Balanced line, Unbalanced line
Offline Captcha
  • 19
  • 1
« on: March 20, 2008, 08:42:52 AM »
which one is better to use in data transmission?
Offline cyanine
  • 24
  • 1
Re: Balanced line, Unbalanced line
« Reply #1 on: March 31, 2008, 09:19:42 AM »
unbalanced line kasi may shielding gaya ng coaxial cable.
  • 11684
  • 711
« Reply #2 on: March 31, 2008, 10:37:34 AM »
depende sa application yan e...
Industrial communications (RS-485) would normally use balanced lines...
USB uses balanced lines too (Differential Signaling)...
ang advantage sa differential signaling (now commonly used in ultra high speed data transfers mostly found on the motherboards of your computers) yung noise sa isang line, cancelled ng noise dun sa kabilang line...
Offline jctupazvi
  • 23
  • 0
« Reply #3 on: April 05, 2008, 11:30:13 PM »
If I am not mistaken ang data transmission ng RS-485 uses differential signalling pero balanced ito because ordinary twisted pair ang gamit and hindi coax. One good example ng unbalanced data transmission ay ang gamit ng mga old long haul microwave systems na ginagamit noon for E1. Ngayon we usually use a balun to convert the E1 BNC connection to RJ45 which is balanced.
"God does not play dice with the universe".
  • 11684
  • 711
« Reply #4 on: April 06, 2008, 12:18:24 AM »
yup RS485 uses differential signalling and balanced lines...
Offline webscatter
  • 210
  • 14
    • Webscatter Online World-WOW
« Reply #5 on: August 17, 2011, 11:56:35 AM »
Di maiwasan both needed to be used ....u cant ignore either in so many applications...
Audio systems alone have both Balance and Unbalanced configuration...
