Leach Low TIM Amplifier V4.5
Offline Engr. Dacuycoy
  • 1164
  • 238
  • Proton Orcad EasyPCB User
« on: October 07, 2010, 08:57:33 PM »
If there is enough demand I will post the Layout with new trannies except for the output.
Offline jiggins20
  • 797
  • 34
Re: Leach Low TIM Amplifier V4.5
« Reply #1 on: October 08, 2010, 10:50:04 AM »
cge po post nyo na...
Audio amp addict
Offline electronic repairer
  • 257
  • 14
  • amu lat im....
« Reply #2 on: October 09, 2010, 10:15:14 AM »
Cge engr. post niyo na yan...
para mapagaralan naman natin..
thanks in advance..
Patience is the best attitude of an electronic repairer.
  • 1164
  • 238
« Reply #3 on: October 09, 2010, 05:17:10 PM »
Offline kulapo
  • 248
  • 30
« Reply #4 on: November 09, 2010, 09:35:50 PM »
ok to a, napag aralan ko na mga detalye, problema lang yung availability ng transistor parts except output trannies... ??? engr.kumusta yung new substitute trannies natin dyan ok naba? ;D
  • 257
  • 14
  • amu lat im....
« Reply #5 on: November 10, 2010, 08:24:01 AM »
ilabas mo na engr. yung mga substitute sa trannies..
  • 11484
  • 872
« Reply #6 on: December 01, 2010, 08:16:07 AM »
@engineer, sent you email......are you offering boards as in "group buy"? if so you can count me in for 4 boards, possibly more depending on price....
  • 11484
  • 872
« Reply #7 on: December 01, 2010, 08:28:39 AM »
  • 1164
  • 238
« Reply #8 on: December 01, 2010, 12:51:18 PM »
it's nice to see you here sir tony. thanks for the email... in a few days i will post the old version of V4.5 then the 3 pairs version and 6 pairs version. for the 3 and six pairs version we need to calculate the resistor of the protection circuit and i need the expertice of our audio pro's and practioners.
  • 11484
  • 872
« Reply #9 on: December 01, 2010, 01:26:26 PM »
@engineer, you can read thru these for more info about SOA:http://home.alphalink.com.au/~cambie/ETI466Web.htm
  • 1164
  • 238
« Reply #10 on: December 01, 2010, 01:49:51 PM »
thanks for link though i can't read it this time since i am in the office. the 3 and 6 pairs version is based on Jens Rasmussen DIYAUDIO. it was made single sided for the elab audio enthusias to make their own pcb. the dimensions are almost identical.
  • 11484
  • 872
« Reply #11 on: December 02, 2010, 09:52:16 PM »
it is sad that prof. Leach passed......http://www.diyaudio.com/forums/everything-else/177692-w-m-leach-passed.html
his design stands the test of time....i have built lots of amps based on his design...have exchanged emails with him.....
  • 1164
  • 238
« Reply #12 on: December 02, 2010, 10:09:40 PM »
The loss of Dr. Leach will leave a great hole in the ranks of those who will train the next generation of audio engineers.
http://www.ece.gatech.edu/personnel/bio.php?id=62
http://www.ece.gatech.edu/media/news/release.php?id=5255
Offline danny
  • 7646
  • 535
« Reply #13 on: December 03, 2010, 04:17:58 AM »
oh my tsk tsk
another one? after Randy,  now its Dr. Leach naman  :( :(
we are losing great audio engineers
  • 5744
  • 402
« Reply #14 on: December 03, 2010, 04:36:22 AM »
great new ones will be born pa din...
it's sad pero his design stood the test of time and it will be.
Offline danny
  • 7646
  • 535
« Reply #15 on: December 03, 2010, 04:52:27 AM »
pero nakakagulat lang dba kung iisipin
with in a year dalawa nalagas agad
si randy at si leach  :(
Offline kulapo
  • 248
  • 30
« Reply #16 on: December 04, 2010, 07:24:03 AM »
mga master tanong ko lang po, sa amp nato, kung halimbawa walang mabiling capacitor na mica pwede ba yung ceramic, ano pong epekto nito sa ampli? ???
  • 11484
  • 872
« Reply #17 on: December 04, 2010, 08:43:22 AM »
silvered mica ang preferred because of its stability with temperature, if you can not source it, then you can use ceramics. i have used both and soundwise i am not able to hear any difference.....
silvered micas are available from Mouser, Digi-key, Allied and other stateside vendors....
maybe engineer can do a group buy for these parts depending interest....
Offline kulapo
  • 248
  • 30
« Reply #18 on: December 04, 2010, 12:02:43 PM »
ok sir salamat.
  • 1164
  • 238
