Author Topic: UV LED exposure box  (Read 5494 times)
UV LED exposure box
« on: May 24, 2009, 03:02:03 PM »
Biglang na-alala ko to nung nabuhay uli yung thread ng diy exposure timer.
Question:
Ano bang klaseng UV LED ang pwede gamitin at ilan LED ang effective for a particular area.  May nakagawa na ba nito?  Anong wavelength at brightness ng UV LED ang gamit ninyo and saan nakakabili asides from ebay sa murang halaga.
Gaano katagal ang exposure time kapag UV LED ang gamit?
UV LED exposure box
Offline nucleus
Re: UV LED exposure box
« Reply #1 on: May 24, 2009, 04:41:27 PM »
Question:
ako gamit ko yung uv led 30 seconds lang ang exposure time at kung gusto nyo ng murang uv led baka matulungan ko kayo "ahehehe raket na naman bwahahaha"
Offline ATE
    • Volts and Bytes
« Reply #2 on: May 24, 2009, 08:05:31 PM »
tagal ko nang gustong gumawa nito,
magkano ba ang 100pcs ng uv led?
Offline nucleus
« Reply #3 on: May 24, 2009, 08:15:42 PM »
Offline ATE
    • Volts and Bytes
« Reply #4 on: May 24, 2009, 10:05:53 PM »
pwede na  ;D
« Reply #5 on: May 24, 2009, 10:40:04 PM »
^mura na... free shipping pa yung 500 pieces.
magkano ang benta mo nyan nucleus? kasi kung bibili ako, parang sobra naman... naisip ko, ibenta yung iba. yung reasonable naman.
tamang tama yung sirang scanner namin for enclosure.:)
Offline nucleus
« Reply #6 on: May 24, 2009, 10:50:16 PM »
lahat ng item dun "free shipping" ubos na yung stock ko ngayon, P15.00 dati benta ko nyan siguro kahit P10.00 na lang ::)
« Reply #7 on: May 24, 2009, 10:57:44 PM »
OK na OK yung price nung 500 pcs  ... sulit na sulit pero kung 100 pcs, sa ebay na ako kasi may kasama ng resistor for both 5V and 12V supply, same lang ang price and free shipping.
Anyway thanks, nakahanap ako ng alternative source ng water clear blue LED na mura na gagamitin ko sa LED cube project ko.
Offline nucleus
« Reply #8 on: May 24, 2009, 11:00:48 PM »
nope option po yun kung pang 5V o pang 12V ;)
« Reply #9 on: May 24, 2009, 11:27:46 PM »
^ Sige na nga  ;) .....  Logical AND kasi gamit ko kaya pagkakaintindi ko 200 resistors in total.   "Free to provide 100 pcs resistors for 5V DC and 100 pcs resistors for 12V DC"
Pero dun na rin ako bibili  sa online store na sinabi mo para isang bilihan na lang.  Pogi points nga pala sa yo! ;)
Baka naman may alam ka rin bilihan ng smd leds na mura  ??? ??? ::)
insomartin
  • Guest
« Reply #10 on: May 26, 2009, 12:48:31 AM »
mahal na project toh.
« Reply #11 on: June 11, 2009, 09:31:12 AM »
completo na akong materials.
UVLEDS, resistors, transistor for current limiting, power supply at kahit yung plywood meron na din....
nakakatamad naman magconstruct! heheh ;D
« Reply #12 on: June 11, 2009, 12:58:29 PM »
Sino ba ang nakagawa na???
strictly, kinunsider nyo ba yung formation ng LEDs? mine is a only 10degrees...  kailangang magkakalapit at medyo malayo.
Offline nucleus
« Reply #13 on: June 11, 2009, 02:21:08 PM »
ahmm yung sakin boss pahalang at patayo lang, yung pagkakalayo-layo naman inacual ko lang yung distance ng dalawang LED tinusok ko sa karton tsaka ko itinapat sa (clips/glass/PCB setup) then pinower ko yung LED hinanap ko yung tamang distansya ng dalawang LED na magiging pantay ang sinag sa layong 1 inch sa setup ::)
« Reply #14 on: June 11, 2009, 02:51:20 PM »
ic... salalamt sa tip. di ko naisip yun ah!!! tutal mauuna naman pala yung construction ng board bago yung enclosure.
ilang degrees sayo? gaano kataas ang kinalabasan kung 1" ang distance?
Offline nucleus
« Reply #15 on: June 11, 2009, 02:56:14 PM »
20 degrees yung sakin 1" po angibig kong sabihin ay anglayo ng mismong led panel sa pcb setup 12mm po yung distansya sa isa't isa ng mga LED ko ;)
« Reply #16 on: June 11, 2009, 03:10:14 PM »
lapit lang pala...
sige... experiment nalang ako...
but since 10deg lang tong akin, paghihiwalayin ko ng 0.5".
salamat sa insights.:)
Offline nucleus
« Reply #17 on: June 12, 2009, 07:03:13 PM »
lapit lang pala...
ahmmm mga 6mm po siguro kung 10 degree yung led nyo then ilayo yung panel sa pcb setup ng mga 1" :)
« Reply #18 on: June 12, 2009, 09:20:35 PM »
tataasan ko naman ng konti... 2-3" actually.
Offline nucleus
« Reply #19 on: June 12, 2009, 09:41:40 PM »
ahhh :D
