Author Topic: Ano ang pinag-aaralan nyo ngayon ? (either sa school or self-study)  (Read 48773 times)
  • Pogi/Ganda Points: 53
Re: Ano ang pinag-aaralan nyo ngayon ? (either sa school or self-study)
« Reply #680 on: July 24, 2011, 04:21:52 PM »
^ito pa isang halimaw sa programming ;D ;D ;D
Offline ` Kim Chi `
  • Pogi/Ganda Points: 9
« Reply #681 on: July 24, 2011, 08:33:15 PM »
cisco at unix ;D
“Engineers like to solve problems. If there are no problems handily available, they will create their own problems.”
Offline ♪ ♫ ♫ ♪ ♪ ♪ ♫ ♫ ♫
« Reply #682 on: July 24, 2011, 09:43:22 PM »
impedance at suseptance  :-\
zixy!  ;D
Offline iyo karpo
  • Pogi/Ganda Points: 18
« Reply #683 on: July 24, 2011, 11:07:27 PM »
http://www.aecdaily.com/en/1585094?list=4
required na kasi sa mga nagtratrabaho sa construction...libre naman, kaya ok lang.
  • Pogi/Ganda Points: 630
« Reply #684 on: July 25, 2011, 01:42:26 AM »
zixy!  ;D
ang confusing part dito, lalo na sa students, kung kailangan dapat impedance at kung kailan dapat admittance ang gamitin. :D
series analysis - dapat impedance / reactance
shunt analyis - dapat admittance / susceptance
naalala ko 'yung unang exam ko sa AC analysis ng Tank Circuit, sa impedance ko lahat sinolve pati 'yung shunts. ayun sakit sa ulo mag-divide ng complex numbers, imbes na additon na lang. :D
Offline iyo karpo
« Reply #685 on: July 25, 2011, 06:46:30 AM »
kung currents ang unknown, admittance matrix [Y] ang gamitin, = [Y]*[V]
kung voltages ang unknown, impedane matrix [Z] ang gamitin, [V] = [Z]*
to convert impedance to admittance, [Y] = inverse [Z]
Offline e-tronix
« Reply #686 on: July 25, 2011, 08:39:20 AM »
STM32
« Reply #687 on: July 25, 2011, 11:31:15 AM »
Naks
Offline PlCUSER
  • Pogi/Ganda Points: 152
« Reply #688 on: July 25, 2011, 11:40:09 AM »
kung pano magsolder ng STM32F103RBT ;D ;D ;D
« Reply #689 on: July 25, 2011, 01:48:34 PM »
with RF and other short wavelengths, mostly, 'di na interested with voltages and currents, power na ang concern in which, maximum transfer is achieved via matching (source impedance = load impedance). kaya mostly working on impedance analysis na lang, hence, only working on impedances of series networks, and admittances of shunt networks, kaya 'yung Smith Chart merong Impedance and Admittance charts to simplify matching design ('di na kailangang mag-compute ng conjugate pairs.
Y = inverse Z may also not hold true with shorter wavelengths. j100 susceptance may act differently with two transmission lines having characteristic impedances of 50 ohms and 300 ohms respectively. kaya when solving using the Smith Chart, nino-normalize siya.
« Reply #690 on: July 26, 2011, 06:08:39 AM »
made an mcu blink for the first time in 1 year. buti di pa sira.
« Reply #691 on: July 26, 2011, 06:44:02 AM »
if
Z = 1
Y = 1
Z = 1 / Y
then
1 = 1
therefore
Z = Y
but if
Z equates Y
I = 0
and
V = Z x I = 0 = Y x I = 0
so
 Z = 1 / Y
is zero!!!
nyahahahha!!!
 :D :D :D
..still studying gggrrrr!
Offline e-tronix
« Reply #692 on: July 26, 2011, 08:35:09 AM »
pwedi
nagbabasa plang ng datasheets at manual na ndownload ko sana tama tong binabasa ko, so far wala pa kong masyadong naintindihan, hehehe, d kopa nhahawak actual device, dpa nadating from place of richa yang sabi ni sir Dandy. hehehe
Offline iNgine
« Reply #693 on: August 02, 2011, 09:31:36 PM »
subs
"When you remove the impossible, whatever remains, however improbable, must be the TRUTH"
« Reply #694 on: August 02, 2011, 11:41:52 PM »
subs din
Offline bLacK_aNgeL
  • Pogi/Ganda Points: 13
  • i love sukolates...
« Reply #695 on: September 06, 2011, 04:35:12 PM »
korean language
if you can't handle my worst
you don't deserve my best..
Offline DSM_elektronix_shop
  • Pogi/Ganda Points: 153
« Reply #696 on: September 07, 2011, 12:42:54 AM »
kapit bahay ko...
DSM_electronics_shop
Alvin Y. Carulasan
Sinal Village, Taguig city
« Reply #697 on: September 07, 2011, 05:37:35 PM »
Review lang now.. medyo tinatamlay na.. parang mas ok ms na lang ;D ;D ;D
Offline jixes
« Reply #698 on: February 03, 2012, 12:25:16 AM »
I NEED TO BUY WORKING EGBC-04 BLUETOOTH MODULE AT MAX Php1200 in CEBU;
PLS PM ME AT eliseo.caday@yahoo.com thanks in advance
Offline /
  • Pogi/Ganda Points: 317
« Reply #699 on: February 03, 2012, 12:26:24 AM »
Photoshop, illustrator, after effects, cisco.
