Memory Issue
Offline 4XFOUR
  • 367
  • 34
Re: Memory Issue
« Reply #20 on: July 27, 2012, 06:50:21 PM »
eto may link kung paano matanggal yung limit sa win 32bit, di ko pa nagawa pero mapag experimentohan kung gagana
http://www.evga.com/forums/tm.aspx?m=960087&mpage=1
3rd Island Epicenter
Officially Deployed
  • 11684
  • 711
Re: Memory Issue
« Reply #21 on: July 27, 2012, 07:51:28 PM »
yup, kernel hack pwede. as old as Windows 2000 limit problem 'yung solution. while it works, hindi lahat ng program umaandar ng tama with the hack, though, sa mga bagong program ok naman.
BTW, kahit i-hack 'yung kernel, per program, nasa 2GB to 3GB pa rin ang limit (nandun sa una kong pinost na article) at a time.
Offline robbietan
  • 697
  • 22
Re: Memory Issue
« Reply #22 on: August 01, 2012, 09:21:38 AM »
from http://msdn.microsoft.com/en-us/library/windows/desktop/aa366778%28v=vs.85%29.aspx
win xp limit is 4GB for 32 bit, 128GB for 64 bit
win 7 limit is 4GB for 32 bit, 8 GB for 64 bit (home basic version)
apqi.ph
Offline THXneo
  • 698
  • 45
  • DJ, Home Theater Fanatic
Re: Memory Issue
« Reply #23 on: August 01, 2012, 04:43:54 PM »
^me factor din ang build ng laptop. kailangan supported din ng processor mo ang 64 bit.kung 32bit lang ang processor ng lappy mo.di mo rin ma-install ang 64bit na OS.
pero pag 64 bit ang processor ng lappy mo ay pwede sya ma-installan ng 32bit na OS.
ang 32 bit na processor hanggang 4gb lang na memory ang supported.kahit lagyan mo pa ng 8gb pataas. 4gb pa rin ang gagamitin ng system.
ang 64 bit naman na cpu 32gb pa lang ang supported. pag XEON na processor 64gb pataas pwede.
sa mga bagong mobo ngayon pwede na na gumamit ng 64bit o 32bit na application. wala na ang compability issue.
tingnan mo ito:
http://www.youtube.com/watch?v=SfCcvlLEwZo&feature=related
http://www.youtube.com/watch?v=s1WnjQpuexU
More to Lose by Seona Dancing
  • 6434
  • 492
Re: Memory Issue
« Reply #24 on: August 13, 2012, 05:55:26 PM »
Panu malalaman if 64bit ready na yung processor ko? meron ka utility para dito?
EDIT: Ito pala...
download cpu-z http://www.cpuid.com/cpuz.php
it will be a zip file. unzip it and then run the exe and then it will collect info about your processor and then under the CPU tab, in the instructions column, see if you have any of these AMD64, x86-x64 or EM64T. if you have any of these then your processor is 64 bit.
this was the direct way. other way, right click "my computer" and then click properties and note down your processor number and then google it and then see in its specs if it is 64 bit or 32 bit. however, if your computer is any p-4 at 3 GHz or above or any new processor than that or any AMD 64 or AMD dual core then you have a 64 bit processor.
you can even see the specs of your computer at your manufacturers site to see if you have a 64bit processor.
but i think that a software's installation will be more affected by the technology of the OS if its 64bit or 32bit than from your processors technology
Offline Nikola Mandić Tesla
  • 444
  • 39
Re: Memory Issue
« Reply #25 on: August 13, 2012, 07:52:14 PM »
problema lang sa 64bit yung mga lumang softwares madalas mahirap patakbuhin
I'm open to trying new ideas. Nothing ventured, nothing gained...
Offline centOS
  • 683
  • 46
  • screw the screw
Re: Memory Issue
« Reply #26 on: August 14, 2012, 07:04:45 AM »
ang ginagawa ko dito right click installer/software na installed tapos punta sa compatibility: tapos check dialog box " Run this program in compatibility mode for" select os na gusto mo kung saan working yung installed mo na software/program...
go to " privilege level " check " Run this program as administrator " then click " Change settings for all users " tapos check mo ulet yun compatibility mode and administrator... ;)
http://www.elab.ph/forum/index.php?topic=25854.0
http://www.elab.ph/forum/index.php?topic=42197.msg673054;boardseen#new
http://www.elab.ph/forum/index.php?topic=34991.0
http://www.elab.ph/forum/index.php?topic=36002.0
  • 11684
  • 711
Re: Memory Issue
« Reply #27 on: August 14, 2012, 02:08:56 PM »
^ tama sir. isang software lang ang 'di ko na-install sa 64-bit na Windows 7, 'yung Ansoft HFSS 11 32-bit, kahit ilagay sa compatibility mode ayaw niyang i-install.
Windows 7 64-bit Ultimate ang gamit ko, BTW.
Offline Ron_wrong
  • 1775
  • 115
Re: Memory Issue
« Reply #28 on: August 14, 2012, 05:53:44 PM »
May mga gadget ako which obsolete na yung support..meaning wala ng update likewise sa driver nito...kaya no choice but to install 32bit OS...May option is dual booting or run it on VM...
So if mag Win 7 Ultimate ako, kahit 32bit lang ma address na yung memory issue ko?
yes,, i dont see any issues on the bios.
try to install the ultimate 32bit version. let see kung mkita nya eh 4gb or 3gb lang. hindi pa ako nginstalled ng 32bit na syete. :D
and pacheck na dn ng CAS. thanks.
(hmmmm, bkit kaya may incompatibility issue ang mga 32bit sa 64 bit, dapat supported na un. un ang alam ko. or pde naman irun in 32bit version)
I am a DBA.
