  The PIR sensor will be used to confirm if the object is human or not.
  • Pogi/Ganda Points: 915
« Reply #6 on: May 04, 2009, 11:28:47 PM »
oo nga agree aku   to avoid  false triggering signal / error    we need to combine sensor application...  gaya ng IR sensor for beam-break detector to know na may dumaan, temperature sensor to identify what kind of object pass through based on its temperature, ultrasonic sensor if ders a feed back sound came from a living organism..    & etc...  to combine a specific PIR detector..
« Reply #7 on: May 04, 2009, 11:31:11 PM »
pero i think we need more farther studies regarding that circuit...   kasi maraming error   mangyayari....      try natin  hintayin yung  idea & suggestion ng iba...
im xur makakatulong yun...   :D  :D  :D  :D  :D
Offline the_next_big_name
« Reply #8 on: May 05, 2009, 05:41:43 PM »
kailangan may camera at gamitan mo ng face detection algorithm or edge detection algorithm para madetect mo kung human nga yung dumaan
Offline akhen
  • Pogi/Ganda Points: 47
« Reply #9 on: May 05, 2009, 07:10:00 PM »
I agree with the idea of using 2 sensors connected in series so that they should both be satisfied to make a count. Yun nga lang may problema pa din talaga sa efficiency naminimize lang yung posible error by using 2 sensors.
Offline marcasjr™
« Reply #10 on: May 05, 2009, 07:32:13 PM »
tnx pow sa mga replies,un po ba PIR mahirap bang hanapin d2 un?geh hanap ako ng circuit para dun,kelangan daw talagang ma detect kung human o hindi...
« Reply #11 on: May 05, 2009, 07:56:02 PM »
oo nga noh...   pwde din ganun  (-_-)
« Reply #12 on: May 05, 2009, 08:39:56 PM »
You dont need those fancy hitech out of reach techy stuff to achieve your objective.
Just list down qualities or features of humans that can be detected using ordinary sensors and combine these to achieve your result.
Ang human may dalawang paa so gamit ka ng active ir sensor that has to be interrupted twice in a certain amount of time.  Ang humans eh mas mataas ng di hamak sa mga hayop so you could place an ir sensor at a certain height to detect this criteria.  If all the criterias are present, then you can be certain na its human.
Yung PIR sensor actually ay motion detector that relies on heat to detect motion.  Meron siyang sensitivity adjustment so bigger lifeforms like humans will emit higher amount of heat kaya pwede mo rin gamitin as heat sensor to detect human presence but only when it is moving.
Just combine the outputs of several sensors and couple it with logic and you have your human detector.
Offline akhen
« Reply #13 on: May 05, 2009, 08:43:36 PM »
madaming available na PIR sensor sa mga electronics store lalo na sa raon. Yung sensitivuty ng PIR sensor sa pagdetect kung tao talaga o hindi ay hindi ganon kaacurate since body temp lang ng tao ang sinesense nya.
« Reply #14 on: May 05, 2009, 10:13:01 PM »
naku...mahihirapan syang lalo nyan...at parang wlang direction...mas ok na yun...kahit ordinary still cam...i-analyze nya yung picture using face detection/ege detection algorithm....solve na problem nya...you dont have to spend a lot of money...kase yung math involve napag-aaralan sa school at tsaka madami resources sa net...
Offline carlsfootprints
  • Pogi/Ganda Points: 25
« Reply #15 on: May 06, 2009, 02:17:32 AM »
i think maganda ung suggestion ni sis hunyango.. since, educational project ito.. maganda na maeexpose sila sa iba't ibang sensors at methods.. at the same time ung designing ng prototype skills nila ay magagamit at maeenhance..for learning na din nila and experience.. pwede nilang paghalohaluin lahat pati ung face detection algorithm (pano po ba un?  :))kung kaya.. group work naman ata eh.. gastos nga lang and time..
sis marcasjr™, kayo pa rin naman po ung magdedecide.. it's good kasi nagkakaroon kayo ng maraming options.. more power and goodluck po sa project nyo.. update nyo na lang po kami  ;D :) ;)
never saturate..
Offline RaffT
  • Pogi/Ganda Points: 103
  • more on R-n-D
    • MY Bots
« Reply #16 on: May 06, 2009, 06:24:43 AM »
PIR = sense BODY heat
IR beam = for a passing human to "cut" the light
LDR = to sense the shadow of a human passing by
AND the 3 sensors and you will get a valid "HUMAN" passing signal...
Offline zer0w1ng
  • Pogi/Ganda Points: 305
    • The Cebuano Geek
« Reply #17 on: May 06, 2009, 07:00:53 AM »
Another way, but much more complicated is to use a camera.
Then using DSP detect faces (face recogition, pattern matching algorithm).
The Cebuano Geek
« Reply #18 on: May 06, 2009, 08:08:14 AM »
I also suggest turnstile (yung gamit sa LRT) then mix it with two IR detector.
Offline THXneo
  • Pogi/Ganda Points: 34
  • DJ, Home Theater Fanatic
« Reply #19 on: May 06, 2009, 11:48:13 AM »
video camera+ software
yan ang da best. 1-way,2-way, vise versa kaya nya bilangin.
walang paltos
check mo sa www.pelco.com
More to Lose by Seona Dancing
