Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
Analog and Mixed Signal
Analog Electronics
(Moderator:
marcelino
Amp for passenger jeep
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Amp for passenger jeep (Read 1759 times)
Roland
Diesel Generator
Pogi/Ganda Points: 208
I always compete to myself
on:
July 10, 2009, 06:13:46 PM »
ano ba magandang amplifier para sa mga pampasaherong jeep na pweding ireplace sa mga transformer type na booster. ung mga booster kase nila aabot daw ng 200 to 250 watts.
meron kaseng mga amplifier na alpine yata ung brand na malaks din. pano kaya lumakas un eh 12 volts lang ung battery.
suggestion mga master.
Logged
on:
audiomachines
Size D Battery
Pogi/Ganda Points: 30
Gender:
Lorentz Transform
Re: Amp for passenger jeep
Reply #1 on:
July 10, 2009, 06:21:20 PM »
sir my DC-DC boost converter un sa loob, 12V to around +/-35VDC. kya ang lalaki ng rating ng fuse nun 30A to 40A swaping current for voltage
Logged
Reply #1 on:
audiomachines
Size D Battery
Gender:
Lorentz Transform
Reply #2 on:
July 10, 2009, 06:25:02 PM »
http://valveaudio.tripod.com/Membuatsendiri.htm
yan diy car amp yan
Logged
Reply #2 on:
Roland
Diesel Generator
Reply #3 on:
July 10, 2009, 06:46:08 PM »
hirap pala, di pa kakayanin ng utak ko hehehe, at bulsa...
Logged
Reply #3 on:
danny
Technical People
Solar Power Satellite
Pogi/Ganda Points: 323
Gender:
Reply #4 on:
July 11, 2009, 02:27:39 AM »
tiyagaan lang
kaya mo iyan hehehe
madami naman tutulong sa iyo dito
Logged
danny
Reply #4 on:
insomartin
Guest
Reply #5 on:
July 11, 2009, 04:17:08 AM »
hey! bi or tri amp system na lang muna. wag muna yung may pwm na boost converter. mga 50-50 watts muna. overkill naman ata agad yun. malakas na din yung bi-amped na 50 watts. 4 amps in all. nag backout tuloy si sir roland sa project.
Logged
insomartin
Guest
Reply #6 on:
July 11, 2009, 04:26:41 AM »
or triamp... dual 50 watts for subs. then isang 50 amps for midrange/tweets.
TDA1562 or LM3875 amp...
yep! it's gonna take 40v to get 50watts.. but... i'll stand corrected.
http://www.nxp.com/acrobat_download/datasheets/TDA1562Q_ST_SD_2.pdf
http://www.national.com/ds/LM/LM3875.pdf
Logged
danny
Technical People
Gender:
Reply #7 on:
July 11, 2009, 04:29:12 AM »
good idea
Logged
danny
audiomachines
Size D Battery
Gender:
Lorentz Transform
Reply #8 on:
July 11, 2009, 06:37:52 AM »
pwede ung mga gainclone na BTL or bridge topology kung 12VDC lng ang supply cguro mga 15W per ch @ 8ohm load, pwedeng I boost ang ouput using descrete power transistor parang hybrid, IC Amp+descrete class B output stage para mkapag drive ka ng low impedance as low as 1 ohm.
Logged
Roland
Diesel Generator
Reply #9 on:
July 21, 2009, 08:12:50 PM »
pano ung discrete class b output bossing. penge ng schem hehehehe. baka kaya kong gawin.
12 volts din ba ang supply ng output ?
Logged
rogerjuvy
Size D Battery
Pogi/Ganda Points: 28
Gender:
ikaw ay supot..salot...suntukan nalang tayo...
Reply #10 on:
August 17, 2009, 10:28:26 AM »
sir madali lang yan problema mo,subok ko na,bale mag assemble ka ng amplifier pwde naun kay marconi pagarigan na 100/channel tapos kahit 6amp lang gamitin u transfo,sa 110volts mo gamitin tapos bili ka ng inverter.un 12v to 110 volts kahit mga 600watts lang.madami yan inverter,same principle lang naman kaya lang u have to do it on your own,tapos i bridge mo yun amplifier,pwede ko ituro sa iyo ang pagbibridgre,simple lang yan
Logged
pinakapogi sa lahat...walang kokontra,.....
EVSU2008
CR2032 Battery
Pogi/Ganda Points: 0
Reply #11 on:
August 19, 2009, 10:01:29 PM »
ang lakas na nung 200-250 watts!! lalakas talaga dahil depende yan sa amperes ng supply...
Logged
Reply #11 on:
Print
Pages: [
1
Go Up
« previous
next »
Analog Electronics
(Moderator:
marcelino
