Electronics Lab Philippines
Amateur Radio Groups
Offline bravokilo
  • 6700
  • 185
Re: Amateur Radio Groups
« Reply #100 on: January 11, 2019, 10:21:59 AM »
Dok, matagal na off air ako. Hinahanap ko na lang kausap. No fixed channel. May nasty , may mababait, may bakla.
Tell me your location and mobile number. I can contact yuou via cp muna, then we choose a clean channel.
Offline amadjo01
  • 720
  • 14
  • Meow....
« Reply #101 on: January 15, 2019, 10:55:46 AM »
Hello, Amad (that is the name of my grand uncle). Yes, buhayin natin. Location mo. Yung 888 mo related ba yan as 555 sardinas? Joke lang. VHF ba yan? I have VHF that could pump 45 watts. I could hit you if you are in Metro Manila maybe and has an antenna. My antenna 30 feet up broke si I ma using a simple dipole sa bakod.
Let me hear from you.
Hi sir BK
Yung nabibili lang po ito sa raon, gamit lang namin kapag nag i install nang mga solar panels
Offline bravokilo
  • 6700
  • 185
« Reply #102 on: January 16, 2019, 09:51:12 AM »
Amad, I started in 1978 with just a porable radio, Yaesu. Everybody thought I had a base. I was only putting 5 watts. The antenna is a very big factor kahit 5 watts. In HF, amateurs talk to each other using QRP radios which can be as low as 100 MW. The low side of the icom dati was 2 watts.
The Chinese radios are working well but their durability is an issue. Motorola has the best casing. Icom is midway. Ok na. Avoid those with digital displays. The readout is the first to go. I have friends who have Icoms with bad readout na. I kept a pair of 02N na de kamot, thumbwheel. NO LCD na madali masira. Go for manual. However, the better portables are those I mentioned, the UV82 in my previous post which has digital display.
The solution when the read out is damaged is to have a scanner at home. Push the transmit and you will the frequency you are in. Or if you have a second unit with a goods display. It can be the scanner.
In can be converted pero ma trabajo, converted to  thumbwheel. Parejo lang ang synthesizer nila. Motorola lahat yan kahit ICOM ang radyo.
Tell me you location is I can touch base with you sa radio but give your CP number kahit sa PM......so I can text you first then we try to contact each other.
Offline amadjo01
  • 720
  • 14
  • Meow....
« Reply #103 on: January 17, 2019, 05:27:05 AM »
Hi sir BK
PM sent for my contact....
Subscribe din ako sa isa mo pa thread
Offline amadjo01
  • 720
  • 14
  • Meow....
« Reply #104 on: February 13, 2019, 04:28:37 PM »
buhayin ulit natin to.
Offline bravokilo
  • 6700
  • 185
« Reply #105 on: February 14, 2019, 09:48:17 AM »
Shoot AMADJ. Dito lang ako and si Super Z.
In fact, I have expertise in building TX and RX from single tannies to digital like for RC. I just need people interested and serious.
LOTS TO PASS ON. Bring them in......
Offline >>>^żżż^<<<
  • 13845
  • 706
  • żżż
« Reply #106 on: February 14, 2019, 09:46:22 PM »
Sir bk ano gamit para sa freq scanner?
http://www.elab.ph/index.php?topic=52236.0 TF?
http://www.elab.ph/index.php?topic=41860 ? ? ? DIY traffo Test Build Uli
http://www.elab.ph/index.php?topic=33717  I2c / spi programmer
http://www.elab.ph/index.php?topic=37150.0 Lcr esr makikigulo rin ba kayo ??? Test Build
http://www.elab.ph/index.php?topic=29963.0 Esr collection na malamig
http://www.elab.ph/index.php?topic=25854.0 Basic C++ Programming Tutorials by Prof Asimo
We only live once,treasure those we love, make friends not enemies and keep our family closer. And we will be at peace.
FISH
Offline bravokilo
  • 6700
  • 185
« Reply #107 on: February 18, 2019, 08:41:03 AM »
You mean what a freq scanner is for. Well, you  an listen in over a wide range of frequency and know anong malakas sa area mo. You can earvesdrop. You can use it to know what your TX freq. is. It is a multi band receiver.
Offline >>>^żżż^<<<
  • 13845
  • 706
  • żżż
« Reply #108 on: February 18, 2019, 10:44:24 PM »
I mean ano gamit mong freq scanner dati kasi ang nakikita ko ay base radio pero sineset sa scan mode para sa mga buhay na linya continous scanning lang.
FISH
Offline bravokilo
  • 6700
  • 185
« Reply #109 on: February 21, 2019, 09:36:45 AM »
Tama ka Tanong Sis. Yung mga radio may scanning feuture pero limited dun sa range of frquencies.
Offline amadjo01
  • 720
  • 14
  • Meow....
« Reply #110 on: May 08, 2019, 06:06:07 PM »
May mga active freq bo ba na nasa range nang baofeng 888s?
Offline amadjo01
  • 720
  • 14
  • Meow....
« Reply #111 on: March 26, 2020, 07:50:59 PM »
wala na pala ito...
Offline bravokilo
  • 6700
  • 185
« Reply #112 on: March 27, 2020, 10:20:57 AM »
Sis, I suspect amny who bought th 888 are using it either directly in a small group with no outside antenna. or, if they do, it is low just for themselves. Or, they just do no entertain outsiders. Mostly I ould think they use it ffor security guards.
*** is in UHF. I am in VHF and I hear many stations and even talk to some. You can get the UV82 or any dual band. But if you want to QSO, put an outside base antenna.
I recommend the Slim Jim or if you have height, even a quarter wave "ting ting". What is your location?
You may contCT ME VIA CP: 0933275 5010.
Offline >>>^żżż^<<<
  • 13845
  • 706
  • żżż
« Reply #113 on: March 29, 2020, 06:16:03 PM »
888 ay pang 2km lang yata so small area lang coverage parang sa ad nila upto 5km. Minsan maririnig ko sa logistic lang mga hardware store. sir bk kaya ba ng 25watter from luzon tail hanggang sa inyo? with outside antenna.
FISH
Offline amadjo01
  • 720
  • 14
  • Meow....
« Reply #114 on: March 30, 2020, 08:54:59 PM »
Hi Everyone,
i am not sure kung dual band itong gamit ko na 888s nang baofeng, pero may naka save ako na img file, na na download over internet, at yung channel 1 to 7 at naka VHF, i will try kung pwede ko baguhin ang freq, then i will try to share kung umubra using chirp software...
