SANYO ST-21MS22/ CHASSIS NO. ST21MS22-02
Offline Pangasinan boy
  • 6486
  • 867
Re: SANYO ST-21MS22/ CHASSIS NO. ST21MS22-02
« Reply #20 on: March 02, 2013, 06:52:34 PM »
prot ckt na naman ito
resolder muna ang board
saka check mo mga ecap sa secondary ng chopper
Offline rovericks
  • 1124
  • 325
  • I SHALL RETURN
« Reply #21 on: March 02, 2013, 07:46:22 PM »
master rovericks cencia na po pero wala pa ko natatanggap na mapa
pacenxa din.. wala nkong magagawa dyan.. 2 beses na ng email sent sa email mo =rolandllandelar@yahoo.com=.. baka bukas pa mg aapear sa mail mo..
Think before you speak, don't jump to conclusions, i-analyze muna bago mag conclude..
Offline Hengilbert
  • 6430
  • 443
  • ECT 2018 / ECE 2019
« Reply #22 on: March 02, 2013, 07:51:05 PM »
hang HOT ;D
Vacuum tube amplifiers:
http://www.elab.ph/index.php?topic=25478.2380
Gainclone Build Thread:
http://www.elab.ph/index.php?topic=29231.0
Satellite TV shooting:
http://www.elab.ph/index.php?topic=47402
Search me on FB : Hengilbert Lubang
Offline sirjon
  • 917
  • 148
« Reply #23 on: March 02, 2013, 08:16:15 PM »
Hang HOT.
Then measure B+
Pag tumaas sa 115v yung B+, baka yung filter cap sa secondary output line ng PSU, yung elect. cap mismo sa B+ line, baka leaky o dry na.
Pag bagsak pa rin B+kahit naka-hang nba HOT,  check individual parts sa PSU pati na trimmer, baka me nag change value o yung trimmer eh sira na (in case me trimmer nga)
  • 6486
  • 867
« Reply #24 on: March 02, 2013, 08:20:34 PM »
Hang HOT.
Then measure B+
ang galing talaga mo master sirjon
Offline sirjon
  • 917
  • 148
« Reply #25 on: March 02, 2013, 08:24:41 PM »
Follow up lang sa una mong suggestion...
  • 6486
  • 867
« Reply #26 on: March 02, 2013, 08:27:05 PM »
korek sis sirjon aka hiv
baka kulang ang supplied voltage
Offline rovericks
  • 1124
  • 325
  • I SHALL RETURN
« Reply #27 on: March 02, 2013, 08:27:54 PM »
ang galing talaga ninyong dalawa  sirjon at sir kagz..
Offline bistek
  • 545
  • 9
« Reply #28 on: March 02, 2013, 08:43:56 PM »
master rovericks baka dito mo na lang ko bigyan ng mapa then upload ko na lang dati kasi dito na lang ko kumukuha ng mapa upload ko lang
  • 6486
  • 867
« Reply #29 on: March 02, 2013, 08:58:25 PM »
@ts
pakicheck ang email account mo baka may mali
Offline roxas
  • 49
  • 0
« Reply #30 on: March 03, 2013, 03:20:22 AM »
Idea lang po ito baka hindi na umaabot ng 180 ang sukat ng video dahil pag on ng tv hold down agad,hold down ang problema siguro nito idea ko lng po
Offline TBG
  • 2765
  • 259
« Reply #31 on: March 03, 2013, 06:52:46 AM »
activated daw proteck circuit sabi ni master kagz.
sundin mo lang ang mga master sa itaas.
Offline sirjon
  • 917
  • 148
« Reply #32 on: March 03, 2013, 08:40:57 PM »
Ok ba B+ mo? Three posibilities kung ok naman Pwr Supply
1) Me loscon - resolder muna
2) Hor. one line - magpo-protect talaga yan kasi yung masinsil na too bright one line eh masusunog yung phosphor ng picture mo kaya, hold down sya agad. Check mo vertical section. Kung me spare, actual replace vert ic
3) Me tama na FBT. Flyback testing dapat
Offline bistek
  • 545
  • 9
« Reply #33 on: March 04, 2013, 03:00:30 PM »
mga master pina test ko na ung flyback JF0501-32639 sa raun good naman gusto ko naman bumili kaso walang replacement worth 150 pesos meron orig 1k mahirap i swap baka di gumana sayang un 1k at tanong ko lang master ano po ung value ng resistor na R604 at R603 paligid ng regulator kasi iba na ung nakalagay na resistor di ko alam kung tama ung value?  ano po ang pwede na i replace dito sa vertical ic niya LA78141?
Offline bistek
  • 545
  • 9
« Reply #34 on: March 04, 2013, 03:05:52 PM »
master rovericks baka pwede dito na lang sa account ko na BISTEK kau magpadala ng mapa i upload ko na lang mukhang may problema
Offline rovericks
  • 1124
  • 325
  • I SHALL RETURN
« Reply #35 on: March 04, 2013, 03:17:48 PM »
R604 and r603 = 0.56 ohm 2watts
yong vertcal ic pwede dyan yong la78040N.
regarding sa mapa check your inbox..
Offline xxx1987virusxxx
  • 2935
  • 252
  • SERVE THE LORD WITH JOY 0G&68O05H2&12Dcdgn
« Reply #36 on: March 04, 2013, 03:19:20 PM »
gusto sana kitang tulungan kaso naerase ko ata pinadala sakin ni master roverects nwala yung mapa....check mo nga ito kung same silamm
"MAY MAS MAGANDANG PLANO ANG DIYOS KAYSA SA MGA PLANO  NATIN"
"A3L ELECTRONICS REPAIR SHOP"
  • 2935
  • 252
« Reply #37 on: March 04, 2013, 03:23:48 PM »
.56 JA/metal oxide 2watts.. parihas kung same sila ng diagram...115B+ nito...andito pala smae lang salamt master rovericks..+1 sayo
Offline bistek
  • 545
  • 9
« Reply #38 on: March 04, 2013, 05:23:06 PM »
mga master un ba na R604 at R603 pwede din ba ung colorcoded na resistor basta 2 watts ang nakalagay ngaun dito isa lang resistor ung kulay puti pahaba siya may gumawa na kasi una nito
  • 2935
  • 252
« Reply #39 on: March 04, 2013, 05:25:27 PM »
kahit ata 1 ohms pwide na dyan tingin nyo or must better carbon resistor bastat malapit sa value..
