Author Topic: PIC and AVR DIY development boards  (Read 3950 times)
Re: PIC and AVR DIY development boards
« Reply #20 on: June 06, 2009, 10:15:57 PM »
tinry ko yung v2.2, lahat ata ng bootloader dun ginamit ko pero, ayaw madetect... so ginamit ko v1.2, kasi madaling hanapin yung hex, driver, saka tool.. pero sa mga latest version, daming demo na pwedeng pag-aralan...
i used this path...
C:\Microchip Solutions\USB Device - Bootloaders\Vendor Class - MCHPUSB Bootloader\Bootloader - Firmware for PIC18F4550 Family Devices
then i just compiled it... it worked. nadedetect ang board ng PC ko.
@sir motion55 and sir paranz
I can't seem to find those files... heheh ;D
Offline motion55
  • Pogi/Ganda Points: 243
« Reply #21 on: June 06, 2009, 10:20:10 PM »
BTW, there are at least two kinds of drivers (possibly three) you can use for free for the PIC USB chips.  These are for custom USB classes. The standard classes have built-in drivers for windows from Microsodt.
The first one is the original "mchpusb" driver.
The second one is WinUSB from Microsoft which comes with Vista but can be used in XP. It is free download through the Windows driver kit.
The third one is an open source version used by other embedded USB devices for custom applications. I can't remember the name right now.
It is possible the version 2 framework uses a different version mchpusb. Hence it can't be detected. Or the VID/PID pair may be different..
Try this link for more info:
http://www.lvr.com/usb.htm
"Set your mind free!"
Offline paranz
  • Pogi/Ganda Points: 177
  • 1/4W resistor specialist
    • RapidSignal Electronics
« Reply #22 on: June 06, 2009, 10:23:51 PM »
Download the appnote
Migrating Applications to USB from RS232 UART with Minimal Impact on PC Software.pdf
and its sample code instead
Offline nucleus
« Reply #23 on: June 06, 2009, 10:34:09 PM »
WOW ngayon ko lang to nakita pogi for you kuya :)
Offline ATE
    • Volts and Bytes
« Reply #24 on: July 19, 2009, 08:40:53 PM »
« Reply #25 on: August 09, 2009, 05:42:49 PM »
Finally i were able to make my PIC18F4450 work. di pa pala supported ng version 1.3 - yung driver sa PC ayaw pa magwork.
i used stack version 2.4. pero medyo natagalan akong maguhin gawa nung iba na ang mga files comparing sa version 1.3. most ng tutorials sa net ay pic18F4550 at version 1.3 ang ginagamit.
i was successful with the CDC demo.
;D
Offline aeronuts
« Reply #26 on: September 02, 2009, 09:42:13 PM »
@kuya,
ganda naman... meron ka ba spare board ng 4550 devboards?
thanks for sharing
