Author Topic: sony trinitron KV-20M20  (Read 1622 times)
Offline jet2081
« on: May 17, 2009, 11:19:22 PM »
ano po ba ang cira pag on ng power mamatay ulit after 3 seconds na parang ayaw tumuloy meron naman po b+
Offline tdh7700
  • Pogi/Ganda Points: 25
Re: sony trinitron KV-20M20
« Reply #1 on: May 17, 2009, 11:25:48 PM »
sir lang volts ung b+ nya?.. ano na po nga na check nyo? more info po.
ORDONIO ELECTRONICS
public mkt. sq pangasinan ph.
Offline jet2081
« Reply #2 on: May 17, 2009, 11:41:59 PM »
b+ po nya is 110v,
Offline tdh7700
« Reply #3 on: May 17, 2009, 11:49:06 PM »
na check  nyo na pa ba vertical at hor section?
ORDONIO ELECTRONICS
Offline jet2081
« Reply #4 on: May 18, 2009, 12:12:49 AM »
na check ko po ung h.out ok naman po vertical section dko po alam ang dapat icheck newbie lang po ala po naturo samin mabuti sa skul kya po d2 po ako natututo sa electronicslab buti na lng po madami ang kagaya nyo na mababait
Offline Woots29
  • Pogi/Ganda Points: 344
  • asan si mojacko?
    • Woots Page
« Reply #5 on: May 18, 2009, 09:53:35 AM »
paki check kung kung ilang blinks ung led
baka OCP yan
WootsPC2 Videos  Woots Page
Offline jet2081
« Reply #6 on: May 18, 2009, 10:01:02 AM »
baka OCP yan
sir ala po ilaw yung led
Offline jet2081
« Reply #7 on: May 18, 2009, 10:03:45 AM »
baka OCP yan
sir gud am ano po ung ocp?
Offline Woots29
  • asan si mojacko?
    • Woots Page
« Reply #8 on: May 18, 2009, 10:13:18 AM »
over current protection
karaniwan kasi sa sony, kung may cra sa loob, may mga blinks sa led, yun ang error code nya
karaniwan ng shutdown eh two blinks.
kung over current protection nga, malamang flyback or may leak sa mga power supplies papuntang ibat ibang sections
pero better check sum parts muna starting sa output ng power supply
Offline jet2081
« Reply #9 on: May 18, 2009, 10:14:26 AM »
ok sir thanks po sa info il try to check po muna
Offline Woots29
  • asan si mojacko?
    • Woots Page
« Reply #10 on: May 18, 2009, 11:11:10 AM »
cge update mo kami ;D hmm nawawala si sir ultrasonic ah ;D
Offline vences86
  • Wireless mic
« Reply #11 on: May 18, 2009, 11:29:03 AM »
If meron B+, try 2 look un 5Volts Regulator. baka sira n.
