can you please give us your idea how to display ALARM and CURRENT TIME, using or not using multiplexers..using TTL..we are using 4 Seven Segment Displays for both hours and minutes12:00this should how it works: for ex, your current time is 12:00AM and we want to set the alarm at 12:30AM, by using for example a switch we can change the display to its ALARM mode, and then after switching it again, the 7SegDisplay should display the current time..we appreciate your help..
Mukhang yung kailangan nyo ay merong MODE button. Yung tipong may alarm mode at current time mode tama po ba?In that case, mukhang kumplekado yan using logic gates. Mas madali ata yan using MCU.
kung marunong lng kami gamit MCU bkt hndi..pure TTL lng, may alarm mode may time mode, nka relay switches un pareho..tas hiwalay p ung ALARM on/off..bale 5 switches ang gamit..1. ALARM on/off (SPDT)2. ALARM mode (relay switch)3. TIME mode (relay switch)4. HOUR (tack switch)5. MINUTE (tack switch)thanks po s opinions, we appreciate it..
sad to say MCU is not allowed to use in our project..we use 74LS90 Decade counters for the digiclock..please, we badly need help..thanks a lot..
