Author Topic: Security Based System  (Read 869 times)
Offline Ms. Lawliet
« on: June 22, 2009, 09:47:11 PM »
kung ndi po abala, pati rin po dito..hingi din po sana ako ng tulong..slamat ng marami..
Offline Google
  • Pogi/Ganda Points: 20
Re: Security Based System
« Reply #1 on: June 22, 2009, 09:50:00 PM »
kindly elaborate and explain what you want to be happen :)
Offline Ms. Lawliet
« Reply #2 on: June 22, 2009, 09:57:32 PM »
Security Based System – alarm system which uses different kind of sensors such as PIR, touch, motion, vibration, sound and  contact break.
---> e2 po..pero,naisip ko n wag na lng ung motion..hehehhe..
Offline Google
« Reply #3 on: June 22, 2009, 09:58:56 PM »
madaming klase yan... dapat alam nyo na yung pinakaobjective at plano nyo about sa magiging applications :)
Offline Monde
  • bespren kita ^_^
« Reply #4 on: June 22, 2009, 10:04:03 PM »
uu nga jo be specific dapat d2 kasi madami apps yung sa gsm eh=p..
Offline AgentPhoenix08
« Reply #5 on: June 23, 2009, 02:00:06 AM »
by three methods we may learn wisdom: first, by refection, which is the noblest; second, by imitation, which is the easiest; and third, by experience, which is the bitterest.
