Author Topic: sony trinitron kv xf29  (Read 3025 times)
Offline orravan
  • "I know i'm not good yet, but soon I will"
Re: sony trinitron kv xf29
« Reply #20 on: June 15, 2009, 09:20:58 AM »
mga master...ok na itong sony trinitron KV XF29N93 kahapon ko lang kasi nabalikan un unit sa antipolo.
i summarized ko lang.
Problem:
no raster, with standby power but failure to turn on, two blinks of led.
Cause:
Shorted Horizontal output and fusible resistor R615 1ohm.
To sir Tasyo maraming salamat sa tulong with regards dito sa model na ito
  • Pogi/Ganda Points: 916
« Reply #21 on: June 15, 2009, 11:07:56 PM »
Problem:
Cause:
congratz  (^_^)
Offline cass
  • Pogi/Ganda Points: 6
« Reply #22 on: July 01, 2009, 01:28:55 PM »
ple try to the vertical section, baka may short at baka sira ung vertical ic mo. nkaencounter ako ng ganun pro sa sharp na tv
Offline ayet
« Reply #23 on: September 13, 2009, 08:04:58 PM »
try mo isolate horizontal din lagay ka bulb na 150 watts sa load, pag umilaw means okey current ng supply mo, now yung blink ba is green muna then saka mag blinking red, or deretso nang red blink, kung deretso nang red blink check mo R657 di ko lang sure kung tama number 220K same chassis lang hawak kong diagram
  sir tasyo gngwa kong 29 green den red tpos 2blink na cya minsan on cya liliit ang screen both side tpos cbak na h-out...
Offline -edz-
« Reply #24 on: October 09, 2009, 10:36:15 PM »
mabuti naman po kung ganun.. congratz!
