Author Topic: WHICH IS BETTER, 350 watts nominal or 350 watts peak???  (Read 10043 times)
Offline TinTopHack
  • Pogi/Ganda Points: 154
Re: WHICH IS BETTER, 350 watts nominal or 350 watts peak???
« Reply #40 on: July 15, 2009, 12:30:45 PM »
Offline Woots29
  • Pogi/Ganda Points: 344
  • asan si mojacko?
    • Woots Page
« Reply #41 on: July 15, 2009, 12:41:28 PM »
yan yun, juz clict the Konzert 502 hehehe
WootsPC2 Videos  Woots Page
Offline TinTopHack
« Reply #42 on: July 15, 2009, 12:56:14 PM »
OK thanks. Link pala yun. heheheh
Offline ghomer
« Reply #43 on: July 15, 2009, 01:14:25 PM »
                                                             TinTopHack
                                                              Woots29
                                                           audiomachines
        amp
        nath630
Mga sir maraming salamat.. huhu! iba tlga ang may alm! dami kong natutunan sa inyo..
laki tulong sakin nito sa future, kung meron man.. hehe! salamat ulet mga sir! GALING!
cgro 2x12" woofer nalng ako 3way @ 300watts nominal 350-400 watts peak..  tska na mghahangad na malakas, pag dumating na si FUTURE.. cgro mainan na bimili ako ng woofer ayon sa nominal wattage ng aking amp at base sa peak power ng aking amp.. SALAMAT MGA SIR!
        ghOmz™
Offline Woots29
  • asan si mojacko?
    • Woots Page
« Reply #44 on: July 15, 2009, 01:31:32 PM »
welcome sir hehehe
kung nakagawa ka na share mga pix hehehe
Offline amp
  • Pogi/Ganda Points: 11
« Reply #45 on: July 15, 2009, 03:09:48 PM »
tama sir 100watts rms lang Konzert502
50 volts lang eh hehehe
wala pa akong nakitang konzert na lumagpas sa
150 watts rms ang design (maliban sa orig K-series)
kungsbagay ang mga amps na yun ay PMPO lang ;D
hello mga bosing dpat mgicing sa katotohanan lalo na sa mga DIY mging wais nman sana at gmitin ang nalalaman sa tamang paraan.
Konzert AV502a is wthin 150watts - 160watts of POWER at 8ohms load  not RMS POWER.
Offline Woots29
  • asan si mojacko?
    • Woots Page
« Reply #46 on: July 15, 2009, 03:12:53 PM »
^any explanations sir?
Offline amp
Offline Woots29
  • asan si mojacko?
    • Woots Page
« Reply #48 on: July 15, 2009, 03:57:46 PM »
hmm mabasa nga..
kasi hangang ngaun nalilito pa ako sa mga terms na yan
thanks sir amp
Offline ghomer
« Reply #49 on: July 15, 2009, 04:50:52 PM »
ok sir woots, pag'nakagawa nqo share ko sa inyo..
pacenxa na sa mag may high end audio dito, 502a lang amp ko eh.. hehe..
pagtyagaan ny nalng..  ;D
Offline Woots29
  • asan si mojacko?
    • Woots Page
« Reply #50 on: July 15, 2009, 04:58:39 PM »
hehehe
pagpraktisan muna 502
ako nga sounds ko sa bhay 100w 100w elco lang eh hehehe
Offline audiomachines
  • Pogi/Ganda Points: 30
  • Lorentz Transform
« Reply #51 on: July 15, 2009, 05:04:51 PM »
 yan nga sir maganda jan sa amp nyo pwede nyo pa i tweak ung performance, parang bang kumuha ka ng stock cars tpos sesetupan mo ng turbo charger at NOS he he he.
Offline Woots29
  • asan si mojacko?
    • Woots Page
« Reply #52 on: July 15, 2009, 05:23:54 PM »
waaah!
panu sir?
ang alam ko lang dito pwedeng i-bridged eh
  • Lorentz Transform
« Reply #53 on: July 15, 2009, 05:35:56 PM »
 ayan my niluluto na c sir TinTapHack  kya huminge ng schemes he he he my potential ang ckt. Nka full differential symmetry ung front end ibig sbihin nun sabay ang pag clip at negative cycle ng signal. My minana sir to sa mga professional K series.
Offline TinTopHack
« Reply #54 on: July 15, 2009, 07:27:25 PM »
Woots, I got the diagram. Thanks.
I-redraw ko lang para malinaw at madaling i-analize.
Offline TinTopHack
« Reply #55 on: July 16, 2009, 02:56:18 AM »
Woots, There is something wrong with the K502 schematics.
The input stage does not look right. There is no differential amp.
Q3 qnd Q4 are practically useless because their outputs do not go
anywhere. If this is the diagram, this amp won't work!
Below is the diagram of the power amp section. I traced it para mas malinaw.
Notice how Q1, Q2 ,Q3 qnd Q4 are connected?
Are we sure this is the true diagram? Whoever draw this intends to deceive
us. Hahahah...
Offline Woots29
  • asan si mojacko?
    • Woots Page
« Reply #56 on: July 16, 2009, 09:18:18 AM »
alam mo sir tin top hack nakuha ko mismo yan sa owners manual ng sakura 5020
naparehong pareho sa konzert 502
kakainis lang talaga, nagpost pa ng diagram malimali pa ang coneksyon
hindi ko nasabi na maraming mali, sori for that
pero ganyan talaga, ang sakin eh kelangan ko lang ung mga values
kung sakaling nasunog pati board
and
nasasau na yan sir panu mo intindihin hehehe
Offline TinTopHack
« Reply #57 on: July 16, 2009, 09:57:19 AM »
Heheheh. Ok lang. Naintindihan ko.
Anyway, i-try ko manghiram ng Konzert amp kung meron dito
malapit sa amon tapos i-trace to get the correct connection.
O, baka si Bro Audio meron ng corrected diagram?
Cheers!
Offline Woots29
  • asan si mojacko?
    • Woots Page
« Reply #58 on: July 16, 2009, 09:59:28 AM »
^ok gud luck ;D
Offline nath630
  • Pogi/Ganda Points: 37
« Reply #59 on: July 16, 2009, 10:48:46 AM »
Cheers!
sige po mga Masters...
Magkaroon po sana ako ng kopya nito..at ng gagawin nyong modification..
malaking tulong po ito lalo na sa mga sunog na pyesa...at kung pano patibayin yung amp nato..
 galing!! ;)
