Author Topic: how to extend PIC memory using external EEPROM?  (Read 14913 times)
Re: how to extend PIC memory using external EEPROM?
« Reply #120 on: March 19, 2008, 11:19:57 PM »
nyahahahaha ;D
Offline 'yus
  • Pogi/Ganda Points: 299
  • hw -> fw -> sw
    • yus' projects
« Reply #121 on: March 19, 2008, 11:20:14 PM »
... baka bukas ko na gawin siguro, medyo antok na ako hehehehe ;D
linawin ko lang ha.. libre ito at walang anumang bayad..
saka may libre pang sample ng actual PCB..  :D
« Reply #122 on: March 19, 2008, 11:24:11 PM »
ako lang ang gagawa ;D si sir paranz ang magpapafabricate ng PCBs sa PCB manufacturer para lahat ng members dito may samples... heheheh ;D
Offline paranz
  • Pogi/Ganda Points: 177
  • 1/4W resistor specialist
    • RapidSignal Electronics
« Reply #123 on: March 19, 2008, 11:25:54 PM »
pogi points lang bayad nyan  ;D ;D ;D
« Reply #124 on: March 19, 2008, 11:28:07 PM »
corrrection... renesas kit lang ang tinatanggap ko ;D ;D
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
« Reply #125 on: March 20, 2008, 10:47:06 AM »
mamaya, check ko kung meron din para sa SPI eeproms ang CCS..
kung meron, ita-try ko yung nakuha kong spi eeprom..  ;D
wala palang built-in driver ang CCS para sa spi eeprom..  :'(
ang meron lang (para sa EEPROM) yung i2c type (like 24xx),
saka 9346, 9356 & 9366 serial eeprom's..
ano naman kaya 'tong 3 na 'to ?  ???
« Reply #126 on: March 20, 2008, 10:50:05 AM »
gumamit ako dati ng 93LC56B (9356), and SPI ang ginamit ko jan..
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
« Reply #127 on: March 20, 2008, 10:54:54 AM »
dito sa site ng IC-Prog (supported devices) http://www.ic-prog.com/index1.htm
kasama yung 9356 sa Microwire eeproms, same lang sya sa SPI ?  ???
« Reply #128 on: March 20, 2008, 10:58:41 AM »
yup... pag may time ako sa work check ko ang behavior ng serial port pag ginamit ang IC-Prog, tapos from the waveform sa oscilloscope we can come up with a circuit for programming SPI EEPROMs (or baka mareuse din natin ang JDM with little modifications)
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
« Reply #129 on: March 20, 2008, 11:04:01 AM »
uy.. thanks.. hihintayin namin 'to!  ;D
so bale, isa sa mga hardware modification is kelangan magdagdag ng programming pin
kasi yung JDM pang i2c lang ata..
Offline snider
  • Pogi/Ganda Points: 25
  • Hi.
« Reply #130 on: March 22, 2008, 03:35:53 PM »
eto poh mga kuya baka makatulong sainyo www.lancos.com
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
« Reply #131 on: March 22, 2008, 04:31:57 PM »
very late question:
anong commercially available na eeprom ang may pinakamalaking storage capacity ?  ???
Offline zer0w1ng
  • Pogi/Ganda Points: 305
    • The Cebuano Geek
« Reply #132 on: March 22, 2008, 05:16:50 PM »
very late question:
You could use a serial flash and not an eeprom.  Serial flash have larger storage. We use an 8Megabit flash on one of our products.  That is 1 megabyte of flash.  The only disadvantage of flash compared to eeprom is that you could not re-write the value on a page.  You need to erase the whole page and re-write the entire page with the corrected value.
The Cebuano Geek
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
« Reply #133 on: March 22, 2008, 06:13:18 PM »
ayoko nito.. magka-cascade na lang siguro ako ng maraming maraming EEPROM's.. hehe  ;D
Offline zer0w1ng
    • The Cebuano Geek
« Reply #134 on: March 22, 2008, 07:26:44 PM »
Why?
Serial flash chips now is cheap and common and is 8 pin only like eeproms.
For your usage that is for static pictures only, it is the right choice.
The Cebuano Geek
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
« Reply #135 on: March 22, 2008, 08:08:00 PM »
Why?
for practical reasons na rin siguro..
unlike kasi nung eeprom ko na kinuha ko lang sa amin (as in FREE ;D), bibili pa ko nito..
and kung bibili pa ko ng additional components, i will opt for better devices..
better device like memory cards.. mura na rin pala ang mga memory cards..  :D
