Repairing RAM: Component Level
  • 6201
  • 405
« on: July 29, 2008, 08:20:30 AM »
Meron na bang nakapag repair sa inyo ng RAM component level?
eto kasi yung nangyayari sa akin ngayon...
Memtest Screenshot:
tinitignan ko yung Error bits: 000040000. kung sa binary 1000000000000000000. mukhang may isang bit na palaging nag eerror.
eto yung RAM
I inspected it already and I don't have idea kung ano ang problem, kung sa trace or one of the eight mem modules... I am tempted na to remove the memory modules one by one...
This occurs only around 3 minutes after boot-up... mukhang nagkakaroon ng temp problems...
Any inputs will be highly appreciated. :) :) :)
  • 11684
  • 711
Re: Repairing RAM: Component Level
« Reply #1 on: July 29, 2008, 09:32:39 PM »
heatsink muna. mura lang ata sa CD-R King. ;D
gusto ko rin magkalas ng RAM chip sa RAM Module. ;D
Offline 1110000
  • 2057
  • 28
« Reply #2 on: July 30, 2008, 07:12:08 PM »
pede kaya palita yung mga chip nyan ng mga 1 gig bawat isa :o yung nkukuha sa mga flash disk hehehehehe
E153C51513
  • 11684
  • 711
« Reply #3 on: July 30, 2008, 08:37:10 PM »
magkaiba ng timing at specs 'yun.
Offline 1110000
  • 2057
  • 28
« Reply #4 on: July 31, 2008, 12:49:17 AM »
ahhh sayang hehe
E153C51513
« Reply #5 on: August 29, 2008, 11:48:28 PM »
pwede mo palitan ung clip ng same ic code no.
pero hindi pwde lumagpas sa dati nya capacity
may makikita ka microchip sa memory 8 pins eeprom yan dyan naka-record ang spec ng memory.
yan ang pinag-iisipan ko kung paano mag-program
 ;D
« Reply #6 on: September 01, 2008, 07:02:30 AM »
wow... mga programmers.. hehehe
  • 11684
  • 711
« Reply #7 on: September 02, 2008, 12:08:21 AM »
@sevenstring: kapag ayaw nang umandar pa-arbor nung buong RAM chips na natitira. ;D
Offline BANNEDMemberAccount
  • 2747
  • 130
« Reply #8 on: December 09, 2010, 12:39:48 AM »
dito rin ako napunta sa research ko sa google, meron kasi ako memory sa laptop ko isang 512 at 1 gig parehong sira, e hirap pa naman hanapin ng memory ng laptop ko kasi ddr1
ito mga naresearch ko,
http://www.memorytesters.com/articles/memory_repair.htm
http://forums.cgsociety.org/archive/index.php/t-350572.html
yung isa may RAMCHECK device
my two memory
Wag HIHITHIT ng Katol para hinde Tamang Hinala  Account is permanently BANNED due to Accumulation of forum rules and violations.
Offline updated
  • 769
  • 22
« Reply #9 on: December 09, 2010, 12:53:42 AM »
nakapag repair na kami ng ram. kaso pang pentium 1 ata na ram yun. anyway madami din na IC, signature analysis yung appoarch. Address at data yung tinignan nami. altough naka parallel lahat yun, makikita kung anong pin yung may tama through comparison, dapat kasi magkakaparehas lahat ng address at data line. after ma isolate yung pin, tapos sunod na problem ay pag hanap ng IC, aalamin muna kung ano kalase ng sira based sa ASA, kapag nalama na medyo short ang sira though resistance naman.
sa temp problems, naka encounter na kami na kapag normal temp ok yung device, pag umiinit nag short yung pins nya. so pinainitan namin ng hot air habang nag test para makita at lumabas yung sira.
ewan ko lang kung makaka tulong to.. share lang
  • 2747
  • 130
« Reply #10 on: December 09, 2010, 01:13:22 AM »
mahirap dito yung gamit sa pagtanggal ng IC
  • 11684
  • 711
« Reply #11 on: December 09, 2010, 01:53:35 AM »
kaya pa 'yan ng ordinaryong panghinang. punuan lang ng tingga magkabila.
Offline de PatAtas
  • 1895
  • 336
  • ' The unbreakable
« Reply #12 on: December 09, 2010, 01:28:29 PM »
' ang gagaling ah,,,pati ram na rerepair,,,pa repair ko kaya yung mga SDRAM ko dito,, ;D
Offline /
  • 1899
  • 317
« Reply #13 on: December 09, 2010, 01:37:51 PM »
kalasin mo na manay...
  • 2747
  • 130
« Reply #14 on: December 09, 2010, 01:43:52 PM »
ganito kalupit ang mga taga elab :)
bili kaya ng mga ram sa quiapo yung IC importante. mas makakatipid siguro at kahit sd-ram to ddr 3 kayang gawin :)
Offline updated
  • 769
  • 22
« Reply #15 on: December 09, 2010, 01:46:29 PM »
kalasin mo na sis..
Offline electronic repairer
  • 257
  • 14
  • amu lat im....
« Reply #16 on: December 29, 2010, 01:50:40 PM »
madali lang matanggal yang mga ic sa RAM hotair at flux lang..
Patience is the best attitude of an electronic repairer.
  • 2747
  • 130
« Reply #17 on: July 13, 2011, 05:25:24 PM »
ilagay sa komokolong tubig...para mainitan/.
nde kaya kalawangin sir?
(walang kasamang bawang,sibuyas,paminta,sinigang mix :) )
