need help welding circuit how to varry current to reduce weld
pashare  nman mga boss  na expert sa welding circuit ung variable current ...maadjust thru potentiometer or other controller...malakas po kc weld or hindi consistent minsan ...ty po
Re: need help welding circuit how to varry current to reduce weld
« Reply #1 on: March 06, 2013, 09:18:01 AM »
circuit po kailangan ko mga boss variable controler of current
Offline bravokilo
  • 6707
  • 185
« Reply #2 on: March 06, 2013, 09:22:25 AM »
not practical to control the huge  current by semicons. The way it is done is choosing the number of turns in the secondary. STill another way is for the core being moved in the transformer. Study Daidens and Mitsubishi welding machines. I have the latter, 150 amps. I also have a Mig welding machine, Hobart Handler 150.
BK
Offline DJFEL
  • 2134
  • 96
« Reply #3 on: March 06, 2013, 09:23:47 AM »
basa mona neto..parang ang haba nang osapan neto..
dj fel on the mix
« Reply #4 on: March 06, 2013, 09:32:39 AM »
what about using SCR to control high current... anybody can share simple circuit sir..ty po
Online Super zHero
  • 5782
  • 310
« Reply #5 on: March 06, 2013, 12:02:16 PM »
If the problem is inconsistency of the weld, there are several factors to consider.  Do not right away try to solve the problem by modifying your welder.
The type of welding rods, their age or exposure to humidity can vary the weld quality.  The source or your AC mains supply might not be stable, therefore varying your weld consistency.
Old welding machines (I don't know about the new ones) used to have a reactive core or inductor to stabilize the current.
  • 5744
  • 402
« Reply #6 on: March 06, 2013, 03:42:14 PM »
madali lang mag control nang current nang welding machine. specially with SCRs but kelangan nang konting rNd. obvious na hindi mag current control sa secondary side. since i don't think meron semicon that could handle that much current. sa primary which is high voltage and low current pwede mag control.
and i don't think na may SIMPLE circuit.
  • 5744
  • 402
« Reply #7 on: March 06, 2013, 03:47:54 PM »
try mo muna mag experiment using salt water resistor.
http://en.wikipedia.org/wiki/Liquid_rheostat
Asin, tubig at balde muna...
Offline motion55
  • 3171
  • 520
« Reply #8 on: March 06, 2013, 04:18:40 PM »
Saan mo gagamitin ang welding? Di parepareho ang circuit. Depende sa gamit.
Eto spot welding:
http://youtu.be/hxWo8ko2k2A
"Set your mind free!"
Offline @badoy
  • 82
  • 4
« Reply #9 on: April 28, 2013, 12:28:02 PM »
baka thyristor pwede. kaso saan ka bibili ng thyristor that can handle hundreds of ampere. mangangahoy ka sa sirang VFD or sirang 20 to 250 KVA UPS or di kaya sa mga sirang VRF aircons....
mag series ka ng inductor sa primary sigurado bagsak amperahe sa secondary....wag mo nag parirapan sarili mo. welding machine lang yan... ;D
