VB 2010 small problem <3
Offline bibang
  • 142
  • 2
  • likeaboss c:
« on: December 05, 2012, 10:27:57 AM »
eto po question ko, pde po ba yun sa VB 2010 yung for example may button (or any object) ako, then when i place my pointer at that button (without clicking) ay may lalabas na description/information nya, sana nakuha nyo yung ibig kong sabihin hehe, ty
bakasibibangyan <3
Offline motion55
  • 3169
  • 520
Re: VB 2010 small problem <3
« Reply #1 on: December 05, 2012, 06:32:56 PM »
Sa windows pwede yan kahit anung programming language. Sa VB.NET using VS2010 here is an example:
http://stackoverflow.com/questions/5545257/creating-a-tip-balloon-over-a-control-on-hover
"Set your mind free!"
Offline bibang
  • 142
  • 2
  • likeaboss c:
« Reply #2 on: December 05, 2012, 09:45:02 PM »
thnx, let me try, sir how about this problem i posted,just trying if you know this, thnx
http://www.elab.ph/forum/index.php?topic=37686.0
bakasibibangyan <3
Offline motion55
  • 3169
  • 520
« Reply #3 on: December 06, 2012, 06:49:59 AM »
^^^I am not an expert in VB. But the reason na walang nag respond is probably because sa mga nakaka-alam ng sagot ay dapat kaya mo i-Google ang sagot. Ayaw nila maging dependent ka sa spoon feeding. Di ako gumagamit ng VB ever pero nakita ko kaagad ang sagot by simply googling "VB textbox properties and methods". I hope this helps.
Offline Arvie
  • 62
  • 5
« Reply #4 on: December 07, 2012, 03:15:21 PM »
Use MouseEnter event.
Offline bibang
  • 142
  • 2
  • likeaboss c:
« Reply #5 on: December 07, 2012, 09:48:11 PM »
ng goo2gle po ako, nooby din po ako sa VB kaya di ko malaman yung ryt term sa pg google kaya hirap hanapin c: by d way thnx,
bakasibibangyan <3
« Reply #6 on: March 18, 2013, 09:59:43 PM »
Nasagot na ba ito? pwede mong itry ung toolTip, mabenta to sa work ko
    Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        'uppon loading of form this will be the first activity
        Dim toolTip As New ToolTip()
        toolTip.SetToolTip(Button1, "hey just hit me !!")
    End Sub
Offline bibang
  • 142
  • 2
  • likeaboss c:
« Reply #7 on: March 21, 2013, 12:25:28 PM »
yes sir, sql
bakasibibangyan <3
Offline Lucky@Me
  • 10
  • 0
« Reply #8 on: April 15, 2013, 02:05:59 PM »
Tool tip tlga ang tmang sagot dun... :)
« Reply #9 on: April 15, 2013, 02:08:48 PM »
;D
