Author Topic: sony trinitron red picture  (Read 2160 times)
Offline randy3
« on: May 18, 2009, 08:31:01 PM »
sir san ang possible na sira if red ang video or screen. thanks
Offline BANNEDMemberAccount
  • Pogi/Ganda Points: 130
Re: sony trinitron red picture
« Reply #1 on: May 18, 2009, 11:05:17 PM »
Check mo CRT
Offline nucleus
« Reply #2 on: May 18, 2009, 11:41:21 PM »
check mo po yung mga transistor sa CRT board pati na po mga resistor dun
Offline kirk simone
  • Pogi/Ganda Points: 7
« Reply #3 on: May 19, 2009, 01:19:11 PM »
adjust muna sir ung tint trimmer
shake it .....
Offline Electrofun_01
« Reply #4 on: May 19, 2009, 01:27:57 PM »
check mo muna and compare yung voltages sa Cathode versus ground tatlo yun R G B if red ang video meaning either cra Transistor or cold solder lang sa Green at Blue cathode na nasa CRT board
  • Pogi/Ganda Points: 909
« Reply #5 on: May 21, 2009, 05:33:48 PM »
focus ka muna sa CRT board  malaman na jan ang sira...
check your RGB gun.  if  pareho sila ng voltage reading..   kung wala bang absence...
try also to check your 3 color driver transistor
:D
Offline sEPh
  • Pogi/Ganda Points: 68
  • try this_
« Reply #6 on: May 21, 2009, 06:53:23 PM »
check CRT circuit,madalas cold solder lang...
« Reply #7 on: May 21, 2009, 08:17:21 PM »
cold solder, nga madalas 3 time ko naexpirience. :-) pero 1 time sa tv ko resistor sa crt rin
Offline nucleus
« Reply #8 on: May 21, 2009, 08:31:32 PM »
oo nga sa resistor, minsan akong pinahirapan ng resistor sa crt board sa visual inspection mukha syang good nung mga 3 days ko hinahanap sira sinukat ko na isa isa ang mga resistor sa CRT board yun pala open yung isa yung nasa base ng transistor na nagreregulate sa red gun ??? ;D
« Reply #9 on: May 21, 2009, 08:37:21 PM »
hehe. ako masyado mababa na yung resistance.hehe
sa ibang tv kasi may switch para jan nakalagay sa crt. minsan switch lang din sa kakahanap ko wala akong mahanap inilagay ko sa gitna yung switch ayun ok na kulay.hehe
Offline tdh7700
  • Pogi/Ganda Points: 25
« Reply #10 on: May 22, 2009, 06:22:59 AM »
up
ok na po ba yung unit ???
ORDONIO ELECTRONICS
public mkt. sq pangasinan ph.
Offline john_xd
  • Pogi/Ganda Points: 37
« Reply #11 on: May 22, 2009, 08:48:46 AM »
 ;D ;D ok na cguro, oh kaya........namumula na rin ang mata sa pangangapa.hehhe
btw, nasabi na lahat ng mga masters ang lahat ng maaring gawin mo. ;)
« Reply #12 on: May 22, 2009, 11:52:34 PM »
share aku ulit may na-encounter akung SONY trinitron kanina lng tlaga,  29''  nga lang  (^_^)
over red raster video din ang display....  check ko yung three RGB gun supply...   hindi pantay ang nakuha kung reading..  hindi maadjust yung screen  & sub-brightness adjustment..
trouble found:  open resistor  680k ohm
hope makatulong yan   ;D
Offline randy3
« Reply #13 on: June 14, 2009, 08:05:49 PM »
mga bos  hanggang ngayn hin di pa rin gawa kasi tinbi ko muna, salamat sa inyong lahat try ko mga suggestion nyo
Offline Woots29
  • Pogi/Ganda Points: 344
  • asan si mojacko?
    • Woots Page
« Reply #14 on: June 15, 2009, 10:00:22 AM »
ako nmn CRT rejuvenator ang katapat.
nakaencounter ung isanga kasama ko ganyan ;D
agree ako kay ultrasonic. 680k
WootsPC2 Videos  Woots Page
Offline tdh7700
« Reply #15 on: June 15, 2009, 12:31:47 PM »
ako din naincounter ko  green naman. 680k dn.
ORDONIO ELECTRONICS
