vb .net login, case sensitive
Offline bibang
  • 142
  • 2
  • likeaboss c:
« on: February 17, 2013, 06:35:54 PM »
sir i had made a login form in vb 2010 and ms sql server 2008 to store and retreive datas, my question is for example the pass word registered is "bibang" but when i input "BIBANG" it will still logs in, how to set this so that it will only accept passwords that are really registered on my database, it shuld be case sensitive ofc. thank you
bakasibibangyan <3
Re: vb .net login, case sensitive
« Reply #1 on: February 19, 2013, 09:47:08 AM »
Dim uname As String
Dim pwd As String
uname = InputBox("Enter username…", " Enter Username", "username")
If uname = "PrODo" Then 'uname match string
    pwd = InputBox("Enter password…", " Enter Password", "pass")
    If pwd = "paSSWord" Then
        MsgBox("I grAnt thEe!")
    Else
        MsgBox("THOU SHALL NOT PASS!!")
        me.close()
    End If
Else
    MsgBox("THOU SHALL NOT PASS")
    me.close()
End If
-Spoon feeding in the long run teaches us nothing but the shape of the spoon
Offline bibang
  • 142
  • 2
  • likeaboss c:
« Reply #2 on: February 19, 2013, 11:36:33 AM »
is it also applicable if there are lot of users registered? thnks
bakasibibangyan <3
« Reply #3 on: February 19, 2013, 02:28:44 PM »
gamit ka na ng simple storage mo nun kung saan naka store ung mga accounts na icacall mo
Public Class loginFRM
    Private Sub login_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles login.Click
        Dim uname, pwd As String
        Dim dataread As sqlDataReader
        Dim com As New sqlCommand
        uname = Txtuser.Text.trim
        pwd = Txtpwd.Text.trim
        Sql = "SELECT [USERNAMECOLUMN] FROM [ACCOUNTSTABLE] WHERE [USERNAMECOLUMN]='" & uname & "' AND [PASSWORDCOLUMN]='" & pwd & "'"
        com.CommandText = Sql
        com.Connection = con
        MsgBox(Sql)
        If con.State = ConnectionState.Closed Then con.Open()
        'adding few variables
        Dim readuname, readpwd As String = ""
        dataread = com.ExecuteReader
        While dataread.Read()
            readuname = dataread.Item("[Username Column]")
            readpwd = dataread.Item("[Password Column]")
        End While
        'Now check if these two values are the same
        If readuname = uname AndAlso readpwd = pwd AndAlso readuname = "" AndAlso readpwd = "" Then
            LS = True
            [your FORM].Show()
            Me.Hide()
        Else
            MessageBox.Show("THOU SHALL NOT PASS!!!", "Login Fail", MessageBoxButtons.OK, MessageBoxIcon.Information)
        End If
    End Sub
End Class
