Author Topic: Counter using 74ls192  (Read 8472 times)
Offline Decoder
  • MABUHAY!!!!
« on: May 20, 2009, 03:04:12 PM »
cnu po mei ckt. dito ng up/down counter using the said IC.....2 digits po qng pd....hehe........
arrrrr!!!!!!!.............arrrrrrrrrre yahhhhhh ready kidz??????????? aye aye CAPTAIN!
  • Pogi/Ganda Points: 924
Re: Counter using 74ls192
« Reply #1 on: May 20, 2009, 05:51:53 PM »
try dis one
that cicuit are fixed in a up counter,  kung gus2 mung gawing down counter just change the input pin of your counter ic 4 & 5
or maybe lagyan mu nlng ng SPDT switch..
Vcc = 5V-9V
for more info:  look for the component datasheets   :D  as your guide
Offline Decoder
  • MABUHAY!!!!
« Reply #2 on: May 21, 2009, 03:15:50 PM »
kung pd po sana ung automatic na po xang mag-cocount up/down without having to switch this......halimbawa po kapag press po ako ng button A (signifies up) magcountup xa then kapag po press ko c button B (signifies down) count down xa......kc po nung ng-try ako sa proteus nito ung outputng carry up and down pins ay nagsasabay ng pasok sa decoder kaya un hindi niya magawa ng tama ung dapat sana ay dapat gawin ng counter na ginawa ko......baka po mey further improvements pa po na pdi gwin sa ckt......anyone??????? tnx
« Reply #3 on: May 21, 2009, 04:10:30 PM »
ahhh... ganun pala gus2 mu sana..  sa susunod complete detail na  ;D ;D ;D ;D ;D
hehehe
« Reply #4 on: May 21, 2009, 04:16:18 PM »
kailangan mu nalang ng flip-flop &  switches to interchange the operation of your counter
by d way ask aku   wat do u mean two digit?    two digit po ba na sabay na nag-ka-count ? or carry/borrow  operation ang principle?  ??? ??? ???
Offline Decoder
  • MABUHAY!!!!
« Reply #5 on: May 21, 2009, 04:43:26 PM »
carry/borrwo operation po...heheheh...tenk yu po
Offline Decoder
  • MABUHAY!!!!
« Reply #6 on: May 21, 2009, 04:46:48 PM »
nalimutan ko po.........baka po pd pahingi ng ckt. nung mey flip-flop....
« Reply #7 on: May 21, 2009, 10:34:55 PM »
ito   try  this one...   cnxa na medjo pangit ang drawing  koh...  (^_^)
by the way dont forget  to supply your  flip-flop ic
recommended  flip-flop ic =  74LS76   ;D
push the switch to change the clock counting operation
try to look the datasheet of ur flip-flop ic & counter ic to easily understand the operation of your circuit
intindihin nyu nalang ang diagram..  (^_^)   if may mali   modify nyu nlng   hindi nmn kasi aku perfecto  :D :D :D :D :D
« Reply #8 on: May 21, 2009, 10:45:49 PM »
xa nga pala...  ngayon ko lng napansin  bat aku lang ang nagpopost sa thread nato...?
nasan na ba yung iba?     ang daya nyu tlga...  (^_^)
;D ;D ;D ;D ;D
Offline Tasyo
  • Pogi/Ganda Points: 39
« Reply #9 on: May 22, 2009, 01:39:43 AM »
;D ;D ;D ;D ;D
nag rrewind lang sir kaya mo yan parang digital cock lang yan
Offline nucleus
« Reply #10 on: May 22, 2009, 04:09:43 AM »
Spoonfeed:
lagyan na lang ng bcd to seven segment katulad ng nasa itaas ::)
« Reply #11 on: May 22, 2009, 06:32:39 PM »
;D
Offline Decoder
  • MABUHAY!!!!
« Reply #12 on: May 22, 2009, 06:35:27 PM »
hmmm.......nasolusyunan niyo ser ung pwoblema ko.......tenk yu.........ur da best
Offline ♪ ♫ ♫ ♪ ♪ ♪ ♫ ♫ ♫
  • Pogi/Ganda Points: 124
« Reply #13 on: May 22, 2009, 07:12:49 PM »
mas maganda siguro ang 74LS193, para deretso na decimal...
Offline nucleus
« Reply #14 on: May 22, 2009, 07:53:06 PM »
??? kung decimal po kailangan padin ng decimal to seven segment decoder ::)
« Reply #15 on: May 22, 2009, 09:19:55 PM »
yap, medyo simply lang ang 193....
« Reply #16 on: May 22, 2009, 11:20:25 PM »
bat?  walang image lumabas
uulitin ko nlng  sori
« Reply #17 on: May 23, 2009, 11:25:08 AM »
Spoonfeed:
Nadale mo bata! Ilang taon ka na ba ngaun? katorse ka pa rin ba?
Offline nucleus
« Reply #18 on: May 23, 2009, 12:02:24 PM »
15 na po nung February :D
« Reply #19 on: May 23, 2009, 05:04:09 PM »
 ;D  ;D  ;D  ;D  ;D
