Wireless LAN design
Wireless LAN design
« on: March 03, 2011, 01:00:07 AM »
Good Morning masters! Help naman po!
May project kami to design a Wireless LAN. Ang building po namin is 6 floors (HOTEL), lalagyan po dapat namin ng WiFi each floor. Papaano po ang design nito?
Internet-Firewall-Wireless Router? Paano po ba magdesign if 1 server lang located sa Ground floor? Salamat po!
Offline alyas
  • 3119
  • 211
Re: Wireless LAN design
« Reply #1 on: March 03, 2011, 07:23:38 AM »
The easiest is to have six wifi routers (one per each floor).  One wifi router will act as the wifi router while the remaining 5 are just configured as access points.  Simply chain them together in series.
« Reply #2 on: March 03, 2011, 09:40:24 AM »
sir salamat po sa pagreply. paano ko po sila iconnect in series? gagamit pa po ba ako ng switch or simple series ko lang sila?
then, pano po ba yun ung topology nito? firewall-router-switch-wireless router? ganito po?
Offline alyas
  • 3119
  • 211
« Reply #3 on: March 03, 2011, 10:31:00 AM »
di mo na kailangan ng switch.  Each of the wifi router typically has 4 ethernet ports and 1 wan port.  sa 5 wifi configured as access point, simply bridge the wan and ethernet ports then it will be configured as access point.  Disable any dhcp server functionality.  You connect the wan port of one access point to 1 of 4 ethernet ports of the other wifi access point ...so na ka chain lang talaga.
« Reply #4 on: March 03, 2011, 11:06:47 AM »
ah ok sir simple lang po pala. maraming salamat po sir.
anyways, ung sa IP address naman po? paano po?
« Reply #5 on: March 03, 2011, 12:06:48 PM »
sir good noon. ask lang po ulit re design.
meron po kasi kaming, internet cafe sa ground floor sa floor plan design namin. hmm. pwede po ba na ung server namin na gamitin as source ng internet for wifi e ung server sa net cafe? or we have to make a separate server? thanks po! :)
Offline mcleod
  • 1167
  • 144
« Reply #6 on: March 28, 2012, 10:00:40 AM »
pa-subs. ano silbi ng server nyo? proxy-server? dns / dhcp server ? search mo sa google ip addressing / lan /wan /wifi /( dns / dhcp / proxy servers) /  how to / router / switch configuration / home networking
