hmm may sakura 5023 dito na kapareho ng konzert 502pwede natin idesect, anu gusto mo sir tintop?
sakura 5020 pala hehehekapag silent period may maririnig kang munting hisssssss sa tweetermay ganun na konzert. sinauli naminhehehe
^hehehhenalilito nmn ako ngaunmay mga nakita akong mga circuits ng ampiba iba formula
The way I see it the real RMS power ouput is this:Supply voltage = +36 / -36V:This means for a sinewave signal the maximum positive swing is +36V and the maximum negative swing is -36V (assuming rail to rail ang swing.)This means the maximum peak voltage is 36V. The RMS value is 36 x 0.707 = 25.45V rms. This the maximum rms value you can get out of the output.So P = (ExE)/R = 25.45 x 25.45 / 8 ohms = 80.97W rms for one channel - BUT this is assuming rail to rail voltage of +/-36V and 100% efficiency from the output stage. In reality you can not get 100% efficiency and you don't get rail to rail output swing. So maybe you just get 60Wrms to 70Wrms per channel into 8 ohms.
sir tiptoptama nga na overlook ko nga yung RMS supply that should be Vrms= 36volts NOT +/-36voltsVdc= 36volts x 1.414Vdc= 50.9 voltsVrms= 50.9/1.414Vrms= 36 voltshehehe
sir tip topsa loob ng amp (Konzert AV502a) mayroon secondary AC 36v-0v-36v transformerVpeak = 36vrms x 1.414Vpeak = 50.904 voltsand So, there is peak voltage of +/-50.904 volts
