washing machine problem
« on: October 18, 2012, 03:36:07 PM »
paano ko po kaya maayos wash namin, pag naka-on napo kasi ayaw umikot ng motor, ugong lng sya hirap sya umikot. pag naka off  maluwag naman, madaling ikot ng kamay ung motor. pls. help
Re: washing machine problem
« Reply #1 on: October 18, 2012, 06:17:56 PM »
check mo kung my kalog ang bushing ng motor, pag meron palit kana shufting at bushing para ayos...
Offline x13r_kit_0
  • 1817
  • 169
  • --__x13r_kit_0__--
« Reply #2 on: October 18, 2012, 06:27:24 PM »
ano brand,model.,
manual o automatic.?
capacitor lang kadalasan nyan.. 10 to 12 uF.
Professional Kuno?,
Tuldok ka lang - ASIN
"Never argue with an idiot, they drag you down to their level and then beat you with experience"
  -nevermind
Offline grizzom
  • 133
  • 4
  • Walang malayong kulangot sa mahabang kuko.
« Reply #3 on: October 19, 2012, 02:04:35 PM »
Pag hindi capacitor sira check mo ung wire sa tester minsan my isang putol dun sa wire kaya ganyan. check mo mga wire ng motor mismo baka my putol na isa testerin mo.
Offline >>>^żżż^<<<
  • 13845
  • 706
  • żżż
« Reply #4 on: October 19, 2012, 02:28:00 PM »
sundin ang payo ng mga master. simulan sa pagcheck ng mga bushing kung ok naman. check capacitor, then wiring. Also check kung maluwag na belt.  :)
FISH
  • 11684
  • 711
« Reply #5 on: October 19, 2012, 04:27:56 PM »
ang isang way para ma-check kung may problema sa capacitor (basta AC motor), kapag may supply na 'yung motor at umugong, pihitin ng kamay (kung kakayanin ng kamay, pero kung power tools katulad ng bench grinder, sinelas ang gamitin). kapag biglang umikot ng walang hirap 'yung motor, pwedeng electrical ang problema, capacitor, wiring, etc.
kung umikot at kumalog o lumalangitngit, pwedeng mechanical ang problema.
Offline cyrusnicole
  • 1293
  • 83
  • WORK LIKE A SLAVE.....DRINK LIKE A KING..!!!!!
« Reply #6 on: October 19, 2012, 05:34:48 PM »
my spinner ba to sis?...alin ang di iikot..ung sa washer or sa spinner?.....
work like a slave...drink like a king   :)
Offline kokel2004
  • 133
  • 5
  • *Ang Diyos ay Pag-ibig*
« Reply #7 on: October 20, 2012, 12:30:29 PM »
Gandang araw lexy at mga master! Tama mga master check mo lahat possibilities. Pero base sa aking eksperyensa pag ganyang umuugong bushing at shafting na yan gaya  nabanggit ni sir lorenso. Pag "capacitor" sira ay mabagal ang takbo ng motor at minsan damay na rin belt.
Kay Yahweh ka magtiwala, buong puso at lubusan,
At huwag kang mananangan sa sariling karunungan.
Siya ang sangguniin sa lahat mong balak,
At kanya kang itutumpak sa lahat ng iyong lakad. :-)
Offline angel_017
  • 1001
  • 122
  • (c.p.a )
« Reply #8 on: October 20, 2012, 01:36:53 PM »
anong klaseng washing machine kaya ito?
@tatay ts.. sundin mo sina tatay... iyan lang ang mga pwede sira.. o na check niyo na lahat baka wash motor na...
"For god so loved the world that he gave his one and only son that whoever believes in him should not perish but have an eternal life"  JOHN 3:16
THINK like a man of ACTION. :)
ACT like a man of THOUGHT.
https://www.facebook.com/iamsandraflirt
Offline 1meg
  • 884
  • 35
« Reply #9 on: October 20, 2012, 03:03:40 PM »
malamang sira ang bushing pag on mo di talaga iikot yan dahil didikit na yan kasi sira ang bushing
Offline de PatAtas
  • 1895
  • 336
  • ' The unbreakable
« Reply #10 on: October 20, 2012, 03:43:35 PM »
' ts try mo to... then pag ayaw pa rin.. malamang motor may short sa windings..
Offline Lola Baciang
  • 1914
  • 235
« Reply #11 on: October 20, 2012, 05:50:53 PM »
ok pa ba ang timer nyan,apo?
Expect The Unexpected
Offline bravokilo
  • 6707
  • 185
« Reply #12 on: October 21, 2012, 09:35:38 PM »
Lexy, here is the basics of the motor. Usually 3 wires yan. Isa common, yung dalaw parejo ang resistances nila. A capacitor is across these two terminals. Let us call the common line 3, and the othr two 1 and 2.  the cap is across 1 and 2. Meralco line sa common. If you touch  the othr Meralco line to Pin1, it will spin. Line 1 is recta and line 2 is off phase via the cap. Now, if you touch line 2, it will reverse, line 2 is recta and line 1 is via the cap. That is how simple it is. Now, the common Washing Machine has the switching on the timer switch mismo. It will toucj Line1 for a while then stop. Then it will touch line 2. Kung walang cap. uugung yan but won't start cuz it is the line after the cap that will spin it to one direction.  So the cap is a starting point. Look at the cap of the spinner if similar, then try to use it. If it works, replace the orig one. The spinner does not rotate both ways. The motor set up is exactly the same but these is no alternate switching on the timer. Get a tester and put on X1. unplug the WM. Just read the resistance of linme 1 and 2. If open, one of then is open. Can't be both since umuugung, one is good. TEst line 1 to line3 and line 2 to line 3. You will confirm one of them is open. If so or if its the bushing, go to Raon and get a new one. It will be cheaper than to rewind. They can be as low as P450. Go to Sta Cruz, find Chowking. It is on the right side of a building by the Church. To the left of the building is Ronquillo. See Jollibee there. Right across is United Electrical.....mura dun pero pumila ka. Bring the original motor.
BK
Offline x13r_kit_0
  • 1817
  • 169
« Reply #13 on: October 22, 2012, 05:02:02 PM »
The problem is nawala si TS... :) :)
BTW thanks for wash motor buying tips sir BK..a pts 4 you..meron palang mas mura sa binibilhan ko dati.. :)
Professional Kuno?,
  -nevermind
« Reply #14 on: January 26, 2020, 01:06:57 PM »
gud pm po. ask ko lang po pano po ba gagawin pag nag error E4 ung automatic washing namin. fukuda po brand nya. salamat po sa sasagot. God bless!
« Reply #15 on: March 24, 2020, 12:26:51 AM »
I think ibigsabihin is either power or water supply ang problem...na try mo na irestart?
