Possible ba ang computer maging fax machine?
« on: May 21, 2010, 09:20:22 AM »
Is it possible that computer can be a fax machine without subscribing internet fax services? like extremefax or whatever it is? Pwde ba yun?
  • 11684
  • 711
Re: Possible ba ang computer maging fax machine?
« Reply #1 on: May 21, 2010, 10:10:33 AM »
magfa-fax direct sa ibang fax machines? pwede 'yan using dial up modem. alam ko, ganyan fina-fax 'yung ibang electrical plans sa tatay ko.
kung walang phone line modem, kailangan talaga mag-subscribe sa internet services.
Offline pishboy
  • 105
  • 2
  • Eternal Flame
    • bosshardhans.comuf.com
« Reply #2 on: December 15, 2010, 08:43:07 PM »
yup. Ginawa ko na yan dati. Built in na siya sa XP kung ininstall nung pag-install ng OS.
-pirma-
Offline anggwaponi
  • 76
  • 2
  • ayos d2
« Reply #3 on: September 09, 2011, 05:31:28 PM »
hello all  8)
i'm planning to setup a fax server ... please give an idea if it's okay to Win Server 2003 Standard Edition as it's operating system?
besides, what's the best fax modem to be use (i go into external ... since all the slot of my computer are already filled)? i see some already in Cd-R King store but not sure if those are worthy to use  ???
hoping bright ideas can be shared for this inquiry.
cheers!
Offline x13r_kit_0
  • 1817
  • 169
  • --__x13r_kit_0__--
« Reply #4 on: September 09, 2011, 05:39:22 PM »
How about incoming fax document?
printer?
Professional Kuno?,
Tuldok ka lang - ASIN
"Never argue with an idiot, they drag you down to their level and then beat you with experience"
  -nevermind
Offline makuy
  • 186
  • 11
« Reply #5 on: September 10, 2011, 01:19:34 PM »
computer+modem+printer+scanner :D
nakagamit ako nito dati Winfax Pro on windows 98 :D
Offline anggwaponi
  • 76
  • 2
  • ayos d2
« Reply #6 on: September 10, 2011, 03:24:36 PM »
hello x13r_kit_0 at makuy  :)
actually, ang main concern ko dito is anong fax modem ang ginamit (any name/brand in particular)? saka, is the said modem ba mount internally socheted o external fax modem ang ginamit??
besides, the way i understand it ... fax server can be used both as outgoing and incoming fax.
as printer? sorry ha x13r_kit_0  pero 'di ko masyado na-gets anung ibig mo sabihin as printer, you mean print server o print as .pdf file? sana you can elaborate farther x13r_kit_0
any way, salamat talaga sa post o comment n'yo. i really thought that this thread can no longer be active. much more na i'm seldom coming in here since i'm also pre-occupied with my daily bread  :D
matsalams
Offline tikbalang
  • 130
  • 23
    • kill sp@m
« Reply #7 on: September 11, 2011, 02:31:50 AM »
kahit anong modem pwede na sa ngayon since 14.4kbps lang ang typical transmission rate ng mga fax machines. kung boxed yung modem (yung hindi oem), meron all-in-one software bundle yun na pwedeng gawing terminal, voicemail, answering machine, telephone, at fax yung pc. ganyan kami dati nung win 3.11 wfwg using bitware v3.3. kahit DOS pwede mag fax using BGFAX.
http://www.bgfax.com/bgfax.htm
ngayon may tunay na fax na kami kaya di ko na alam.
Offline anggwaponi
  • 76
  • 2
  • ayos d2
« Reply #8 on: September 11, 2011, 07:19:27 AM »
hello tikbalang  :)
meron ako dating modem 'yung parang bundled na 1-card (sa likod may RJ11 port) at may kasamang external na box (actually, kulay transparent green tapos may mga ilaw2x). duon ikinakabit 'yong connection from telephone line - computer (dati kasi dial-up pa at gumagamit kami 'yong scratch card).
ginagamit namin ito sa aming lumang computer ... pero nang bumili kami ng bagong computer, tinanggal ko from lumang computer for safe-keeping tapos binigay namin 'yung lumang computer.
ang nangyari ngayon, loaded lahat slots ng bagong computer ko kasi 4-slot lang available. hinahanap ko 'yong modem na external tapos connected lang through parallel port ng computer.
meron dati binibinta sa CdRKing pero out-of-stock na at 'di na daw sila nag-request ng bagong stock kasi obsolete (CNET yata brand). meron naman available 'yung USB-type na fax modem .. pero ang mahal (P700++).
i'm looking kahit 2nd hand o surplus basta worthy to used pa at if pero meron software, sana it's working also. besides, it will work with my OS which is Win Server 2003 SE.
Offline BANNEDMemberAccount
  • 2747
  • 130
« Reply #9 on: September 11, 2011, 07:47:00 AM »
hello all  8)
cheers!
sir baka mapagalitan aka ng Moderator natin sa picture mo sa signature.
Pweding Pwedi. kailangan mo lang iprogram ang incoming message then using printer, gawa ka lang ng command using API para magprint automatically yung priter, syempre kailangan mo talaga ng any internet connection
Wag HIHITHIT ng Katol para hinde Tamang Hinala  Account is permanently BANNED due to Accumulation of forum rules and violations.
Offline THXneo
  • 698
  • 45
  • DJ, Home Theater Fanatic
« Reply #10 on: September 11, 2011, 09:09:06 AM »
heto try mo. kakailanganin mo lang ay modem at telephone line.
http://www.essentialfax.com/
http://www.snappysoftware.com/
More to Lose by Seona Dancing
Offline tikbalang
  • 130
  • 23
    • kill sp@m
« Reply #11 on: September 11, 2011, 04:24:06 PM »
baka meron pa sa mga used computer stores. kung hindi man modem, may mga mobo na built-in yung soundcard at modem. kung hindi visible yung modem port, meron yun slot na pwedeng kabitan ng header para saksakan ng telephone line. parang soundcard lang ang modem, meron lang itong additional circuitry para sa phoneline.
Offline anggwaponi
  • 76
  • 2
  • ayos d2
« Reply #12 on: September 11, 2011, 09:56:54 PM »
hi Positron E+  :)
sorry ngayon ko lang na-noticed ang reply mo ... parang totally i overlook it  :-[
but i'm a little bit puzzled sa sabi mo na, " ... baka mapagalitan aka ng Moderator natin sa picture mo sa signature ... ". bakit, what's wrong with my picture, as well, with my signature? sana you can elaborate further so if ever i commit something overboard ... i can immediately change it  :-X
any way, baka naman pwede mo rin througly discuss paano i-program ang incoming message using printer? hope you can give more hint din sa pagawa ng command using API para magprint automatically yung priter??
nevertheless, salamat rin sa ino sharing Positron E+ .. yur the man  ;)
  • 11684
  • 711
« Reply #13 on: September 12, 2011, 12:51:21 AM »
from Ninang Shey:
karamihan sa mga bagong member they do not even bother to read the registration agreement.. register agad then post agad only to be warned by me and the moderators about posting in all capitalized letters, images on forum signatures and irrelevant thread titles gaya ng "help po"..
Offline anggwaponi
  • 76
  • 2
  • ayos d2
« Reply #14 on: September 12, 2011, 08:30:05 AM »
from Ninang Shey:
hello Ninang Shey & rdpzycho  ;)
salamat talaga for reminding me tungkol sa registration agreement .. i really didn't realized of the said violation. pero give me more time para mabasa ko ulit (at ma-update ko profile ko).
nevertheless, i'm still looking forward for more inputs sa thread na ito. i'm sure na maraming kababayan natin ang expert na sa field na ito .. i guess they really want to share their expertise but they just don't know where  :-*
Offline anggwaponi
  • 76
  • 2
  • ayos d2
« Reply #15 on: September 13, 2011, 10:31:03 AM »
hello THXneo at tikbalang  ;)
tanong ko lang sana THXneo if have you tried setting-up fax modem o fax server? it just happend na somehow i really need someone or anybody who can guide me better most especially related to gadgets that i still need to acquire  ???
likewise, tikbalang are their also any particular sound card with such features built-in ang modem ... is it socheted type, i mean inserted to a free slot? besides, can you recommend or suggest any stores that into 2nd or surplus items??
sana you can enligthen me of my inquiry  :(
Offline /
  • 1899
  • 317
« Reply #16 on: September 13, 2011, 02:08:45 PM »
basa mode..
Offline THXneo
  • 698
  • 45
« Reply #17 on: September 13, 2011, 02:15:21 PM »
yup, na try ko na yan before.kailangan mo lang ay dedicated landline para sa 56k modem.
meron usb o pci modem na available.ang US robotics ang pinaka maganda dahil sa maraming options na pagagamitan.pag na-install mo na ang software,i-gu-guide ka non sa bawat settings at meron test option para masiguro na tama ang ginawa mo setting.kung sa office o marami kayo gagamit pede mo sya setup via local lines(like dial 9 sa outgoing sa PABX),kailangan nka install din sa ibang pc para magamit ng lahat.automatic sya magre-recieve ng incoming fax at i-si-save nya yun sa pc mo o i-derect print sa printer kung meron.mas malinaw ang resolution ng fax sa pc compare sa fax machine talaga. ang problema lang sa mga software na ito.mostly pang windows XP lng.ang setup nito o setting madali lang.
Offline THXneo
  • 698
  • 45
« Reply #18 on: September 13, 2011, 02:23:53 PM »
eto ang usb type na modem:
eto nman ang pci card:
eto nman external fax modem:
Offline THXneo
  • 698
  • 45
« Reply #19 on: September 13, 2011, 02:43:16 PM »
one more thing,di mo na kakailanganin ang scanner pag meron ka nito.mostly pag MSoffice,pdf,jpg,bmp.tiff atbpang files unless na nka hard copy ay pede direct print na sa fax program.meron sya kasama printer driver na i-coconvert nya sya fax file.meron ito inbox,outbox para sa na send at na recieve na docs.
pede ka mag DL ng demo version (30days) para ma test mo,saka ka lang bumili it suited sa kailangan mo ang napili mong software. ;D
