Author Topic: SHARP 21V-K100M Valeo  (Read 7936 times)
Offline technoquest
« on: June 11, 2009, 07:37:10 PM »
hi im  billy  newbie lang po ako sa larangan ng pagrerepair actually  OJT pa huh aku until now,  hihingi sana ako ng tulong sa inyo mga master, may inaayos kasi akong TV  sharp 21V-k100m,  no power hu siya
may standby red light lang hu  pagpress ng  ON button, iyong LED magiging green  kaya lang babalik ulit sa standby  maririnig ko na lang na nagrerelease ang relay,    hope any one could be help me
Offline technoquest
Re: SHARP 21V-K100M Valeo
« Reply #1 on: June 11, 2009, 07:42:50 PM »
ito po iyong mga parts:
D1884   Regulator transistor
TA8403K  vert. ic
X2933CE  chroma
D2586   H-out
TDA7056A   amp. ic
24C01     memo
1X2946CE   CPU spider
B+ = 145v   tama po ba ito ?  nagdadrop siya sa 110v  pagnagcontact na po iyong relay
Offline tdh7700
  • Pogi/Ganda Points: 25
« Reply #2 on: June 11, 2009, 07:44:42 PM »
sir try mo check vertical saction, at audio aamp...
ORDONIO ELECTRONICS
public mkt. sq pangasinan ph.
Offline technoquest
« Reply #3 on: June 11, 2009, 07:50:28 PM »
sir nasubukan ko ng magpalit ng vert.  pero ganun pa rin, iyong audio aamp  hindi ko pa nasusubukan
Offline lhan
  • Pogi/Ganda Points: 186
  • agta maloko
« Reply #4 on: June 11, 2009, 07:52:52 PM »
chek u bk loss con lng sa vert section tip ko lng sir bgo k magsolder pki discharge muna mga filter cap sa b+, bk lumalala trobol nya pag nag spark ;D
Offline technoquest
« Reply #5 on: June 11, 2009, 07:55:21 PM »
thanks po sir
Offline technoquest
« Reply #6 on: June 11, 2009, 08:06:36 PM »
sir may napansin aku  sabi kasi ni sir  supervisor hu namin  may power daw ito noong  una  kaya lang nagtetrep-off na ngayon  kasi pinalitan niya sa akin ng maliit na value iyong abl capacitor 10mf/250v sa 4.7mf    kaya ayon  ganun na ang TV
Offline sEPh
  • Pogi/Ganda Points: 68
  • try this_
« Reply #7 on: June 11, 2009, 08:12:05 PM »
baka wala ng pumapasok na supply sa vertical ic.
check mo yung resistor galing flyback,papunta vertical...
Offline tdh7700
« Reply #8 on: June 11, 2009, 08:14:17 PM »
agreee ako.......
ORDONIO ELECTRONICS
Offline lhan
  • agta maloko
« Reply #9 on: June 11, 2009, 08:21:26 PM »
resolder u jungle ic, bk nag loss con  kz binaliktad u board nung palit u cap
Offline technoquest
« Reply #10 on: June 11, 2009, 08:33:00 PM »
sir may makukuha ba akung voltage reading sa vert. kahit  magtrep  iyong relay?
  • Pogi/Ganda Points: 924
« Reply #11 on: June 11, 2009, 08:46:14 PM »
(^_^)  sa tingin  ko saglit lng
Offline tdh7700
« Reply #12 on: June 11, 2009, 08:48:54 PM »
hehehe xempre saglit lang un. pag trip na relay..
ganto gawin mo sir,, abang mo na test probe mo sa suply ng ic tpos on mo xa... hehehe
ORDONIO ELECTRONICS
Offline technoquest
« Reply #13 on: June 11, 2009, 08:52:53 PM »
mga  master ano pa kaya possible na masira na device pagpinaiklian ang abl capacitor ng maliit na value?
Offline tdh7700
« Reply #14 on: June 11, 2009, 08:55:10 PM »
la masisira dyan, maiiba lang ang effect
ORDONIO ELECTRONICS
« Reply #15 on: June 11, 2009, 08:55:49 PM »
may  tama  pala aku   (^_^)
Offline technoquest
« Reply #16 on: June 11, 2009, 08:57:30 PM »
ano  po iyong ibig ninyong sabihin  sir ?
Offline Siramiko
  • Pogi/Ganda Points: 35
  • thank you elab
« Reply #17 on: June 11, 2009, 09:15:20 PM »
sir masarap tumulong, pero  mahirap maintindihan ang txtspeak mo   ;D parang parts number lahat ng  sinabi mo  dito ;D ;D
I shall return
Offline Siramiko
  • thank you elab
« Reply #18 on: June 11, 2009, 09:18:35 PM »
pwede maiba ang kulay, karaniwan niyan nakakaroon ng retrace line (parang guhit sa papel pang grade school)
I shall return
Offline Siramiko
  • thank you elab
« Reply #19 on: June 11, 2009, 09:24:31 PM »
nag kakaroon ba ng high voltage yan ? kasi kung hindi nag kakaroon ng high voltage hindi gumagana ang horizontal osc. ng tv kaya babalik yan sa standby mode. wala magbibigay supply sa vertical IC.
I shall return
